Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
How to drop the fuel tank and replace the fuel pump.
Reply
Thread Tools
Old 02-26-2009, 08:26 PM   #1
thor1701
fresno ca
96 EB
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
ok, i've looked all over this website and i guess im not seeing it but im sure there is a "how to" on replaceeing the fuel pump for a 91 EB, and how to drop a tank, i just cant find it, and hopefuly someone can direct me to the right place and hopefuly that place has pics to help! lol thanks much
thor1701 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-26-2009, 08:40 PM   #2
James909
Long Island, NY
1994 GMC Yukon 2 Door
Vehicle Specs
Quoted: 0 Post(s)
This is the only one I know of. No pics but helpful nevertheless.
__________________
-James
1992 Ford Explorer XLT 4x4 - Sold
350 TBI
James909 is offline   Reply With Quote
Old 02-26-2009, 08:42 PM   #3
boggs1227
Flowery Branch , Georgia, 1994 sport 2wd auto
2005 colorado 2wd 5spd
Vehicle Specs
Quoted: 0 Post(s)
two ways to replace the pump / sending unit ...
1 ) to cut a access hole in the body ( inside the truck in the cargo area) to gain access to the pump .
2) jack the truck up and remove the skid plate , undo the fuel lines and the straps then drop it .
...either way has their pro's and con's .which ever way you decide just remember to mark the direction of the fuel lines as they meet up on the top of the pump / tank ( just mark it with sharpie marker) a new or different angle may cause stress on the fuel / return lines and may cause them to get damaged. the tank ring .....if it's a 91 then chances are it's pretty rusted and you may need a new one .....to remove it just get a punch and work it around the ring in one direction ( hitting each tab on the ring as you go ) this way free's up all of them together if they are cemented on the tank from decades of road grime and rust .a new o-ring should come with the pump you buy but if not then that has to be replaced as well .
boggs1227 is offline   Reply With Quote
Old 02-26-2009, 08:44 PM   #4
fordnut71
oshawa, ontario. home 2 goverment motors canada
99 ex sport
Vehicle Specs
Quoted: 0 Post(s)
if you dont mind cutting the floor on your explorer, there is a to: cut the floor to make a access panel above the fuel pump/sending unit.
replacing the pump is a few mins once you get the sending unit out.
fordnut71 is offline   Reply With Quote
Old 02-26-2009, 09:02 PM   #5
cculter
Flatrock, Michigan
cculter's Avatar
'92 sport
Vehicle Specs
Quoted: 0 Post(s)
I just finished doing this to mine. It took a lot longer than I expected just to drop the stupid skid plate. Once the plate was dropped it was very easy to get the tank down. Everything was really rusty oner there. I now have everything back up and it doesn't work. now I have to drop it all again. It would be easier to cut the whole.
__________________
1992 Sport
130,000 Miles
Climb-on
4X4 shift motor broken?http://www.explorerforum.com/forums/...d.php?t=123542
cculter is offline   Reply With Quote
Old 02-26-2009, 09:11 PM   #6
boggs1227
Vehicle Specs
Quoted: 0 Post(s)
did you recheck the harness connector on the left frame rail ? if you had a lot of dirt in or around the connector you may have to spray it with electronic cleaner...mine had a lot of stuff caked on and i had to do that .
Old 02-26-2009, 09:37 PM   #7
Dannyboy
Other Make & Models Mod
4348′48″N 9113′59″W
Dannyboy's Avatar
91 4 do'
Vehicle Specs
Quoted: 6 Post(s)
I'm in the process of changing mine out via the "access panel" method. I've dropped the tank on my last truck and although it wasn't the worst thing ever, it was all the work again to put it back up. If you get under your truck and look at the skid-plate/metal straps you pretty much just start unbolting stuff until the tank drops down.
Dannyboy is offline   Reply With Quote
Old 02-26-2009, 09:54 PM   #8
thor1701
fresno ca
96 EB
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
thanks for the fast replys guys, wasnt expecting that fast heheh, i think i will drop the tank, mainly cuz with my luck i will blow something up and my wife doesnt like the idea of me cutting a hole in the floor, so new question, whats the skid plate and where would i find a pic of one? lol
this wont be for a while as i dont have the money to get the pump-sending unit floater and whatnot, plus the jackstands and tools to take off the fuel lines
Old 02-26-2009, 10:15 PM   #9
James909
Long Island, NY
Vehicle Specs
Quoted: 0 Post(s)
The skidplate is just a protective metal plate that mounts underneath the gas tank. I may be wrong but I think they only had them on 4x4s. So if you have 2wd you may not have to worry about that. I don't know of a pic but it's one of those things that if you just crawl under the truck you'll understand.
