Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
PO171, PO174, PO304, and PO442 at the same time! Ideas...
Reply
Thread Tools
Old 01-13-2009, 01:23 PM   #1
djp2233
Dallas TX
2000 XLS 4.0 SOHC
Vehicle Specs
(Original Poster)
Hello. I'm new to this forum, but here goes. I have a 2000 Explorer, 4.0 SOHC with about 100,000 miles on it. About 3 months ago, I was getting codes Po171, Po174 at the same time. My truck was "chugging" at idle, so we thought it must be a miss, bad plug, etc. At the advice of a self-proclaimed mechanic, we changed the plugs and wires. They had at least 30k on them, so why not? For about a month's time, all was well. Then the CEL came on again. This time, Im getting codes PO171, PO174, PO304, and PO442.
PO171 and PO 174 suggest a rich or lean fuel/air ratio.
PO304 suggests a misfire on Cylinder #4. inspection of the plugs/wires show that they are in good condition since I recently replaced them
PO442 suggests a small leak in the EVAP system. And from what I have read, PO442, is the "mechanic's nighmare"
Just to give some insight, the vehicle "chugs" badly at start-up, and now it chugs sometimes while moving. I used some fuel injector cleaner and installed a new gas cap (the old one was, well, old), and I'm looking for some additional direction as to what all this could mean. I'm not even sure they're altogether related. Any assistance would be appreciated.
djp2233 is offline   Reply With Quote
Old 01-13-2009, 03:39 PM   #2
montegun
philadelphia
2001 explorer sport
Vehicle Specs
the 171 and 174 are lean codes usually the culprit is the upper intake gasket has a leak as for as the misfire code have you checked for spark at the coil pack just because the plug looks good doesnt mean its getting the proper spark
montegun is offline   Reply With Quote
Old 01-19-2009, 10:26 AM   #3
djp2233
Dallas TX
2000 XLS 4.0 SOHC
Vehicle Specs
(Original Poster)
Update. I finally got a chance to see what was going on. I decided to check the plug on Cylinder 4 since that is the code I was given. It appears that oil dripped on to cylinder 4 spark plug, gunked it all up, and caused the misfire. It was almost impossible to get that plug out, but I did with great care (after thoroughly cleaning the area around it). So I think this should solve one of my problems at least. But I know I have bigger problems to address as well!
Old 05-30-2012, 07:41 AM   #4
Zach Everlast
99 ford explorer sport
Vehicle Specs
po442 is normally an evaporation error such as a hose leak or something small like that. mine has it all the time with nothing major seeming wrong, i just clear the code and keep driving.
Zach Everlast is offline   Reply With Quote
Old 05-30-2012, 07:48 AM   #5
drdoom
VA
1997 XLT 4.0 SOHC 4WD
Vehicle Specs
I would be doing a run-up on the EVAP system, tracing all lines & connections. You have a leak there I think.
drdoom is online now   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
