Sylvain
- March 11, 2009
- Crozon, Brittany, France
- Not mine, my father's
Hi there,
I registered here, though I am not a Ford Explorer addict myself, but my father is.
We live in France, and it's not quite easy to find spares or even the right information for the right part...
That's why my dad registered here. But since he is not much of a technical translator, he asked me to come here and translate his current issue with a relay. So here is his original request, translation is in blue
"Bonjour à tous
je découvre ce forum où je viens partager mon attachement au modéle 1995 Ford Explorer USA
malgré les quelques avatars subits ces derniers temps.
Hello all,
I have just discovered this forum where I will be happy to share my attachment to the '95 US Ford Explorer
Pour l'instant, j'ai un problème de positionnement des relais dans la boîte à fusibles du compartiment moteur:
Compartiment moteur
Boîte à fusibles
(Positionné à droite côté passager derrière la batterie)
For now, I have an issue with the positioning of the electric shifts in the fuse engine compartment fuse box (they are positioned behind the battery on the passenger's side)
? HEATER BLOWER RELAY 28
A/C WOT RELAY 27 ?
? ABS ELECT RELAY 26
FUEL PUMP RELAY 25 ?
? ABS HYDR CONTROL RELAY 24
E.E.C. POWER RELAY 23 ?
Fusibles de 1 à 22
Fuses 1 to 22
Relay Ford FDAB
14B1926AA
2K24 1655 1 ITEM
2K24 1657 1 ITEM
2K24 1658 3 ITEM
2K24 1701 1 ITEM
Merci d’avance à celui qui saura remettre la bonne référence relais
en regard de son emplacement dans le haut de la boîte
Alain
I would be quite grateful to the one who might help me match referrences and positions in the box. Thanks in advance
Alain"
There you are, I hope somebody'll be able to help him with his issue, for it's really a pity to have the Explorer sitting in front of the house for the time being...
Cheers to all of you, and enjoy your rides
"Bonjour à tous
Hello all,
Compartiment moteur
Boîte à fusibles
A/C WOT RELAY 27 ?
Fusibles de 1 à 22
Fuses 1 to 22
Relay Ford FDAB
14B1926AA
2K24 1655 1 ITEM
2K24 1657 1 ITEM
2K24 1658 3 ITEM
2K24 1701 1 ITEM
Alain
Alain"
