#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Performance Lighting
Notices
Performance Lighting Aftermarket lighting. Driving lights, fog lights, rock lights, HID, halogen. Make your Ford Explorer light up the night!!
Gauge Cluster LED Conversion V2 (PICS)
Reply
Thread Tools
Old 03-21-2009, 01:08 PM   #1
MustangP51
Connecticut
2009 Limited V8
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
This is my second and hopefully much more helpful writeup on converting the 95-01 gauge cluster to LEDs. I have tried 3 different types of 12v wedge based 194 replacements and I have finally found the one that puts out enough light and lights up the cluster evenly.
Here were my candidates.
From Left to Right: Inverted Wedge LED, Refractor LED, SMD LEDs
The Results
Inverted Wedge LED: Even Light output, but not bright enough
Refractor LED: Horribly Uneven light output, Short Lifespan (they started blowing on me)
SMD (Surface Mount Diode): Even Light output and very bright (brighter the the 194LL Bulbs)
Getting to the cluster:
Step 1
Remove the Radio
Step 2
Remove the 2 screws (circled in red)
Disconnect the 5 wiring harness behind the bezel (circled in blue)
Step 3
Remove the 4 screws holding the plastic panel in place. (2 are hidden under the hood release) Then pull back on the top of the panel ( it is held in by clips)
Step 4
Remove the 3 bolts holding the metal shield in place
Step 5
Remove the 2 screws at the bottom of the gauge bezel (note the wiring harness locations circled in blue)
Step 6
Remove the 3 screws at the top of the gauge bezel
Step 7
Pull out the bezel enough to disconnect the 3 wiring harnesses. (Headlight Switch, Dimmer, and Rear Parking Assist) Then Remove the bezel. (Shifter must be in 1st gear)
Step 8
Remove the 4 screws holding in the Gauge Cluster
Step 9
Tilt the Cluster back and remove the Shift Indicator from the cluster, there are 2 plastic tabs that must be held on each side to remove the indicator.
Disconnect the 3 wiring harness from behind the cluster, then remove the Cluster
Now Hopefully You are holding your Instrument Cluster and can go on to the fun part.
Remove the 6 back light bulbs from the cluster. (Circled in Red)
( I also highly recommend you also remove the THEFT light LED so you don't risk blowing it like I did when I was trying to figure out how to bench test the cluster)
The PC board on the back of the cluster is flexible so you can carefully pull the contacts where the wiring harnesses attach out of the sockets so you can attach alligator clips to bench test.
(The white wires are the - and the RED and GREEN are +)
Here are the LEDs in the sockets. ( I used a bit of hot glue to make sure they didn't come out)
I apologize for not having a night shot of the final product, but the camera I have with me is an absolute noise box and takes terrible low light pics. When I get back my Canon ill get some pics.
Good Luck!
MustangP51 is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-21-2009, 01:41 PM   #2
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
vroomzoomboom's Avatar
98 supercharged 347 sport
Vehicle Specs
Quoted: 326 Post(s)
once again ryan, i will bow down!
__________________
Stroke Me, Blow Me. 347 Stroker + M112 Eaton Supercharger = Evil
roll pan build for 1st and 2nd gen explorers
door switch LED convention
vroomzoomboom is offline   Reply With Quote
Old 03-21-2009, 02:01 PM   #3
BrianDye
I'll have another...
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 58 Post(s)
hey man, great write up, ive been wanting to order LED's to do that, and im replacing EVERY dash light, even the ac controls' lights, all the check so and so lights, blinker arrows, all that, and ive been wondering what LED's i should get (the 194's) where did you get those?
eBay?
__________________
06 XLT
Debadged in back, removed pin stripe, tinted fogs, LED conversion, black headlights w/Morimoto Mini retro, xB LED Halos, black bentley style grille, 18" Fi BTL, Pioneer X4700BS, & plenty more
Check out my for sale posts here. 4th Gen Headlights, Grill, Flip Key, & H13 HID Kit.
BrianDye is offline   Reply With Quote
Old 03-21-2009, 02:40 PM   #4
millerman23
Shawano WI
99 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
As will I .
Your post on replacing all the dome lights with leds helped me a lot. You sir I will say are a LED MASTER
__________________
99' Silver 4dr 4.0 sohc "x" 31X10.5R15 Mud Terrains, BWM, upgraded tunes.
No one ever said that life is easy.
millerman23 is offline   Reply With Quote
Old 03-21-2009, 03:13 PM   #5
MustangP51
Connecticut
2009 Limited V8
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Haha thank you tim and miller.
Brian I would leave the indicator lights as bulbs. If you put LEDs in then the system will think the bulb has blown and if an indicator like the Airbag light comes on then the system will make the chime sound when the light comes on. They are also not the same 194 bulbs as the back lights.
