| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Charlotte, NC
'93 Ranger Ext. Cab
Ranger bed removal.
Is disconnecting the wiring, the fuel filler & removing the 6 bolts in the bed all that's required to remove the bed on a Ranger?
#2 |
Yes, hopefully your bolts ore not rusted to bad as they like to size up real good. Be sure you have a good impact gun or cheater bar. I tried grinding one off and it is a very tough steel.
Oh yeah you might need a hand to lift it off also as it is an awkward 150-200 pounds or so. __________________ 2000 Explorer Eddie Bauer 2wd *Sold* 1988 F250 7.3 IDI Diesel & C6 |
#3 |
Charlotte, NC
'93 Ranger Ext. Cab
Bed removal
Thanks. I've ready made arrangements for help taking it off. Do you know what size the Torx bolts are that hold the bed on?
#4 |
T55 torx
#5 |
UPSTATE NEW YORK
94 RANGER / 98 explorer
any pics of the bed swap ???
__________________ REDNECK RANGER 98 EXPLORER SPORT "The truck's a ford and the tractor's green" - Jason Michael Carroll |
#6 |
Charlotte, NC
'93 Ranger Ext. Cab
Bed removal
I hadn't thought of it. I'm going to remove it to replace the fuel filler neck assembly. I'll take few pics & make it a "How to" post.
#7 |
buffalo area ny
BEFORE YOU START
shoot all the bolt at least 3 times with PB BLASTER let it soak in for 20 mins or so between shooting them then they sould come out relitively easy |
#8 |
Charlotte, NC
'93 Ranger Ext. Cab
Bed removal
Thanks, I'll add that to my prep list. I'm just waiting on my tax refund so that I can purchase the filler neck assy.
#9 |
Near Los Angeles California
'95 Ranger 4x4 4.0 manual
I found this thread while researching Ranger fuel filler replacement.
I just did my '95 Ranger Supercab 4x4. It was easier than I thought it would be. I did not completely remove the bed. I put the rear axle on jack stands and removed the left rear wheel. I removed the gas cap and the three small screws that hold the filler to the bed. I removed the three bolts on the drivers side of the bed with a t-55 Torx bit. I loosened the other three so there was about a half of an inch between the head and the bed. I lifted the side of the bed and had my girlfriend place a piece of 2x4 and 4x4 stacked on the frame rail to hold the bed up. There was now plenty of room to remove the hose clamp holding the filler to the tank. I used a 1/4" drive 5/16" socket and a ratchet. The clamp is molded into the hose, loosen it thoroughly. The hardest part was pulling the crusty hose off of the tank. My local Ford dealer wanted 400 SOME DOLLARS for the part. My local auto parts stores did not carry the part. I searched eBay for Ranger fuel filler and got an aftermarket one for $72 shipped. It is an exact replacement. I only hope my motor mount replacement job is as easy. It looks somewhat difficult. |
#10 |
Charlotte, NC
'93 Ranger Ext. Cab
Bed removal
Thanks. I might try that. Sounds easier than complete bed removal.
#11 |
Quarryville
93 Ford Explorer Sport
When i took the bed off my 86 ranger, the bolts were so stripped i had to torch them out, then with the bed off i used a locking vise and spun them off, and got some new bolts from the junkyard
__________________ 93 Ford Explorer Sport 4.0 5-speed-New Daily Driver 97 Ford Ranger 2.3L 5-speed lowered-SOLD 86 Ranger XL 2.9L 5-speed 4x4--Mud Truck-SOLD My Cardomain http://www.cardomain.com/id/Z3CHYD |
#12 |
Offroad Moderator
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...JetskiMark, could you add a link to where you found the filler neck here???...I have a bit of info with one link already in this thread...
http://www.explorerforum.com/forums/...d.php?t=219411 __________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#13 |
tbars4, your smog thread is very informative.
Since eBay item links soon expire, here is the seller's store that I bought the fuel filler from. Search the store for Ranger fuel filler. http://stores.ebay.com/ePartPal The part I received fit perfectly and was shipped rapidly. I would definitely buy another one from this seller. Z3CHYD, what type of bolt heads do the first generation Rangers have? Are they just hex heads? I really like Torx head bolts. I have never had one strip as long as I was using a properly fitting bit. Now hex and allen heads are a different story.... __________________ '95 Ranger XLT SC, 4x4, 4.0, 5sp, 3.73 LS, 31x10.50x15 BFG ATs, Cepek DC-1 wheels, Bilsteins, Smittybilt tube bumpers & nerf bars, Sirius radio and a billet grille so far. |
#14 |
Chillicothe, Ohio
'00 Ford Ranger
I have a 00 Ford Ranger that I'm gonna need to get to the fuel tank. After readin to take the bed off is easier I think I might take that route. First though, I have a bed liner in mine, are the bolts ya'll are refering to seen from inside the bed or do ya have to go under to get em out?? Thanks.
#15 |
Moderator
Elite Ranger Omao, Kauai
'93 Ranger XLT 4X4
Bolts are in the bed, just remove your bedliner. (hopefully, it's not a sprayed in type!)
__________________ Bill Collins 93 Ranger XLT 4X4 "Beauty is only sheet metal deep." |
#16 |
Chillicothe, Ohio
'00 Ford Ranger
Alright thank ya. Nah its the bolted down kind. I could lift it a lil to see a few bolt heads but didnt wanna take it apart to find out that wasnt them. Welp guess I got work to do...thanks again.
#17 |
Charlotte, NC
'93 Ranger Ext. Cab
Are you having to remove the fuel tank or just replace the filler neck?
#18 |
Chillicothe, Ohio
'00 Ford Ranger
I actually took the tank off by droppin it a cpl months back and we know easy it is to re position it from underneath. Well I think I may of messed up the gas guage and I hope that maybe working from the top it will be easier to reposition everything. That and when I was in there before some of the hoses looked questionable..so gonna replace those too.
#19 |
Salem CT
2000 Ranger XLT
Just a heads up for those who havent removed the bed before. They are pretty light. Two people can lift it off no problem.
__________________ Join the Resistance
#20 |
Colmar, Pa
1993 Ranger 2.3L/2wd/5spd
The worst part is fighting the rusted t-55 torx head bed mounting bolts. Besides that it's a 20min job.
| Thread Tools | |
