I vote for the 4th one in the picture. The anodized metal ones with the rubber band around them. I think they are the most expensive ones but worth it IMO. By expensive I mean $12 instead of $8 haha. When I replaced my fuel pump I struggled with the scissor type ones that I bought at AZ. They bent and eventually broke. So I went out and bought the kind mentioned above, I had the fuel line off in no time.
#2 seems to work the most.. #5 the least.. I've only used #4 twice.. when #2 wasn't working for me.. I borrowed #4 when #1 didn't work.. but next time I tried #4 it didn't work and #1 did.. go figure.
I used all 3 sets for fuel lines.. I've used set #2 for a/c lines too..
actually, now that I think about it.. I used #3 once for a/c when I was at a friends shop.. I don't remember them working any better than #2..
If your asking which size do you use.. you put on which ever one fits in the fitting the best.. (not too small, not too big.. or it won't push the right spot enough)
