Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2002 explorer rear window washer not working????
Reply
Thread Tools
Old 01-10-2009, 12:54 PM   #1
julia_gulia4697
Adirondack Mtns, NY
2002 XLT & 2008 Eddie
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The Rear window washer on my 2002 XLT isnt working............it makes the 'motor noise', the wiper wipes, but no fluid comes out. The fluid tank is full....................What could be the problem?? HELP!
julia_gulia4697 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-11-2009, 06:35 PM   #2
not8taxi
queens, ny
02 XLT
Vehicle Specs
Quoted: 1 Post(s)
i had the same problem a while ago...i found the hose that connects to the back window came out of place...when u look in the engine bay...on the passenger side...behind the air filter on that side....there should be a splitter from the tank to the front hood spray and one that goes to the rear...check that maybe it came out like mine did....ill try to get a pic tomorrow...
not8taxi is offline   Reply With Quote
Old 02-10-2009, 01:45 PM   #3
julia_gulia4697
Adirondack Mtns, NY
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I think I found where the hose to the back wiper is unhooked, but WHERE does it go???? I cant tell where to re-attach it............
My rear window is GROSSSSSSS, help a girl out!!!
Old 02-11-2009, 09:53 AM   #4
tv4fish
Minnesota
2007 EB V8 & 2002 EB V6
Vehicle Specs
Quoted: 1 Post(s)
Julia: If you found the end of the hose that feeds the rear window, try to find the splitter next. Maybe try to follow the hose back from the nozzles that spray the windshield to the splitter - or follow the hose that comes out the bottom of the washer tank to the splitter.
tv4fish is offline   Reply With Quote
Old 02-17-2009, 04:13 PM   #5
julia_gulia4697
Adirondack Mtns, NY
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok, I found the splitter, and reconnected it...............now all the fluid is DUMPING OUT behind the rear passenger tire! WTF???!!!!!!
Any ideas??
Old 02-18-2009, 09:09 AM   #6
tv4fish
Minnesota
Vehicle Specs
Quoted: 1 Post(s)
The washer line has either pulled off the spray nozzle at the top of the rear hatch or the line has spilt. My bet is that it has been pulled off. Time to "dis-assemble" the rear hatch so you can check out that line !!
Old 01-08-2013, 04:55 PM   #7
Butchlund
2002 ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Thanks to this site my rear window washer works again instead of wasting fluid
Butchlund is offline   Reply With Quote
Old 01-08-2013, 09:32 PM   #8
Donystoy
Hamilton, Ontario
02 Eddie Bauer
Vehicle Specs
Quoted: 28 Post(s)
I had the same problem a few years back after recently purchasing the truck. Mine only opened up under the hood at the splitter. Never had this problem with vehicles with a seperate rear reservoir.
Donystoy is offline   Reply With Quote
Old 01-08-2013, 10:57 PM   #9
DAT05EXPLODER
Hampton, New Hampshire
2002 XLT 4.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
chances are it's just broken at the nozzle on the hatch. remove the 3rd brake light and it will be obvious from there. most likely should be a free 2 minute fix too.
DAT05EXPLODER is offline   Reply With Quote
Old 07-26-2015, 01:18 PM   #10
ccrider
Eugene, Oregon
2002 Ford Explorer EB
Vehicle Specs
Quoted: 0 Post(s)
'02 Explorer rear washer
My experience was a little different. I traced a leak to the back passenger side rear quarter panel near the spare. There were two access holes covered with plastic on my EB. They proved useful in tracing the tube. Then, I took apart the interior panels around the hatch on the passenger side tracing the tube from the front reservoir. Only the upper panel had to come completely off. There was a connector for the tubing there. It had vibrated loose. 20 minutes or so.
__________________
02 EB X
4.6L
ccrider is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
