#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
FM146 Tran's in '91 Explorer
Reply
Thread Tools
Old 03-26-2009, 02:38 PM   #1
djmillett
Boise, Idaho
1994 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I did some checking but didn't find what I was looking for.
I bought a '91 Explorer that was converted to manual with the Mitsubishi FM146 transmission. The previous owner had put a new starter in it which shortly after getting the explorer stopped working. In doing some checking I discovered the flywheel was chewed up.
I picked up a flyweel from the junkyard for a '91 manual Explorer and discovered when I went to buy the new cluch that although it looked to be the same size was different than the flywheel in the explorer.
To make a long story short, I now have a '91 manual flywheel and cluch with a FM146 transmission and I'm trying to find out if this setup will even work and if so what starter works with it?
djmillett is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-26-2009, 03:04 PM   #2
solitary ogre
Surrey, B.C.
'91 explorer, '88 bll
Vehicle Specs
Quoted: 0 Post(s)
when the ring gear on my flywheel got chewed up i bought a new gear from Ford. i hammered off the old gear then i put the flywheel in the deep freeze overnight. in the morning i warmed up the ring gear in the oven at 400 degrees for about 15 to 20 minutes.
i put lock-tite around the flywheel and used welding gloves to handle the ring gear. i set right in place without any persuasion with a waiting hammer. within 2 minutes it had cooled enough that there was no way no how it was coming off. that was 6 years ago and it is still running fine.
solitary ogre is offline   Reply With Quote
Old 03-26-2009, 08:31 PM   #3
djmillett
Boise, Idaho
1994 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I already have a new flywheel. My question is will the flywheel and starter for a stock manual which is the Mazda transmission work or do I need to use the flywheel for the Ranger the Mitsubishi transmission came from.
I didn't realize the transmission in my '91 explorer was not the stock tranny and I bought and installed what would be the stock flywheel and cluch. When I installed the starter it started but the starter would not disengage.
Will the stock starter for a '91 Explorer work with the stock flywheel mounted on the FM146 tranny or do I need to use the Ranger starter and fywheel that the FM146 tanny came from?
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
