| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
lessburg
98 explorer 4.0 sohc
timing chain replacement on 4.0 liter sohc
do you have to pull engine to replace timing chains on 4.0 sohc engine
#2 |
Allen, Tx
96 XLT V6 OHV 4x4
yes, you have to pull it to get to the chain on the back side of the motor.
__________________ 96 Explorer XLT 4x4 4.0 V6, Pacesetter headers, Magnaflow high flow cats, Magnaflow dual exhaust, custom intake, Cragar soft 8s, KYB shocks, 265/70/15 BFG Rugged Terrains My 96 Explorer |
#3 |
lessburg
thank you for taking the time to reply,although i had found my answer to that question already it leaves me with several new questions
#4 |
Calgary, AB
98 XLT 4.0 SOHC
There are 3 chains: 2 front and 1 back. The front chains can be serviced (tensioners/guides) with the motor still in the truck. The rear chain must be serviced with the motor out of the truck.
Are you planning on replacing the chains or servicing the tensioners and guides? What got you to this point? |
#5 | |
Nashville, TN
'97 Eddie Bauer
Why are their 3 chains? Thats something i havent quite understood. And why in the back?
__________________ Quote:
#6 |
Germantown, MD
Info: http://www.explorerforum.com/forums/...d.php?t=163298
AutoZone's Repair Guide: http://www.autozone.com/shopping/rep...00c1528018ec62 __________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#7 | |
Calgary, AB
98 XLT 4.0 SOHC
Quote:
Why do people climb mountains? Because they can... Why do engineers make things more complex than they need to be? Because they can... I climb mountains...and I am friends with many engineers. I just never climb mountains with engineers...keeps me safe. |
#8 |
lessburg
well its my friends truck she was driving down the road and it quit on her and thats where i came in,i suspected it had jumped time or chain had broken, had no idea that ford could design something so silly...anyway she does'nt have the money to fix it the right way so i was gonna just replace the giudes and tensioners and leave the chains alone but engine has 197k so not really sure thats smart not to mention the parts are 360.00 with my nephews ford discount...any thoughts??
#9 |
Northeast
93/97 4.0 EB/5.0 XLT 4AWD
Do we have non interference engines, or are they interference engines? I think if one keeps quality clean oil (frequent oil/oil filter changes), that this would help prolong the life of the chains themselves. However, at what mileage do they begin to really stretch and or wear out, or better yet, what is the average life span of the tensioner/chain guides?
Thanks in advance!
#10 |
Spokane
99 XLT
It is crappy plastic, not soft metal. The cam chain design looks like a 1930s bicycle and will offer way too much rotary impact pressure than the rails can provide. I suppose affirmative action engineers have finally found their place. Unfortunately, indeed.
#11 |
Hickory, NC
'98 XLT, '91 EB
I have I think the same problem with mine and was wondering the best advice of where to go from here. Something finally broke on the guides and I'm pretty sure that it got loose enough to skip a few teeth on the chain. If the front chain skipped would the rear skip as well? Should I just plan on pulling motor to take a good look at everything? Like most people I don't have the money to do all that I should but just need to get it running again.
Another rought that I thought about going is swapping motor. I found a motor, tranny, transfer case and all wiring including computer still assembled for $350. It's from a '96 with 108k and mine is a '98 with 219k. I should be able to just put everything in from the '96 correct? __________________ '91 EB 4.0 OHV 4x4 31x10.5 Maxxis Bighorn's Uwharrie 2010 BrooklynBay's List of Useful Threads |
#12 |
ford explorer trac 2005
#13 | |
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Quote:
__________________ 2000 Ford Explorer SOHC 4X4 249,000KM 2003 Ford Escape 101,000KM Last edited by bluestream1; 07-28-2010 at 07:26 AM. |
#14 |
replacing rear taiming chain guide ford explorer 4,0
yes you have to remove the engine out and the top cylinder pasenger site that you can fix the timing chaine guide ,if the sporket is ok and the chain is ok dont go more than that , to get more informaitions and instructions go to this link i get every think is here D:\ford explorer repaiurs\Ford Explorer SOHC Timing Chain Replace.mht
#15 | |
Waterloo Ontario
#16 |
Detroit
01 sport
I have a 2001 Explorer Sport 4.0 SOCH with a bad timing chain guide (RH Cassette). I pulled the head to check for internal damage but forgot to drain the oil first. When I did drain the oil there was about a 1/4 gallon of coolant in the oil pan. the oil itself did not look like coolant was being burnt, and there was no oil in the overflow. Is it possible the coolant got in through the cylinders when I removed the head?
