Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
hi jack lift
Reply
Thread Tools
Old 03-12-2009, 10:08 AM   #1
jeremyc653
st pete fl
2001 ford sport trac
Vehicle Specs
(Original Poster)
hi jack lift
the idea of a high jack lift is to lift the truck up and then push it and let the jack fall correct? i was wondering if this would damage anything on the truck
jeremyc653 is offline   Reply With Quote
Old 03-12-2009, 10:38 AM   #2
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
That one of the many things you can do with it.. But.. you can damage the truck doing that if the jack doesn't fall just right...
Here is a list of the safer things (where you stay in control of the jack). All still carry quite a bit of risk.. the high lift is a versitile but can be dangerous if you don't think ahead.. things to use it for are...
  • Break the bead from a tire (put base on tire, use weight of truck to break the bead)
  • come-along/winch. If you put a chain at each end you can pull your truck, abiet slowly
  • lift the truck so you can stack rocks under a tire
  • lift the truck so you can do a minor suspension repair.. i.e. replace a spring that popped out and put a chain on as a limiting strap
  • use the highlift handle as a cheater bar
there are many more uses.. and Yes I've used the lift/push method to get the truck move when I got it stuck but its not under control at that point and can be dangerous to you, or the trucks sheetmetal.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 03-12-2009, 04:46 PM   #3
jeremyc653
st pete fl
Vehicle Specs
(Original Poster)
thanks what did you mean use it as a winch ?
Old 03-12-2009, 05:07 PM   #4
jutgin
Chattanooga, TN
2002 ST
Vehicle Specs
Quote:
The hi lift acts as a ratchet, if you look at one the plate part that lifts actaully climbs the stand, so if your hooked the truck and the lift plate you can ratchet the handle and it will start to pull the truck forward like a winch.
Maybe not the best explanation, but hope it helped to picture it.
__________________
2002 Ford Explorer Sport Trac 4x4
Body lift / 33's
jutgin is offline   Reply With Quote
Old 03-12-2009, 05:13 PM   #5
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
LOL yes it can damage the truck, but if you do it right and enough times at least the truck will be back on the trail!
Have done this many times, it is DANGEROUS
anything HI lift is dangerous, so use common sense and caution
also GLOVES
I almost lost my pinky due to hi lift slipping, gloves would have helped a great deal!!!
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 03-12-2009, 05:45 PM   #6
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
Hi-Lift = danger Will Robinson, danGER!
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 03-13-2009, 07:49 AM   #7
jeremyc653
st pete fl
Vehicle Specs
(Original Poster)
thanks alot
Old 03-13-2009, 07:55 AM   #8
John_Rock
Moderator In Memoriam
Houston, TX
John_Rock's Avatar
2001 Sexy Sport Trac 4x4
Vehicle Specs
Yes, they can be dangerous. One of my Texas Demon4x4 buddies had his truck jacked up using his hi-lift on his rock sliders. So he had to have a door open to get the jack underneath the slider. He was changing from his offroad tires to his street tires. A procedure he had done many times. But this time the hi-lift jack slid on the slider(go figure) and pinned one of his fingers against his door. I had to grab his keys and run around to the other side to start his truck and get it moved to get his finger released from the hi-lift death grip.
__________________
John_Rock - Mugshot - Click Here For info on my 2001 Sport Trac 4x4
- 2000 Explorer Limited AWD, 5.0L v8; 4.10 gears, KKM True Rev filter, B&M Tranny Super Cooler, Aux. Tranny Filter, Autometer Tranny & Water temp gauges.
Demon4x4.com
John_Rock is offline   Reply With Quote
Old 03-13-2009, 09:47 AM   #9
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
was it his pinky?
if so I think they have a thing for pinkys
I was wheeling in the snow
got in over our heads, LOL
I had the truck jacked way up to dig out, and I was trying to jack it up one more notch, well the jack slipped down and the handle snagged my pinky when I tried to lift my hand out of there with lightning speed
nothing like 3500# of bronco slamming into your frozen pinky
snow looked like a murder scene, my GF at the time was like, "You okay?"
LOL I am like "oh this little thing? doesnt even hurt!" LOL
We are now married and I have a 1/4" thick scar on my pinky and limited mobility, it was to the bone
__________________
Old 03-15-2009, 10:08 AM   #10
jeremyc653
st pete fl
Vehicle Specs
(Original Poster)
i guess i should invest into a winch rather then a hi jack lift then huh
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
