| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
Dallas, TX
1997 Explorer XLT
FORD Transmission DTC - Diagnostic Trouble Codes. OBDII P0700-P0790.
I have a 5R55E transmission, but these may apply to other Ford transmissions.
I hope these are helpful. Ford OBDII Diagnostic Trouble Codes - P0700-P0799 - Transmission P0700 Transmission Control System Malfunction P0701 Transmission Control System Range/Performance P0702 Transmission Control System Electrical P0703 Torque Converter/Brake Switch B Circuit Malfunction P0704 Clutch Switch Input Circuit Malfunction P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input) P0706 Transmission Range Sensor Circuit Range/Performance P0707 Transmission Range Sensor Circuit Low Input P0708 Transmission Range Sensor Circuit High Input P0709 Transmission Range Sensor Circuit Intermittent P0710 Transmission Fluid Temperature Sensor Circuit Malfunction P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance P0712 Transmission Fluid Temperature Sensor Circuit Low Input P0713 Transmission Fluid Temperature Sensor Circuit High Input P0714 Transmission Fluid Temperature Sensor Circuit Intermittent P0715 Input/Turbine Speed Sensor Circuit Malfunction P0716 Input/Turbine Speed Sensor Circuit Range/Performance P0717 Input/Turbine Speed Sensor Circuit No Signal P0718 Input/Turbine Speed Sensor Circuit Intermittent P0719 Torque Converter/Brake Switch B Circuit Low P0720 Output Speed Sensor Circuit Malfunction P0721 Output Speed Sensor Range/Performance P0722 Output Speed Sensor No Signal P0723 Output Speed Sensor Intermittent P0724 Torque Converter/Brake Switch B Circuit High P0725 Engine Speed input Circuit Malfunction P0726 Engine Speed Input Circuit Range/Performance P0727 Engine Speed Input Circuit No Signal P0728 Engine Speed Input Circuit Intermittent P0730 Incorrect Gear Ratio P0731 Gear I Incorrect ratio P0732 Gear 2 Incorrect ratio P0733 Gear 3 Incorrect ratio P0734 Gear 4 Incorrect ratio P0735 Gear 5 Incorrect ratio P0736 Reverse incorrect gear ratio P0740 Torque Converter Clutch Circuit Malfunction P0741 Torque Converter Clutch Circuit Performance or Stuck Off P0742 Torque Converter Clutch Circuit Stock On P0743 Torque Converter Clutch Circuit Electrical P0744 Torque Converter Clutch Circuit Intermittent P0745 Pressure Control Solenoid Malfunction P0746 Pressure Control Solenoid Performance or Stuck Off P0747 Pressure Control Solenoid Stuck On P0748 Pressure Control Solenoid Electrical P0749 Pressure Control Solenoid Intermittent P0750 Shift Solenoid A Malfunction P0751 Shift Solenoid A Performance or Stuck Off P0752 Shift Solenoid A Stuck On P0753 Shift Solenoid A Electrical P0754 Shift Solenoid A Intermittent P0755 Shift Solenoid B Malfunction P0756 Shift Solenoid B Performance or Stock Off P0757 Shift Solenoid B Stuck On P0758 Shift Solenoid B Electrical P0759 Shift Solenoid B Intermittent P0760 Shift Solenoid C Malfunction P0761 Shift Solenoid C Performance or Stuck Off P0762 Shift Solenoid C Stuck On P0763 Shift Solenoid C Electrical P0764 Shift Solenoid C Intermittent P0765 Shift Solenoid D Malfunction P0766 Shift Solenoid D Performance or Stuck Off P0767 Shift Solenoid D Stuck On P0768 Shift Solenoid D Electrical P0769 Shift Solenoid D Intermittent P0770 Shift Solenoid E Malfunction P0771 Shift Solenoid E Performance or Stuck Off P0772 Shift Solenoid E Stuck On P0773 Shift Solenoid E Electrical P0774 Shift Solenoid E Intermittent P0780 Shift Malfunction P0781 1-2 Shift Malfunction P0782 2-3 Shift Malfunction P0783 3-4 Shift Malfunction P0784 4-5 Shift Malfunction P0785 Shift/Timing Solenoid Malfunction P0786 Shift/Timing Solenoid Range/Performance P0787 Shift/Timing Solenoid Low P0788 Shift/Timing Solenoid High P0789 Shift/Timing Solenoid Intermittent P0790 Normal/Performance Switch Circuit Malfunction __________________ 1997 Explorer XLT-2 Wheel Drive 6 Cyl. 4.0L SOHC -5R55E+OD Transmission |
#2 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Thanks for making this thread! I've added OBDII P0700-P0790 to the title, and made it a sticky thread.
