Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Ham Radio - CB - Trail Communications
Notices
Ham Radio - CB - Trail Communications I have found that fourwheeling and ham radio go hand in hand. Post any questions or comments about the great hobby of amateur radio here. Of course CB'ers are welcome also. Ray, AE6H and Joe, N1LVN both moderate this forum.
2nd Gen Explorer install of Yaesu 7800
Reply
Thread Tools
Old 03-11-2009, 08:35 AM   #1
MikeCMP
OH
2001 Explorer Limited
Vehicle Specs
(Original Poster)
Hello,
Finally, after a long wait, and a long while after my original getting started thread, I have my radio installed in my truck. This took me a while, partially, b/c I totalled my last truck, and partially due to the fact that my daughter was born two weeks early. Now that I have her home I decided to finish up my install, and take some pictures.
I managed to install this without drilling any holes in my new truck, except in the little compartment where the radio sits. In there is where the jack, key less entry system, and air ride suspension systems hang out, and there happened to be a nice metal bracket I could mount the radio to, after using one available hole and drilling only one more.
Wires ran out an existing hole at the bottom of the plastic under the carpet, and under the plastic trim all the way to the front of the vehicle. The power cables go up to the battery through the shift lever grommet, and the head cable goes under the dash, and behind the console through a small rubber "gasket" between the console and dash.
the head is stuck on with double sided trim tape, as is the microphone mount. The external speaker is also help on with double sided tape, however, I am going to get a nice strong wire, and run it down through the trim, in case I am in an accident, so that the speaker does not become a projectile. I figure if I get some wire, I can make a nice connection to the metal bracket the radio is mounted on and tie the speaker down.
Running the wires took me about an hour and a half, finishing up the mounting took another hour or so.
On to the pics.
MikeCMP is offline   Reply With Quote
Old 03-11-2009, 08:47 AM   #2
rizzjc
Scubajoe - Radio Mod
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
Very nice! I need to get a removable head unit and been done with it. So much cleaner to install in a gen 2. What's the ON/OFF switch for near your jack? Can you still open your rear window with the antenna there?
__________________
Joe, N1LVN
'97 XLT AWD V8 STOCK
Amsoil Synthetics throughout. Amsoil Ea air filter. Bilsteins. Scanguage.
Search ExplorerForum
rizzjc is offline   Reply With Quote
Old 03-11-2009, 08:56 AM   #3
MikeCMP
OH
Vehicle Specs
(Original Poster)
Quote:
The ON/OFF switch is for the air suspension on this model. As far as opening the window, that is a little annoying actually. The lip mount was originally going to go on the part of the hatch that was above the tail lights in the other truck, thus avoiding any trouble, but on this truck there is plastic trim in the way. I don't remember my old truck having that, regardless, if you were to just open the glass, it would hit the antenna, but the antenna is a fold down, so, you fold it, and can open the glass no problem.
Then antenna is a comet SSB5NMO dual band in case you are interested.
Mike
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
