Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
P1131 code on 1999 FORD Explorer XLT SOHC
Reply
Thread Tools
Old 02-16-2009, 01:28 PM   #1
bbrizendine
Silver Spring, MD
1999 Explorer XLT SOHC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question P1131 code on 1999 FORD Explorer XLT SOHC
Have cleaned (4 times) MAF and replaced it. Engine still rough with engine light on and P1131 code. Points to 02 sensor. How do I tell which one? Where is it? I found one on left side. Can't find one on right side. I was told that there are 2 above the cat converter and 2 below - right and left side. I think the ones below the cat converter are a different code. If that's true, then how do I tell if it's the right of left one? Note - I'm a decent backyard mechanic, but don't know to use a voltmeter or do auto electric testing. How hard is it to replace?
bbrizendine is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-16-2009, 02:10 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 02-16-2009, 02:40 PM   #3
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 222 Post(s)
I replaced my RF O2 sensor about two weeks ago, same code and engine. To get at it, pull the right plastic inner fender out from the back. You can most easily get to it from the side along that back edge of the wheel well. Both of your front O2 sensors are the same part number. I suggest buying the Ford part, it will plug right in. The other brands require building the wiring connection ends, the wires come separate from the connectors.
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty, 98 Limited with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Old 02-17-2009, 06:45 AM   #4
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
Quote:
H40 DTCs P1131, P1132, P1151 AND P1152: UPSTREAM HO2S NOT SWITCHING. DTCs P1130 and P1150: FUEL SYSTEM NOT SWITCHING AT FUEL TRIM (RICH OR LEAN)
Note: It is necessary to address all Continuous Memory Ignition and Misfire DTCs, if received during Continuous Memory testing, before addressing any KOER HO2S DTCs.
DTC/HO2S Reference List
HO2S-11 = DTCs P1131, P1132 and P1130
HO2S-21 = DTCs P1151, P1152 and P1150
Check intake air system for leaks, obstructions and damage.
Check air cleaner element, air cleaner housing for blockage.
Verify integrity of the PCV system.
Check for vacuum leaks.
Are any of the above concerns present?
So, what makes you think that the sensor itself is bad? Could it not be just a simple vacuum leak in a PCV hose? A $10 hose sounds like a better deal than a $90 O2 sensor that may not fix the problem...
The code does not indicate that the sensor itself is bad. The code simply indicates a lean condition being detected by that sensor. It could, in fact, be correct. (I know, it's a novel idea) Until you've done a complete diagnostic, there's no sense in throwing parts at it...
-Joe
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 02-17-2009, 07:07 AM   #5
wyochimneysweep
fargo, nd
97 explorer AWD 5.0
Vehicle Specs
Quoted: 0 Post(s)
most of the time if its a vaccum leak both sensors willshow lean
wyochimneysweep is offline   Reply With Quote
Old 02-17-2009, 07:22 AM   #6
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Quoted: 10 Post(s)
Quote:
Depends on where the vacuum leak occurs... With the split intake on the SOHC motor, and two vacuum lines attached to it, it's possible for the vacuum leak to only affect one bank...
edit: Or, if it's the lower intake manifold gaskets, it can depend on which side(s) is(are) leaking... Vacuum leaks don't necessarily affect ALL cylinders equally...
__________________
Old 02-17-2009, 05:19 PM   #7
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 222 Post(s)
The code definition that I read pointed at the one sensor, and the wiring for it. I don't know how many different definition sources there are. I knew I had no more obvious problems, and the wiring, connections were good. Do check those, as well as the obvious vacuum leak sources, tune up items etc. I decided based on mileage and the definition that it was a good time for me to swap the RF sensor. I had it for my 302, it's the same sensor.
__________________
Don
Old 06-07-2009, 12:15 AM   #8
desertbum8
Oceanside, CA
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
Hey guys. I have had the P1131 and P1152 codes show up on my truck. The truck runs great after it has warmed up, but it still has a rough idle. When the engine is cold it has a really rough idle and the acceleration hesitates and sounds like the engine is misfiring. I just replaced the DPFE sensor and it helped a little. I was thinking my bad Cats messed up an O2 sensor. Does anyone have any ideas on how to check my sensors to see if they are bad? Thanks!
desertbum8 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
