#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Need help removing broken sway bar end links
Reply
Thread Tools
Old 01-30-2009, 05:55 PM   #1
mcnulty6807
Alexandria, VA
2000 XLT V8 5.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp Need help removing broken sway bar end links
Hello,
I have a 2000 Ford Explorer XLT, AWD. Both of my front sway bar end links have broke. The nut on the top seemed to have popped off as well as the bushings.
What I have left is the bottom bushings and a nut. I tried loosening this nut but it keeps turning. I hosed it down with WD-40 and hammered it from the top and it still is not budgeing.
Anyone have any suggestions?
Thanks for the help.
mcnulty6807 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-30-2009, 05:58 PM   #2
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
try jacking up the lower control arm, it may be in a bind.
techieman33 is offline   Reply With Quote
Old 01-30-2009, 06:06 PM   #3
mcnulty6807
Alexandria, VA
2000 XLT V8 5.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the response.
Should I put the jack in the piece of end link that sticks through the bottom?
Old 01-30-2009, 06:11 PM   #4
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
no, on the lower control arm, under the ball joint should probably work
Old 05-27-2009, 10:52 PM   #5
markedman450
Enola, PA
01 Sport
Vehicle Specs
Quoted: 0 Post(s)
Just had the same problem, it was a huge pain to get them off cause the bolt is so rusted on, i had to pry and pry at the bottom to slowly get the bolt to slide from the original plastic pipe its in. If i would have had a way of cutting id choose that way first.
markedman450 is offline   Reply With Quote
Old 05-27-2009, 10:55 PM   #6
kyleyz762
syracuse, NY
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
i torched em LOL
__________________
kc's in front,hella's on top,ranchoRS5000,general grabber at2,cragars,procomp,cai,front hooks,billet grille,PA,alpine,jensen,usaspec,rockford fosgate,valvoline mxsyn,lucas
kyleyz762 is offline   Reply With Quote
Old 05-27-2009, 10:57 PM   #7
mikepier
Long Island, NY
99 XLT
Vehicle Specs
Quoted: 25 Post(s)
Use a vise grip to grap the entire bolt, then use a ratchet to loosen the bottom nut. Eventually if you use enough force, the plastic surrounding the bolt will break off.
mikepier is offline   Reply With Quote
Old 05-27-2009, 11:46 PM   #8
trucku
Queens, New York and living in Budd Lake, NJ now.
trucku's Avatar
2002 Explorer XLS 4.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by kyleyz762 View Post
i torched em LOL
That's what I did too...
Worked like a charm!
__________________
2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage
Gen 4 mirrors
"The More Complex The Mind, The Greater The Need For The Simplicity Of Play"
trucku is offline   Reply With Quote
Old 05-28-2009, 01:27 AM   #9
Trebor
Bridgeport,Ct
'98 Explorer 4X4
Vehicle Specs
Quoted: 0 Post(s)
i grabbed mine and with enough force was able to snap them in half and then i cut the remainder off with a hacksaw. mine were so rusted a few strokes ( no pun intended) with the hacksaw and they fell off. I actually have to go back out in the morning and re-tighten them
Trebor is offline   Reply With Quote
Old 05-28-2009, 10:19 AM   #10
volver
Milan, IL Quad City area
1998 XLT AWD
Vehicle Specs
Quoted: 1 Post(s)
I got pissed and kicked mine. It snaped off and fell through the hole.
__________________
XTL, 5.0, AWD, TT, F-150 spring, Shackles, Custom ram air intake. Rear cats removed, Glass packs, Side exit exhaust.
4x120 watt head lights + 2x100 watt head lights + 2x30 watt fog lights, thats 740 watts, one horse power=746 watts. "I am afraid of the dark"
volver is offline   Reply With Quote
Old 11-05-2014, 09:30 PM   #11
Jarred767
Seattle WA
'98 Explorer Limited
Vehicle Specs
Quoted: 7 Post(s)
Quote:
I have one that is stuck beyond belief...maybe I need to just go back out and use this method lol
Kinda wish I had a saw or torch though, sounds like that's the way to go here
Jarred767 is offline   Reply With Quote
Old 11-05-2014, 09:50 PM   #12
DjDom
Moderator Emeritus
Toronto, Ontario
DjDom's Avatar
97 XL(imited)
Vehicle Specs
Quoted: 429 Post(s)
Cut it off with a hacksaw or angle grinder..
__________________
2001 BMW 320i, 2.2L I6
2000 Nissan Maxima, 3.0L V6
1997 Explorer XL(imited), 4.0L V6 OHV, TT/Shackles, 31s, RIP with your exploded (cracked open) transmission
DjDom is offline   Reply With Quote
Old 11-05-2014, 11:03 PM   #13
1996BLKBauer
McHenry, IL
1996BLKBauer's Avatar
1996 Eddie Bauer AWD V8
Vehicle Specs
Quoted: 79 Post(s)
I got a bigger hammer, and it didn't work so I cut those things right off, lol. To be honest with any sway bar link it is easier to beak off the head and melt/cut them off.
__________________
Martha, My 1996 Ford Explorer Eddie Bauer Edition
-Alpine stereo, with Alpine Type S Doorspeakers and Alpine Type E Subwoofers in a dual chamber sealed box.
-15x7 Cragar Soft 8's, On Goodyear Wrangler Authority 31x10.50x15 Tires
-Midland 1001 LWX, with Firestick 4ft. whips on taillight mounts.
-Torsion Twist, and Warrior Shackles.. Safari Rack, and 6 Hella off road lights.
1996BLKBauer is offline   Reply With Quote
Old 11-06-2014, 02:38 AM   #14
Jarred767
Seattle WA
Vehicle Specs
Quoted: 7 Post(s)
The little saw I had didn't really do much damage (pretty sure its just for wood and probably ruined it) and I don't have a torch, but I did get it off. I ended up just pushing and pulling the top half of the end link back and forth (mine originally broke right under the top bushing but the bottom bushings would budge, even after removing the nut at the end of the broken bolt). The pushing and pulling on the rod slowly but surely pushed the lowest bushing down the rod and eventually off of it all together and it slid right out.
Probably wasn't the fastest way (well I actually know that it wasn't) but it worked and I got the new ones in.
Are you supposed to tighten those really tight, I thought I read somewhere on here that you don't want to over-tighten them. The new ones are the Moogs BTW. Thanks!
Old 11-06-2014, 10:00 AM   #15
RomeovilleIL
Illinois
98 LTD, 00 XLT
Vehicle Specs
Quoted: 89 Post(s)
If they are rusted tight, just hack saw them. When installing new ones I prefer to put some marine grease or antiseize on the bolt body so it doesn't rust tight to the sleeve (live in the snow and salt belt). The threads should be clean and have a nylock nut. Definitely do not want to over-tighten and compact the gommets. Only turn until they just start to squish.
RomeovilleIL is offline   Reply With Quote
Old 11-06-2014, 10:18 AM   #16
93 x_SPORT
GARRETT, IN
2001 Eddie Bauer V8 AWD
Vehicle Specs
Quoted: 24 Post(s)
I hacksawed and dremeled mine. Dremel worked great, but those little discs explode in a hurry if you aren't careful.
__________________
Ranger Wheels
93 x_SPORT is offline   Reply With Quote
Reply
Tags
end link, suspension, suspension problems, sway bar
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