__________________
-James
350 TBI
Old 02-26-2009, 10:18 PM   #10
thor1701
fresno ca
96 EB
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
yeah mine is 4x4 so i most likely have it
i think im just worried about it all falling on my head after i unbolt everything, then trying to re put it back up after i have everything on lol
Old 02-26-2009, 10:25 PM   #11
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
[QUOTE=boggs1227;2141292]two ways to replace the pump / sending unit ...
first remove as much of the gas as you can from the tank before working on it ( all it takes is just one spark ) QUOTE]
it is safer to work on a full tank than it is to work on a low tank as there are more vapors in a low tank and that is what ignites. and kaboom.
__________________
1993 Explorer Sport, Narrowed HP44 SAS, UA2015 survivor
Four0Sport is offline   Reply With Quote
Old 02-26-2009, 10:49 PM   #12
boggs1227
Vehicle Specs
Quoted: 0 Post(s)
mines a 2 wheel drive and mines gota skid plate .
....that sounds right about the gas/vapors ...... i was just thinking about the level of gas near the top of the tank if he was going to cut a access but if your dropping then yeah you want that fuel gone ...nothing like trying to wrestle 100lb's ( just a guess ) under the truck .....
Old 02-27-2009, 01:44 AM   #13
93explorereb
Northeast
93/97 4.0 EB/5.0 XLT 4AWD
Vehicle Specs
Quoted: 0 Post(s)
Speaking of fuel tank, my guage is totally dead! Must I drop the tank? The wiring on the sender unit is no good? What is the usual replacement for such a debacle? Hey James 909 is that disc brake swap a huge deal or what? thanks in advance!
Quote:
93explorereb is offline   Reply With Quote
Old 02-27-2009, 02:20 AM   #14
James909
Long Island, NY
Vehicle Specs
Quoted: 0 Post(s)
Does your fuel gauge stay on empty all of the time? If so it's probably because the float leaked and sunk to the bottom. It's a common problem. The only way to fix it is to drop the tank (or make an access hole) and replace the sender or repair the float.
The disc brake swap wasn't bad at all. My truck was down for a weekend but that was working slowly with a lot of breaks and I had to go to work most of one of the days. I replaced the whole rear end with one from a '99 and it was a very straightforward swap. It was my first time doing something like that and I had no trouble at all. If you're considering it I say go for it.
__________________
-James
350 TBI
Old 02-27-2009, 08:36 AM   #15
boggs1227
Vehicle Specs
Quoted: 0 Post(s)
just one more thing about about the tank.....when i dropped my tank i gave me a good advantage to see the condition of the entire fuel cell. after i got mine removed i was able to flush it out really good and clean all the years of crap in there.tho mine really did not have a lot of stuff floating in there it did however have a ring of hardened stuff right around the pick-up screen .i had to scrape it away with a penny .but after that i took a water hose flushed it out and then got my air compressor and dried it ( squeeky clean )
upon removeing the skid plate i did notice that rocks had made thier way between the plate and the gas tank and were cutting into the plastic ( not good ) .so before i reinstalled the tank i took it and wiped down the tank with armor-all and even the rubber bumper cushions that are attached to the tank to rejuvinate them . plus the filler neck and the vapor return hose's i did armor-all to them to ( that will most likelly keep them alive a little longer because their rubber after all ) .
putting the tank back was not to bad ...i used a car jack and a short piece of 2x8 to lift the tank and hold it while i attached the straps and then used it again to put the skid plate back up while i started the bolts.
but then again this all took me about 1 hour to do maybe a hour and a half ...not as quick as cutting a access and more labor to drop.
Old 02-27-2009, 07:18 PM   #16
thor1701
fresno ca
96 EB
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
new question
ramps or jackstands? personaly i like ramps better, and im just a little iffy with jackstands, as im not quite sure where to put them and do i have to do both front and back?
Old 02-27-2009, 07:50 PM   #17
James909
Long Island, NY
Vehicle Specs
Quoted: 0 Post(s)
I used ramps when I changed my fuel pump. I just put both ramps on the driver's side, one in the front and one in the back so that the whole driver's side of the truck was raised up. This gave me plenty of clearance to work.
__________________
-James
350 TBI
Old 09-21-2010, 11:26 PM   #18
thor1701
fresno ca
96 EB
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
ok i know its been a long time and no i never got around to doing the pump, i ran accross a thread that told how to cut a hole in the floor and do it that way, it had pics but i cant find it anymore, i cant drop the tank where i live, my manager looked at me and she said "YOUR NOT DROPING THE TANK HERE" so i want to do it the other way
Old 09-21-2010, 11:31 PM   #19
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 218 Post(s)
Is this the thread your looking for?
http://www.explorerforum.com/forums/...d.php?t=182160
I found it by going to the useful thread forum, and searched that forum only for the word tank. It was the only thread that showed up. If I had searched for tank throughout the entire forum I'm sure I would have never found it
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 09-21-2010, 11:32 PM   #20
thor1701
fresno ca
96 EB
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
thankyou thankyou thankyou x10000
that was just the thread i was looking for
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
