Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Where is the oil pressure sending unit on my 99 explorer 4.0L EFI engine?
Reply
Thread Tools
Old 03-18-2009, 03:19 PM   #1
explorerthisone
Vancouver
99 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
First of all, I have a 1999 Ford Explorer with a 4.0L EFI OHV engine, XLS model.
Well, my oil pressure on my stock gauge is gone to zero. I am hoping that it is the oil pressure sending unit that is malfunctioning. Well, I've done my research. It should be located right under the power steering pump on the driver side. I have a mechanical oil pressure tester, and a new sending unit. I also have my haynes manual, but the picture given is so close up that it doesn't really help. I tried looking for it for about an hour, but I just can't seem to locate it. Once I know where it is, this should be a simple job.
Can anyone help me with this? I want to test to make sure that it is the oil pressure sending unit before I take it to the mechanics to have the oil pump replaced. (Fingers crossed!!!) If someone has the same engine as mine, and know where your oil pressure sensor is located, could you perhaps take a picture of it and post it (both far away and close up shots)? Or could someone with a parts diagram also post this information? I would be very thankful. Thanks.
explorerthisone is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-18-2009, 03:25 PM   #2
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Quoted: 32 Post(s)
Look under the truck toward the driver side. Look at the front of the engine. Look for a sensor with one wire coming off it on a spur off the engine, it is hard to miss.
96eb96 is online now   Reply With Quote
Old 03-18-2009, 08:07 PM   #3
desertbum8
Oceanside, CA
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
If you look through the driver side wheel-well you can actually see the sensor pretty easily. It's a round sensor with a wire coming out near the bottom of the engine. Make sure you get the right tool to take it out or you can damage the threading.
desertbum8 is offline   Reply With Quote
Old 03-22-2009, 02:17 PM   #4
explorerthisone
Vancouver
99 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
That's the thing... I knew all that information... but I don't know why, I just cannot seem to find it. I bet I am going to hit my head in unbelief when I see it because it was right in front of my nose the entire time. Anyways, if someone could take a picture of the engine pointing to where it in on this engine, it would really help out. Posting such a picture would really be good too because it seems like there alot of people with the same issue as me out there. There is a really good thread out there for a SOHC engine, but none for a OHV EFI engine. Anyways, thanks again.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
