#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How to accurately test ignition coil pack
Reply
Thread Tools
Old 02-11-2009, 02:21 PM   #1
mikepier
Long Island, NY
99 XLT
Vehicle Specs
Quoted: 25 Post(s)
(Original Poster)
I have a 99 XLT, I'm trying to troubleshoot a slight rough idle problem. I suspect it might be the coil pack. I tested it according to the Haynes manual, it says you should get this:
Terminal 3 (coil 1)-spark plugs 1 and 5
Terminal 2 (coil 3)-spark plugs 2 and 6
Terminal 1 (coil 2)-spark plugs 3 and 4
If the resistance for all of the readings was between 6,500-11,500 ohms, the ignition coils are OK. If any of the readings was less than 6,500 ohms or more than 11,500 ohms, replace the corresponding coil pack.
But I'm consistently getting a reading of more like 13,000 ohms on each terminal. Is this normal? Anyone else get the same readings?
mikepier is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-11-2009, 03:37 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
If Haynes says that it's out of spec, and you are experiencing a rough idle, then I think this might be the answer. Check the resistance of a new coil before you buy it to compare your readings.
BrooklynBay is offline   Reply With Quote
Old 02-11-2009, 09:30 PM   #3
mikepier
Long Island, NY
99 XLT
Vehicle Specs
Quoted: 25 Post(s)
(Original Poster)
Quote:
Thanks, I think I found my problem. Was not the engine at all, it was the muffler. look for my post on how I found it.
Old 02-11-2009, 09:41 PM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Thanks for the update!
Old 12-05-2010, 09:47 PM   #5
Orleans
2005 Ford Explore Limited
Vehicle Specs
Quoted: 4 Post(s)
Hi,
I used this image for the test and the figures obtained were not accurate, they were swinging, it's normal?
Thanks
Orleans is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
