| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
1997 XLT V8
Vacuum Leak for Dummies
Hi,
I am in need of information on how to locate a vacuum leak. I've looked everywhere and can't find the "How to find a vacuum leak for dummies" version. Please help! I have a 1997 Ford Explorer XLT 5.0 V8. I am retrieving codes P0171 & P0174. (Lean banks 1 & 2). I have already replaced the MAF sensor. Codes came back. 1.) How many vacuum hoses are there? 2.) Where are they? 3.) How do I check them for leaks? (I read somewhere something about ether?) If someone can point me in the right direction. (Diagrams & actual photos would be great), I would seriously appreciate it. Thank you. |
#2 |
Pa.
1997 Mercury Mountaineer
Well there are many hoses in different places. You can use a propane torch with a length of rubber hose on the end. Turn the propane on and with the engine running aim the end of the hose at the vacuum lines and if the engine idle rises you have found your leak. Sometimes it might be a gasket leaking as well so you'll want to run the propane around the intake manifold too. I believe you might have to unhook the Idle Air Control (IAC) valve when doing this or you might not get a change in idle but I might be wrong. Anyone else chime in?
__________________ ~Jamie~ |
#3 |
mooo
1997 XLT SC'd 5.0/331
call a shop and ask if they have an evap smoke machine, should find a leak if there is one in about 45min tops.
#4 |
Glastonbury, Connecticut
97 Sport
Those codes are usually caused by leaking intake manifold gaskets. You can also use wd-40 to test for leaks, simply spray it around the suspected area and listen for a change in idle speed. When checking the intake manifold gaskets, make sure the engine is cold. The gaskets expand with the engine heat and can sometimes seal up the leak making it nearly impossible to find. You don't have to disconnect the IAC. good luck
#5 |
1997 XLT V8
Is there a vacuum hose diagram available for my truck? I've never had to mess with them so I'm not sure where to spray or look. Thanks for your time, it's really appreciated.
| Thread Tools | |