Yes I bought them off of ebay
Search
"194 SMD LED"
Old 03-21-2009, 03:21 PM   #6
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
Another amazing write up
techieman33 is offline   Reply With Quote
Old 03-21-2009, 03:34 PM   #7
BogFather
Lower Sackville, Nova Scotia
97 Sport, 91 Samurai
Vehicle Specs
Quoted: 1 Post(s)
Are these the same only with 4 leds instead of the 5 ??
http://cgi.ebay.ca/Super-Blue-T10-SM...QQcmdZViewItem
__________________
97 Xplorer Sport, Custom Front Bumper, TT, Rear Shackle Lift, 4 Roof Lights, 4dr Tortion Bars, FatBobs Garage Tortion Keys & 4Door leafs With Full Length AAL SOON
91 Samurai, Snorkeled, Removable Doors, Ranger Shocks On Rear, Explorer Shocks On Front, Cb, 4FT Whip Antenna, Custom Front Bumper/Bush Guard, Relocated & Remounted Spare Tire & Ready To Grow Up..........
BogFather is offline   Reply With Quote
Old 03-21-2009, 03:36 PM   #8
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Quoted: 3 Post(s)
I found a good LED tool for you Ryan, it's an online calculator that allows you to convert millicandelas (or candelas) and lumens for an LED
http://led.linear1.org/lumen.wiz
It's a good way for anyone doing a conversion to compare output specs of different LED's
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
fixxxer is offline   Reply With Quote
Old 03-21-2009, 03:47 PM   #9
MustangP51
Connecticut
2009 Limited V8
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
The only problem with those is that they wont light up the cluster evenly. You will have hot spots where the LEDs are but the light will fade out the farther it gets from the LED. The reason the 3rd ones I used worked so well was because they have 4 LEDs that are angled horizontally to spread out the light.
Fixxxer that is a nice find, but look at the last sentence in the tools description
"Beware especially of wide-angle LEDs, which will probably be distorted the most by this calculation".
That tool would be perfect if you are working with standard 3mm 5mm or 10mm LEDs
Old 03-21-2009, 04:45 PM   #10
BogFather
Vehicle Specs
Quoted: 1 Post(s)
gotcha
__________________
Old 03-21-2009, 04:49 PM   #11
BogFather
Vehicle Specs
Quoted: 1 Post(s)
so these ones then there bud :
http://cgi.ebay.ca/2-HiPower-SMD-BLU...QQcmdZViewItem
__________________
Old 03-21-2009, 05:11 PM   #12
MustangP51
Connecticut
2009 Limited V8
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Those are the ones, I'm very interested to see how the blue will look.
Old 03-21-2009, 05:28 PM   #13
BogFather
Vehicle Specs
Quoted: 1 Post(s)
When i get them and get them installed i'll be sure to post some pics for ya . Did you get pics of before and after with yours in ??
__________________
Old 03-21-2009, 05:32 PM   #14
MustangP51
Connecticut
2009 Limited V8
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I had one from before, but It really doesn't show what it looks like in person. In the picture everything was lit up evenly (far from the way it really looked, there were dark patches everywhere)
I'm hoping I can get a picture tonight of how it looks now.
Please do post pics when your done.
Old 03-21-2009, 05:33 PM   #15
BogFather
Vehicle Specs
Quoted: 1 Post(s)
yeah i will deffinately post some up bud
__________________
Old 03-21-2009, 06:46 PM   #16
BrianDye
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 58 Post(s)
Search
"194 SMD LED"
thanks man, i found them on eBay, about 4.50$ a pair,
but I already replaced my Check Engine light with an LED, and it seems fine, if anything ill do it, and let you guys know how it goes, thanks for the info
__________________
06 XLT
Old 03-24-2009, 04:32 AM   #17
ornithology
Vancouver, BC
'03 X Sport2dr 4.0 V6 XLT
Vehicle Specs
Quoted: 0 Post(s)
I just bought a bunch of blue 5mm 9,000MCD leds. Do you think if I jam several into each socket it will work? But then again...there is the issue with the green film right? I have an 03 sport and that would suck if the blue turns out to be a blueish green because of the film...
__________________
2003 Volkswagon Jetta GLS
ornithology is offline   Reply With Quote
Old 03-24-2009, 09:55 AM   #18
MustangP51
Connecticut
2009 Limited V8
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
As much as I like making custom LED units, this is one application where the pre made 194 LED is better then anything someone could make. There is barely enough room for the SMD 194 LEDs in the cluster so no you wouldn't have enough room to put more then 3 5mm LEDs in each socket.
Old 03-24-2009, 05:21 PM   #19
ornithology
Vancouver, BC
Vehicle Specs
Quoted: 0 Post(s)
hm...
fine.
Order placed for the 5 SMD 194s.
__________________
Old 03-24-2009, 05:22 PM   #20
ornithology
Vancouver, BC
Vehicle Specs
Quoted: 0 Post(s)
Just wondering though, aren't your needles supposed to be red? When you changed your LED color it changed the needle too?? That's awkward cuz in my 03 sport it has flourescent red painted on it..
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
