Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Oil pan gasket removal...
Reply
Thread Tools
Old 01-06-2009, 08:20 PM   #1
35Remmy
Binghamton NY, Hazleton PA, Northern NJ
'88,'99 Ranger, '00 EX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
While we're on the topic of gaskets...to replace the oil pan gasket, is it possible to just unbolt the motor mounts and lift the engine high enough with a jack to make clearance to remove the pan?
35Remmy is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-07-2009, 09:04 AM   #2
Cobraguy
Phoenix...Greatest City on Earth
Cobraguy's Avatar
1995 EB & 1999 EB 5.0
Vehicle Specs
Quoted: 13 Post(s)
Yes. Each engine is a bit different though. Some may require lifting the engine a long ways...practically out of the car! But it can be done that way.
__________________
http://banners.wunderground.com/weat...AZ/Phoenix.gif
Quote:
Originally Posted by four0sport
she is a girl, there are no answers, only more questions!
Cobraguy is offline   Reply With Quote
Old 01-07-2009, 09:39 AM   #3
Turdle
Move along people
Humboldt, KS
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 700 Post(s)
Quote:
Where will you place the jack if you remove the pan?
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 01-07-2009, 10:29 AM   #4
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
Quote:
If your just changing the gasket, its possible.. You will need to fish the gasket through the pan, under the oil pump to get it all the way across.. I've heard of someone doing it on EF before.. Changing the oil pump is a different story.. you would have to lift the motor so high you might as well pull it out.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 01-07-2009, 07:46 PM   #5
35Remmy
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Actually, I was just going to use an engine hoist to lift the motor up since I wouldn't have the oil pan.
I was also wondering if this would place too much strain on the driveline (trans, transfer case, driveshafts, etc. ???
Old 10-30-2009, 02:04 AM   #6
cjryan
CA
2000 XL 4.0 OHV 4x4
Vehicle Specs
Quoted: 0 Post(s)
I was thinking the same thing... Also would the exhaust manifolds have to be separated from the block to do this?
cjryan is offline   Reply With Quote
Old 10-30-2009, 02:25 AM   #7
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
Im not sure how much of a gap you have, prolly 1/4-1/2 inch. If I ever have to do this im just gunna unbolt the pan. Clean up both surfaces as best I can with the pan still on but unbolted. Then Black RTV the thing back on. RTV holds better and lasts longer than a gasket any day.
__________________
Explorer how to videos Brakes, Intake, Seafoam, Coolant Flush, Oil change, Differential Flush, Inertia Switch, Thermostat, Transfer Case Flush, Throttle Mod, and more!
http://www.youtube.com/user/jlsparky7
If you like/use my vids you can thank me by subscribing to my youtube page! Thanks!
jlsparky7 is offline   Reply With Quote
Old 10-30-2009, 02:31 AM   #8
cjryan
CA
2000 XL 4.0 OHV 4x4
Vehicle Specs
Quoted: 0 Post(s)
Does the tranny have to be removed from the engine to do this?
Old 10-31-2009, 08:48 AM   #9
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
Ithink it would depend on the vehicle configuration...
Quote:
~Mark
On my 99 Explorer, removing the oil pan and changing the pan and oil pump was simply removing the 23 or 24 bolts in the pan, removing the starter to get it out of the way, and pulling the pan straight down and out of the vehicle...Now my truck is a 2wd OHV ...Start to finish took maybe an hour and that included cleaning the pan and underbody since I was there...And the pan gasket is a metal and neoprene piece that will not leak unless you over tighten it...
I am assuming a 4wd and/OR SOHC requires more hardware to either be removed or raised out of the way...
__________________
When in doubt, use a bigger hammer!
2014 Jeep Compass Limited [Company Vehicle]
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is offline   Reply With Quote
Old 10-31-2009, 10:07 AM   #10
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
I was talking 1st Gen X (its what I know).
From what I've seen though, its "more possible" to do on a 2nd gen (true IFS) front end explorer than a TTB explorer (1st gen). If the 2nd gen has a lift kit, the suspension needs to be pulled first (Turdle did this somewhat recently)
~Mark
__________________
Old 04-21-2010, 11:33 PM   #11
cjryan
CA
2000 XL 4.0 OHV 4x4
Vehicle Specs
Quoted: 0 Post(s)
Really??!! I thought all the OHV's had the crossmember underneath making the oil pan gasket replacement near impossible (without unbolting the motor mounts). I have a 2000 4wd OHV. Do I have to lift the engine? If I do, do I need to remove the tranny? Exhaust manifolds? Upper intake? EGR tube?
Old 04-22-2010, 06:15 AM   #12
ranger7ltr
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
I think the difference is 2wd vs. 4wd...
On my 2wd Explorer, there is a front crossmember to mount the rack and the power steering cooler.. That is under the harmonic balancer and the very front of the oil pan...From that point on, there is nothing but open space where the oil pan resides until you get back to the transmission bellhousing... The engine mounts are on the frame rails and out of the way completely as is the exhaust out of the way...
Obviuosly the 4wd has the transfer case and the front pumpkin and axles in the way of removing the pan...
I don't specifically have pics of the underside of my truck but I do have some that show the clearance under the engine... Since I will be changing a shortblock in mine this weekend I can take some better pics of the frame and the space available...
__________________
Old 04-22-2010, 10:33 PM   #13
Runnin'OnEmpty
Southeast USA
2000 Sport
Vehicle Specs
Quoted: 46 Post(s)
Question
Ranger, just curious as to what kind of oil and how
often it was changed on that engine? Seems like an
excessive amount of gunk built up down there....?
Did the oil pump screen clog; is that why you pulled
the pan?
__________________
2000 Sport 4x2, 4.0 ohv, 5R55E w/Superior shift kit, 3.55 diff, Mazda truck alloys/BFG TAs, RoadMaster Active Suspension, EE anti-sway bar, F&R poly bushings, camber kit, Rancho shocks, Hooker Aero Chamber muffler, Medium Wedgewood Blue.....
Bought another 2000 Sport (God help me), 4.0 ohv auto, 60K actual miles, Cragar SS alloys/BFG TAs, AAL, EE anti-sway bar, Gibson cat-back, Harvest Gold, GT leather interior.
Runnin'OnEmpty is offline   Reply With Quote
Old 04-23-2010, 12:15 PM   #14
ranger7ltr
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
Can't tell what type of oil was used...
I bought the Explorer with a dead oil pump and fuel pump...I pulled the fuel system supply and plumbed in a stand-alone fuel system and got the engine to run...I cannot even tell if this engines' oil and oil filter were ever changed in 151k miles...
That is when I found this engine had no oil pressure...So drop the pan and replaced the pump and screen...This is what I found when I dropped the pan...
After running the engine with oil pressure one of the rocker arms stuck down and its pushrod fell out of the top of the arm so I developed a dead miss...When I pulled the pass valve cover I found the cover full of solid sludge except for the path of the rockers...I cleaned all that out and started using synthetic oil and for the last 15 months drove the truck...
Last week I pulled the heads to replace them and replace leaking head gaskets and found 2 of the cylinders were not good or reuseable...And I also found that synthetic oil did nothing much to remove sludge buildup in this engine...
I am installing a new shortblock this weekend...
__________________
Old 04-23-2010, 03:51 PM   #15
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
Quoted: 77 Post(s)
You will have to tell that to Pennzoil. They claim PP removes 46% of sludge with the first oil change...
http://www.pennzoil.com/#/motor-oil/pennzoil-platinum/
__________________
2000 Ford Explorer SOHC 4X4 310,000KM
2000 VW Beetle 1.8
1991 BMW 735iL
bluestream1 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