#3 |
Dallas, TX
1997 Explorer XLT
__________________ 1997 Explorer XLT-2 Wheel Drive 6 Cyl. 4.0L SOHC -5R55E+OD Transmission Last edited by dallasmef; 03-11-2009 at 07:54 AM. |
#4 |
Cincinnati, Ohio
94 XLT & 98 XLT
Will an Actron CP9175 read these codes?
Vehicle 98 Explorer 4 Wheel Drive, 6 Cyl. 4.0L SOHC -5R55E+OD Transmission It has a flashing O/D light but the only code the Actron CP9175 found was p0430 |
#5 |
Brooklyn, NY
Welcome to this forum! After reading the information from your link, I would say that this scanner can't read these codes. You will have to go with one of the higher models.
#6 |
alaska
can you recommend a scanner for the DIY. I really don't want to spend the 1.5k on the tool truck for a scanner i will use 3 times a year.
#7 |
hemet ca.
1999 6cyl 4wd
i have a 99 explorer that wont budge its an automatic and when i move the shifter nothing happens no noise no jolt no rpm change and above all no trouble codes does anyone have any ideas i would appreciate any input thanks
#8 |
Evansville, IN
'97 Sport 4 w/d
Scan shows all 4 codes P0750, P0755, P0760, P0765
I started my 97 4.0 (2000 engine) 4 WD after letting it sit for a week in the cold,
the O/D off light started flashing and the check engine light came on. I had the codes pulled at AZ and all 4 codes came up. I can't imagine that 4 separate solenoids failed at once. Is it likely an electrical issue? Since it started the trans doesn't shift out of 3rd gear unless I manually drop it to lower gears. And it never goes into OD. Any help would be greatly appreciated. Thanks, Bob |
#9 |
Tumbler Ridge, B.C canada
2001 Sport Trac 4x4
DTC for 5r55e trans
Thanks to dallasmef for posting DTC for trans. My daughter's '01 Sport Trac is experiencing some trans issues. DTC 768. Have obd tool, Just did not know what code meant. Thanks.
#10 |
Christchurch, NZ
2004 4.0 XLT
This is just a thought - I am toying with the idea of building a computer based enternainment system for my explorer, hooking up GPS into it for map display, having mobile internet etc etc.
Many of the ready - built programs you can get to do this are able to hook into the on-board vehicle diagnostics presumably via the ODBII port. I have been wondering if I could take an input from this to provide a set of 'virtual' gauges for engine temp, RPM, road speed including transmission fluid temp and pressure. Is it likely that these values can be read straight off the vehicles diagnostics if I can interface to them? Might not turn out to be be practical but I do like the idea! Any ODBII experts lurking on the forum? |
#11 |
Brooklyn, NY
Check WWW.Scanguage.Com.
#12 |
Evansville, IN
'97 Sport 4 w/d
loose connector
I was right! (go figure) The connector had simply fallen loose. I replaced it, cleared the computer and it's been ok ever since!
#13 |
Brooklyn, NY
Thanks for letting us know. Sometimes multiple codes are caused by a bad connection on the bulkhead connector.
| Thread Tools | |