#17 |
CT
1997 XLT
I just did my timing chains at almost 205,000 miles. I would recommend replacing the chains, guides, and tensioners, but you can probably leave the sprokets. I was sort of kicking myself for buying the kit for each timing chain and not just the individual parts. But I don't know how much money that might have actually saved me. Good luck.
#18 |
Greenville, SC
2000 Sport SOHC 2WD
SOHC V6 timing chain comments
1. Ford did an injustice to its customers by producing an engine with a camshaft timing chain in the rear that requires engine removal for replacement of the camshaft chain, guide assembly or jackshaft rear sprocket. The magnitude of the injustice was increased by utilizing (and not improving) a plastic guide assembly with no metal reinforcement on the traction side that fractures from fatigue.
2. The SOHC spring/hydraulic camshaft timing chain tensioner is an inferior design compared to the OHV ratchet spring/hydraulic camshaft timing chain tensioner. The spring pressure is inadequate to prevent timing chain slip when oil pressure is low, when the engine backfires, or when the engine is manually rotated counter-clockwise. I recommend replacing the hydraulic tensioners every 75,000 miles or when the cassettes are replaced. 3. The primary (crankshaft to jackshaft) tensioner was an inferior design subject to failure at 50,000 miles. The upgraded primary tensioner is significantly improved and should provide a reasonable service life. 4. The improved camshaft timing chain guide assemblies are still subject to fatigue failure because the metal reinforcement is not bonded to the plastic. 5. Using high quality engine oil with replacement of oil and filter at recommended interval will reduce chain to guide assembly contact wear but will not delay fracture failure. The use of a pre-oiler/oil accumulator will reduce the chance of chain slippage by preventing low oil pressure when the engine is running (start up and hard cornering/braking). 6. The SOHC is an interference engine. When the timing chain slips enough the valves will collide with the pistons. The most frequent occurrence is the exhaust valves dinging the pistons requiring removal of the head and replacement of the valves. 7. The guide assembly fails much sooner than the associated chain or sprockets. It is acceptable to replace the guide assembly without replacing the associated chain or sprocket. After the engine runs for a few hours wear patterns result on the chain and sprockets. The chain and associated sprockets should be replaced as an assembly. Individual cassette components (guides, chains, sprockets) are no longer available from Ford. 8. Aftermarket guide assemblies are frequently inferior to those available from Ford. They may be warped or soon warp. They may wear much faster. They may fracture sooner. According to a Cloyes engineer I spoke with the guide assemblies that come with their timing chain kits are from the same manufacturer that makes them for Ford. Here are links to threads containing more information relating to the SOHC V6 timing chain system: Rear Timing Chain Tensioner Replacement SOHC V6 Camshaft Timing Starting my 00M12 Installation Main timing chain - OHV vs SOHC Timing chain rattle resolution process - SOHC V6 SOHC V6 Timing Chain Saga __________________ My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank |
#19 |
94 Sport
#20 |
Bayamon, Puerto Rico
2006 Mazda B4000
How to remove the fan clutch assemble ?
Ok I got a question. In order to remove the fan clutch assemble the nut behind the clutch has to be turned clockwise or counterclockwise ?? Thanks in advance.
| Thread Tools | |
