#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
leaking front differential
Reply
Thread Tools
Old 01-26-2009, 12:08 PM   #1
goldenmonkey
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i was changing my buddies oil in his 2002 explorer with the 4.6 v8 and awd the other day and noticed a leak on the front differential.
initially it looked to me as if it was leaking from the bottom of the cover, but after searching on here there seems to be alot of problems with the pinion seal leaking.
how can I be sure which one is leaking?
if it is the front cover, is there a gasket or is it just a silicon thats on there.
any help is appreciated,
thanks
goldenmonkey is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-12-2009, 02:44 PM   #2
aspitaletto
Cape May NJ
05 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
my front dif has been leaking for 2 years, its a TSB, but im out of warranty, so im not fixing it
aspitaletto is offline   Reply With Quote
Old 02-12-2009, 04:36 PM   #3
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Clean it up then watch daily to you figure it out.
By the way, my heep front diff is leaking out the side seal for about 4 years now. . its a dana front. IMHO if the drip overnight is like dime don't worry, just make sure you check the oil level and keep it full. Mine barely drops in a year if at all, still the drip.
Only exception is if it leaks more when moving then stopped.
they have a saying jeeps like to 'mark' where they sleep. . .lol
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 35k
2010 Sport Trac Limited, V8 4WD, 80k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 02-13-2009, 09:56 AM   #4
aspitaletto
Cape May NJ
05 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
+1 for American Car quality
Old 02-13-2009, 03:18 PM   #5
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
honestly it was dry for the first 8 years and 100k mi or so . . .i think the leak was more do to replaing the u-joints, and some shop wasn't carefull about putting the driveshaft back in. . . jeeps are a special breed. . .
__________________
Jim
Old 03-02-2009, 10:31 PM   #6
57 t-bird
colorado
98 xlt, 05 xlt
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Do you happen to have that TSB#? I have same problem, but mine should be covered under ESP warranty. They told me it was a 4 hour job. Thanks.
57 t-bird is offline   Reply With Quote
Old 03-02-2009, 10:45 PM   #7
1_v8_merc
calvert,MD
04 Mounty
Vehicle Specs
Quoted: 0 Post(s)
I almost bought an 04 explorer premium or whatever they call it.
It also had a front differential oil leak.
I told the dealer about this.
He said " well if you buy the truck, then we'll work something out to get it fixed"
And im like "bullshit, your going to sell me a truck with NO warranty, then expect me to believe your gonna live up to your word?.....your a CAR SALESMAN, you lie on a daily basis!"
__________________
2004 Mercury Mountaineer - v8, AWD, leather, BFG M/T's.
Is not afraid to go off-road!
1_v8_merc is offline   Reply With Quote
Old 09-20-2009, 02:03 PM   #8
mhartson
South Carolina
03 Explorer 4.6 AWD
Vehicle Specs
Quoted: 0 Post(s)
I have a 2003 explorer V8 AWD and it is leaking from the rear differential around where the cv axle goes into it. My mechanic checked the level said it was full and told me not to replace the seal until it starts dripping when parked. I already bought the seal and am not sure whether to replace it yet. Do you think my mechanic is right?
mhartson is offline   Reply With Quote
Old 09-20-2009, 07:21 PM   #9
tonydp
2002 Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
cheap fix, just get it done
tonydp is offline   Reply With Quote
Old 09-20-2009, 07:29 PM   #10
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
just had mine done under my extended warrenty for my 04'. it wasnt bad at all. just "seeping" a little. Better ford foot the bill then me
jakedrew is offline   Reply With Quote
Old 09-20-2009, 08:01 PM   #11
japracer4
pittsburgh,pa
04 xlt v8
Vehicle Specs
Quoted: 0 Post(s)
its the pinion seal. it takes about 15 minutes to fix and costs about $10. is replacing the diff worth it. my 04 with the 4.6 did the same. quick fix, do it
japracer4 is offline   Reply With Quote
Old 09-20-2009, 08:13 PM   #12
mhartson
South Carolina
03 Explorer 4.6 AWD
Vehicle Specs
Quoted: 0 Post(s)
I got the seal and it cost $39 at the ford dealer. I was told I needed to pull the wheel and hub and gently pry or tap out the cv axle from the rear differential. Is this correct?
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
