#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
2004 Explorer transmission bangs coming from park to reverse or drive?
Reply
Thread Tools
Old 01-15-2009, 02:16 PM   #1
Bri2004
Wayland NY
2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US 2004 Explorer transmission bangs coming from park to reverse or drive?
It has 38k on it. What is the fix?
Is it ok just to leave it like this? or will it screw up the tranny?
Bri2004 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-15-2009, 02:28 PM   #2
ericautopart
Jersey Shore
1998 XLT 5.0L AWD
Vehicle Specs
Quoted: 1 Post(s)
Sounds like a u joint to me..
ericautopart is offline   Reply With Quote
Old 01-15-2009, 02:44 PM   #3
Bri2004
Wayland NY
2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It's not a u joint. It has like a delay going into gear. Then it engages with a bang. Would a tranny fluid and filter change help?
Old 01-15-2009, 05:37 PM   #4
Curtis
Orlando, FL
04 XLT 4x4
Vehicle Specs
Quoted: 6 Post(s)
Did you check the u joints?
Cause it sure sounds like one to me too...
__________________
Curtis
2008 Expedition EL Limited
2004 Explorer XLT 4x4 4.6
1970 Buick GS 455 Silver Mist
Curtis is offline   Reply With Quote
Old 01-16-2009, 07:49 AM   #5
Bri2004
Wayland NY
2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes I checked the u joints. All ok. I did a search in the transmission section on this forum and it seems to be a common problem. Some have changed the solenoid pack and some have worked others have not. Others have changed the fluid and filter and worked and others have not. So last night I changed the fluid and filter and seems ok but we will see what happens over time.
Old 01-16-2009, 08:03 AM   #6
Bri2004
Wayland NY
2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I first posted this question in the 02-05 forum. Then I saw the transmission forum. So here is my issue.
2004 Explorer transmission bangs coming from park to reverse.
Old 01-16-2009, 08:32 AM   #7
Curtis
Orlando, FL
04 XLT 4x4
Vehicle Specs
Quoted: 6 Post(s)
Keep us posted.
I had a mustang once that would barely drive, gave it a trans fluid change and a bottle of lucas and used it for another couple yrs!
__________________
Curtis
Old 01-16-2009, 11:08 AM   #8
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
I've merged both threads together. Please don't start 2 threads with the same subject in 2 separate sections.
BrooklynBay is online now   Reply With Quote
Old 01-17-2009, 04:03 PM   #9
SwampRod
Ohio
2002 Limited
Vehicle Specs
Quoted: 0 Post(s)
My 2002 does the same thing, but not always. It sometimes happens when I am parked on a steep incline. I think it is Trans Fluid level related. I do not have a dip stick on mine so I can not tell the level.
SwampRod is offline   Reply With Quote
Old 01-17-2009, 05:06 PM   #10
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Check the driveshaft's spline where the two halves meet -- make sure its full of grease. Next thing to check would be for any "play" on the rear axle's pinion (very common for the third gen to have rear differential issues).
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 01-18-2009, 06:31 PM   #11
SwampRod
Ohio
2002 Limited
Vehicle Specs
Quoted: 0 Post(s)
Not Sure
I know the "clunck" you are refering to, but when I select reverse and nothing happens I'll increase the RPM's and then "bang" it slams into gear.
Old 01-23-2009, 01:17 PM   #12
Bri2004
Wayland NY
2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I am going to replace the selonoid. Hope it cures it.
Old 01-25-2009, 11:34 AM   #13
Bri2004
Wayland NY
2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
All is well after replacing the selonoid.
Old 01-25-2009, 03:04 PM   #14
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Thanks for the update!
Old 01-25-2009, 03:13 PM   #15
eXcali
Bourbonnais, IL
98 Explorer XLT AWD 5.0
Vehicle Specs
Quoted: 0 Post(s)
First time I saw this post, I was going to tell you to try the selonoid ,but it seems you're 2 days ahead of me!
On a side note: I had a front wheel drive sedan that had the same issue you say, it turned out to be the engine dog bone mounts as it was a V6 mounted sideways so the engine block would torque when you switched gears.
eXcali is offline   Reply With Quote
Old 01-16-2011, 02:45 PM   #16
paulcrabtree3
Marion, AR
2004 Explorer
Vehicle Specs
Quoted: 0 Post(s)
transmission banging in gear
i have a 2004 Explorer with 130k miles. Changing from drive to reverse and back comes with a long pause and then slams in gear. i'm not sure what to do. Are there any other year models or other vehicles with same transmission??
paulcrabtree3 is offline   Reply With Quote
Old 01-16-2011, 02:55 PM   #17
waskly
Crooklyn NY!
Vehicle Specs
Quoted: 4 Post(s)
most common was a solenoid body, if that dont fix it, its internal to the unit, considering the solenoid body can be done in vehicle and its not 700 dollars no more but in the 2-300 range its probably a good shot to change it.
waskly is offline   Reply With Quote
Old 01-16-2011, 08:49 PM   #18
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! Did you check the transmission fluid level to see if it's low?
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
