Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Rough idle with P0300, P0304, P0305, P0306
Reply
Thread Tools
Old 01-01-2009, 07:06 PM   #1
MZAMPINI
Boca Raton, FL
98 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy Rough idle with P0300, P0304, P0305, P0306
If anyone can help with this it would be greatly appreciated. I have a 1998 Explorer with the 4.0 SOHC and about 98K miles. Everything was fine when I left it for about two weeks in the driveway. When I came back the MIL was on, running rough and a moderate to loud ticking noise. It was a great massage on the way to hockey practice. When I returned I read codes P0304, P0305 and P0306 misfire on cylinders 4, 5, 6 respectively. The MIL is now blinking. After resetting the codes I get the following error code, P0300 which is the error code for random / multiple Cylinder missing. The spectrum of solutions range from replacing spark plugs to replace the engine, yikes. Replacing the engine will cost more then the value of the car. If engine replacement is needed, I hope to find a ‘minimum for your trade’ and get a new car. Thanks in advance for your help and advice. What a great way to start 2009!
The freeze frame data is below:
Fuel System 1 Status – Closed loop … Normal
Calculated load – 32.9%
Coolant Temp – 183 F.
Short Term Fuel Trim Bank 1 – 2.34% Rich(+)
Long Term Fuel Trim Band 1 – 24.22% Rich (+)
Short Term Fuel Trim Bank 2 – 2.34% Rich(+)
Long Term Fuel Trim Band 2 – 18.75 % Rich (-)
Engine Speed – 1314.75 RPM.
MZAMPINI is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-01-2009, 09:29 PM   #2
dynamite196
Glastonbury, Connecticut
97 Sport
Vehicle Specs
Quoted: 0 Post(s)
How full was the tank before you let the car sit? I'm willing to bet it's water in your gas tank. Fill up the tank and add a can of seafoam, that should solve the problem.
dynamite196 is offline   Reply With Quote
Old 01-03-2009, 10:49 AM   #3
MZAMPINI
Boca Raton, FL
98 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the tip, the tank was full. Also, I noticed that it runs okay for the first 5 or so minutes until it warms up, after resetting the codes it starts with P0300, followed by P0304, P0305 and finally P0306. The engine sounds like the old days with extensive engine knock on acceleration. I also noticed the fuel trims were at 100% lean. Once in a while the MIL flashes for a few seconds, typically at a long light. The local shop was out of SeaFoam so I tried two cans of the ChemTool B-12 without any changes in operation after 20 or so miles. Any other ideas?
Thanks again for your help.
Old 01-13-2009, 12:07 PM   #4
BaroquenHorse
Keeping, Private
2001 Exp Sport
Vehicle Specs
Quoted: 0 Post(s)
Vacuum Lines
Try running the vacuum lines for a collapsed line. esp the larger diameter hoses.
BaroquenHorse is offline   Reply With Quote
Old 02-20-2009, 09:52 AM   #5
jfrenzel
Chicago, IL
1999 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Did you have any luck with this? I have a 99 Sport SOHC that does the same thing. I cleaned the MAF and it seems to be bit better.
jfrenzel is offline   Reply With Quote
Old 02-20-2009, 10:51 AM   #6
team
1996
Vehicle Specs
Quoted: 0 Post(s)
Obviously it is running lean because the fuel trims are adding a lot of fuel. So i would clean the maf sensor first then see what happens. You could also check the resistance of the plugs and plug wires to see if any one of them stands out before just buying parts. If after you clean the maf and check the plugs and wires you are still getting a lot of fuel trim added you may have the SOHC's famous intake o ring gasket leak.
__________________
96 explorer sport 4x4 ohv, 31s, autozone shackles, cragar soft 8s, TT
team is offline   Reply With Quote
Old 02-20-2009, 02:51 PM   #7
BaroquenHorse
Keeping, Private
2001 Exp Sport
Vehicle Specs
Quoted: 0 Post(s)
JFrenzel,
If your question was to me, the answer was yes. I changed the maf and wasted 125 bucks. Then bought a 5 dollar hose at the parts store and Voom. Then the same thing happened to my daughters 01 Focus. Ran the hose and bingo, clam shelled right by the back of the engine. My 2001 Explorer collapsed on a large diamater hose located under the large intake duct. I coudn't see it in either case. Since it costs nothing to check for a collapsed or loose leaky hose, just give it a try. (engine off!!!) Good luck!
Old 02-20-2009, 03:18 PM   #8
zukman
"Home of Misfit Crawlers"
arcadia calif.
zukman's Avatar
'91EB, '86Sami, '85Ranger
Vehicle Specs
Quoted: 28 Post(s)
Check your heater hoses! My '98 Exped just thru a code 0304 -misfire in #4
Turns out the heater hoses are routed directly above, they drip and or leak causing a short between the boot and the plug. It can tale other cylinders with it. Worth looking at.
__________________
1986 Suzuki Samurai JX(under reconstruction)
1991 ExplorerEddie Bauer http://www.explorerforum.com/forums/...d.php?t=263112
1991 Explorer XLT http://www.explorerforum.com/forums/...40#post2995740sas on the way!
1985 Ranger (waiting for elec surgery)
Tow vehicles-Theirs- '99 Cruise Master, His '01 F-250 4x4,Hers'07 Hummer H3 X
Flags http://www.explorerforum.com/forums/...ight=Wave+Flag
Light Covers http://www.explorerforum.com/forums/...45#post2625145
zukman is online now   Reply With Quote
Old 03-19-2009, 03:21 PM   #9
fdte320
Southern CA
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
This is my first post in this forum. Got a 96 Explorer XLT 4-door. Just pulled out a P0306 DTC. Did my search & it ranges from spark plug, wire, coil & possibly the CAT. Has anybody experience a P0306 and how it was fixed? Thanks for any advice.
fdte320 is offline   Reply With Quote
Old 03-19-2009, 08:22 PM   #10
team
1996
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Your number 6 cylinder is misfiring. Check the wire and spark plug first for problems.
__________________
Old 03-23-2009, 11:47 AM   #11
fdte320
Southern CA
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks for the reply. I believe cylinder 6 is the one closer to the firewall, driver side? Any particular signs I have to look for in the spark plug & wires? I I have read also that the coil can also trigger this problem. Can a shot cat converter trigger this DTC? Thanks again.
Old 06-18-2013, 04:18 PM   #12
92eddie4x4
Kirkland, WA
'97 XLT, '03 Mounty,
Vehicle Specs
Quoted: 1 Post(s)
I just wanted to let you guys know of my experience with P0300. I pulled this code after work one day in the 5.0L V8, 1997 Explorer. It started up fine, but the idle was quite rough, certainly a misfire. I went to drive home and on the way the CEL came on and started flashing at me. I decided to investigate after I got home and found the #2 cylinder spark plug wire had been rubbing against the hot exhaust manifold and burnt through. I changed out the wire and the engine runs fine again. I cleared the CEL and it hasn't come on since.
5.0L V8 Cylinder Diagram
FIREWALL
4 - 8
3 - 7
2 - 6
1 - 5
FRONT
__________________
"Supercars are designed to mess with G-forces, and hypercars are designed to mess with G-strings."
--Jeremy Clarkson
92eddie4x4 is offline   Reply With Quote
Reply
Tags
misfire, p0304, p0305, p0306, rough idle. p0300
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
