Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Ranger bed removal.
Reply
Thread Tools
Old 09-30-2009, 08:57 PM   #21
Phat_kaw
Chillicothe, Ohio
'00 Ford Ranger
Vehicle Specs
OK once u get to the gas tank there are hoses/lines goin into the tank, how do you disconnect them safely?? I tried before but couldnt get them to come apart which being on my back with 2 inches to work didnt help matters.
Phat_kaw is offline   Reply With Quote
Old 01-15-2012, 11:02 AM   #22
christopherrobin
Winchester, CA
94 Ford Ranger
Vehicle Specs
got my 94 Ranger smogged and passed everything but fuel evap test any ideas? getttin ready to pull the bed and take a look but not sure what im looking for exactly
any help would be greatly appreciated
thnks
christopherrobin is offline   Reply With Quote
Old 01-15-2012, 11:13 AM   #23
Tbars4
Offroad Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
...click the link in post #12 of this thread..
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 01-15-2012, 11:14 AM   #24
corkey
Elite Canuck, Eh ??
In the Great White North where winter never seems to end ,Ontario,, still ice fishing,,
corkey's Avatar
96xl,99xls,old Rangers
Vehicle Specs
i just put a big long power bar on my bolts, and snapped them off, the time spent messing with and having a tough time with them is offset by the cost of a couple of bolts that won't undo, and some of the clips that hold them on,
some came out, some broke,, ,,
__________________
Log Roller,, Fox Coilovers 35's and others, ,
Truck of the month
Ranger Of Danger,,,project truck,
also look for Blues Traveller Elite registry, ,
corkey is online now   Reply With Quote
Old 02-17-2012, 09:25 PM   #25
top4874
Huntsville,AL
97&92 Ranger, 95 Aerostar
Vehicle Specs
Very useful information guys.
I will be removing my bed to replace my filler hose but the bed in my truck is spray in. Any tips on what I can do to make removal easier?
Thanks!
top4874 is offline   Reply With Quote
Old 02-17-2012, 11:02 PM   #26
JetskiMark
Near Los Angeles California
'95 Ranger 4x4 4.0 manual
Vehicle Specs
Welcome to the forum. (Like I'm such an active member.)
I would thoroughly cut the bed liner material out from around the washers. You should also remove all of the material from the inside of the Torx head. You want the bit to fully seat into the bolt. You should also spray penetrating oil on the bolt threads several times at least a half an hour before you break the bolts loose.
I recently did another one and I followed the same method that I posted earlier with the exception that I lifted the bed up with my shoulders and put the 4x4 piece in by myself. The bed is surprisingly light when just one side is lifted.
Put the rear axle on jack stands and remove the left rear wheel.
Remove the gas cap and the three small screws that hold the filler to the bed.
Remove the three bolts on the drivers side of the bed with a t-55 Torx bit.
Loosen the other three so that there is about a half of an inch between the head and the bed.
Lift the side of the bed and place a piece of 4x4 on the frame rail to hold the bed up.
I also removed the inner splash guard.
Remove the hose clamp holding the filler to the tank. I used a 1/4" drive 5/16" socket and a ratchet. The clamp is molded into the OEM hose, loosen it thoroughly. The hardest part was pulling the crusty hose off of the tank.
Use anti-seize or grease on the bolts to make future removal easier.
Good luck and be safe.
Thanks!
__________________
'95 Ranger XLT SC, 4x4, 4.0, 5sp, 3.73 LS, 31x10.50x15 BFG ATs, Cepek DC-1 wheels, Bilsteins, Smittybilt tube bumpers & nerf bars, Sirius radio and a billet grille so far.
JetskiMark is offline   Reply With Quote
Old 02-18-2012, 05:00 PM   #27
top4874
Huntsville,AL
Vehicle Specs
Getting the bolts out was much easier than I thought it would be. I took a utility knife and cut around the blot heads and peeled the linex off. Then the bolts came right out with some elbow grease.
I started out trying to just raise one side of the bed, but there was no way I could get the hose off. So I had a friend come over and we picked the bed up and turned it 45* and I was able to get right to everything. (note to self, remember this if the fuel pump ever goes out). Scored the old tube and it came right off.
Now the hard part started. Getting the new tube on was much to difficult to do from underneath or the side. You really need to get over the opening to get the new tube on as it is a tight fit.
All things considered it was much easier than I thought. If you have a friend to help you shift the bed it will take an hour tops to change the filler tube.
Thanks for the help! I am about to start fixing up a 92 Ranger I bought from work, So I will be browsing here a lot.
Old 02-18-2012, 05:34 PM   #28
FORD SUV GUY
VERMONT
2000 FORD EXPLORER
Vehicle Specs
I both removed my bed at one time and replaced the filler neck on my "98" ranger. I removed the bed to gain access to my fuel pump assembly becasuse in Vermont w/all the salt n RUST you dont just "drop" your tank. Often times here dropping the tank means all new straps and possibly even skid plates, if you care about skid plates anyway.(seems most here do not) As far as my filler neck I neither removed or loosend my bed to gain access. I simply removed the left rear wheel n had all the access I needed? I do not remember it being very difficult either, EVEN WITH all the rusty bolts/clamps. Also I got my filler neck from a scrape yard in good condition for arnd $40. To protect it I painted mine w/POR15 'rust preventive paint"(AWESOME STUFF and can be applied OVER rust)and coated it w/self ething primer. Workd great. The neck takes ALOT of abuse from the elements do to its location..
FORD SUV GUY is offline   Reply With Quote
Old 10-28-2012, 10:55 AM   #29
Dirkb
Huntsville
Vehicle Specs
Hi, I'm new here and my first reply.
I have a 1998 Mazda b2500 sx with the rear spring bracket and hangers rusted away including the Frame. I took the box off and broke 3 of the torx bolts even though I spent a week lubricating the bolts. Good thing I took the box off because the filler tube was badly rusted. That brings me to my question I noticed the bolts are different lengths. where do the shorter bolts go?
Dirkb is offline   Reply With Quote
Old 10-28-2012, 03:32 PM   #30
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
..Let me know if this thread is helpful in answering your question..
http://www.explorerforum.com/forums/...&highlight=bed
__________________
Old 10-29-2012, 01:03 PM   #31
Dirkb
Huntsville
Vehicle Specs
Smile
Thanks Tbar, that's the info I needed
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
