Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Repack front wheel bearings?
Reply
Thread Tools
Old 02-20-2009, 09:03 AM   #1
drstein
Justin, TX
1994 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've searched through a few other threads, and that's why I'm asking. I went to have an alignment done on my 94 Ex and the shop said they couldn't do it because my front wheel bearings needed to be repacked. The mechanic had the Ex up on the lift and was able to wobble my front wheels around quite a bit.
They quoted me around $350 to do the job. I opted to wait and check here first. I'm reading that you need to do that on 2WD Explorers, but mine is 4WD. Do I need to have this done?
It has about 190k on it, and I have never had it done. I do experience a wobble when going over 68 mph on the highway and a slight vibration. The tires are brand new and have been balanced, but it did this on the old tires too.
Is this something that I can do at home easily?
Cheers!
drstein is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-20-2009, 09:30 AM   #2
Verno
Waynesboro, TN
94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Cheers!
Yes! If they haven't been done - you should at least repack the bearings, if not replace them. Be sure to look closely at the races (part the bearing rolls on in the hub) and spindle for any signs of excessive wear. My new barings (from O'reilly Auto parts) came with new races, so I replaced them.
Verno is offline   Reply With Quote
Old 02-20-2009, 10:05 AM   #3
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
Once you get the right tools its easy to do... I'm assuming you still have the factory automatic hubs which means you need the 2 3/8" hub socket. Other than that the rest of the tools are normal hand tools (torque wrench is good to have too)..
If you have never done bearings before the hardest part will be packing the bearing with grease.. They sell things to help with that. There is the cut with the plunger looking thing that will fill the bearing with grease. There is also the thing that you put the bearing into and use your grease gun to fill it with grease.
I still do it by hand... I never looked for instruction on how to do it by hand but I'm sure its out there on the 'net.
If you can't find the instructions on here on how to replace your bearings using the search just post back.. I'm sure one of the EF members with good search skills will be able to find it for you..
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 02-20-2009, 11:05 AM   #4
James909
Long Island, NY
1994 GMC Yukon 2 Door
Vehicle Specs
Quoted: 0 Post(s)
Here is a really good write up you may want to take a look at. It is a how-to about brakes but all the information that you need to know in order to repack the wheel bearings is in there.
__________________
-James
1992 Ford Explorer XLT 4x4 - Sold
350 TBI
James909 is offline   Reply With Quote
Old 02-21-2009, 11:37 AM   #5
Explodr94
Vista, CA
1996 XL
Vehicle Specs
Quoted: 8 Post(s)
I had the same situation on my Ex. I agree with everyone else, but I would add that you should always replace the races with new bearings. 190K there is wear on the races as well as the bearings. IMHO Timken makes excellent bearings. After I did the repair, the shop that couldn't do the alignment, said they still couldn't do it because of play. The issue with my Ex turned out to be play in the steering box, not the wheel bearings. I found a shop that does alignments the old fashioned way (giant calipers) and the got it done.
Explodr94 is offline   Reply With Quote
Old 02-21-2009, 08:57 PM   #6
glfredrick
Louisville, Kentucky
glfredrick's Avatar
86-98 Ranger STX
Vehicle Specs
Quoted: 0 Post(s)
The price that shop quoted you for repacking the front bearings is outrageous!
You could just about replace all the parts in the front axle for that fee...
The actual work is not all that difficult, and can easily be done at home. I'd replace all the bearings. Costs for Timken bearings should be under $20 a piece. ALWAYS replace the races with the bearings. The old ones knock right out with a punch. Just tap them out in each direction -- the front out the front, the rear out the rear. Also, replace the wheel seal on each side.
Total time should be under an hour a side.
__________________
glfredrick is offline   Reply With Quote
Old 03-23-2009, 09:18 AM   #7
sniffer1974
circleville ohio
1996 xlt
Vehicle Specs
Quoted: 0 Post(s)
does anyone have a picture of front wheel bearing repair 4wd 1996 explorer
sniffer1974 is offline   Reply With Quote
Old 03-23-2009, 01:51 PM   #8
James909
Long Island, NY
Vehicle Specs
Quoted: 0 Post(s)
Quote:
http://www.explorerforum.com/forums/...d.php?t=165429
__________________
-James
350 TBI
Old 01-17-2011, 03:26 PM   #9
emberswzd
Port Richey, Fl
2001 Explorer XLT, 4WD
Vehicle Specs
Quoted: 0 Post(s)
~Mark
Ok I am confused... According to what I am reading here You can repack the bearings.. But a few post later James909 states that you have to replace the whole hub assy. I have a 2001 explorer xlt 4wd... I will be doing Lower Ball joints and want to repack everything i can while i have it apart or do i have to change the whole bearing assy?? Thanks Joe E
__________________
If you are against Teen Violence, Gangs and worthless Judges then your a friend of mine
Yours truly Joe
emberswzd is offline   Reply With Quote
Old 01-17-2011, 03:29 PM   #10
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
Quote:
That is because your reading a thread that talks about 1st generation explorers and you don't have a 1st generation explorer. As I understand it, your 2001 is bearing assembly and you don't replace the bearing or repack them.
~Mark
__________________
Old 01-17-2011, 04:41 PM   #11
glfredrick
glfredrick's Avatar
86-98 Ranger STX
Vehicle Specs
Quoted: 0 Post(s)
~Mark
Yup!
__________________
Old 01-17-2011, 09:27 PM   #12
James909
Long Island, NY
Vehicle Specs
Quoted: 0 Post(s)
As mentioned, only 91-94 Explorers have bearings which can be repacked. Sorry for the confusion, the link in post #8 was referring to the post above it which asked about a 2nd generation like you have, but the rest of the thread is pertaining to 1st generation Explorers. I went back and edited that post to hopefully clear things up.
__________________
-James
350 TBI
Old 01-18-2011, 01:38 PM   #13
emberswzd
Port Richey, Fl
Vehicle Specs
Quoted: 0 Post(s)
~Mark
Ok then what is 1st generation, 2nd generation etc...etc...And what generation do I Have??? Sorry to sound truck dumb, I'm an aviation mechanic LOL
__________________
Yours truly Joe
Old 01-18-2011, 01:41 PM   #14
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
1991-1994 is 1st gen.
1995-2001 is 2nd gen.
If you have independent rear suspension then your beyond 2nd gen.
~Mark
__________________
Old 01-18-2011, 03:26 PM   #15
emberswzd
Port Richey, Fl
Vehicle Specs
Quoted: 0 Post(s)
[QUOTE=Maniak;2628735]1991-1994 is 1st gen.
~Mark[/Q
Thank You Mark
__________________
Yours truly Joe
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
