Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Oil Gauge going crazy
Reply
Thread Tools
Old 04-01-2009, 06:30 AM   #1
Stace
Saratoga Springs, New York
2000 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Oil Gauge going crazy
Hi I've got a 2000 Exp. 4WD 4L Oil pressure gauge going crazy pinging back and forth hi/lo hi/lo check gauge light came on. If I stop and just idle the check gauge goes oput and the OP needle is normal, step on the gas light on and needle goes nuts. Any thoughts? Has Oil in normal range on dip stick.
Stace is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-01-2009, 06:58 AM   #2
tripplec
Markham, ON Canada
2002 Explorer Sport 2Dr
Vehicle Specs
Quoted: 10 Post(s)
the gauge is really a voltmeter. Any oil pressure over a pre specified pressure (likely 5-10lbs) will set it off and in never varies. The guage sender is likely malfunction. If the engine sound normal (no excessive lifter noise) you're probably ok on pressure. Pickup and new sender and swap it out. You could check the wire contact on it first.
I don't know where its located though.
__________________
2002 Explorer Sport 2Dr, 4x4, 4L SOHC V6
200,000km, Sunroof, Class III Hitch
Stock
Nokian WR SUV P255R70/16 tires - All Weather & Winter Certified DOT snowflake symbol
tripplec is offline   Reply With Quote
Old 02-07-2010, 05:21 PM   #3
Delta Dog
Gulf Coast
Vehicle Specs
Quoted: 1 Post(s)
Mine is doing the same thing......and crazy is an understatement. That needle wants to come outa there!!!!!!! I mean hitting the limiter pin so hard I can hear it over the radio.
I had a new gauge but it was the wrong one so I took it back. The one that looks right (electrical connector) is supposedly for the oil LIGHT according to the NAPA guy. Either way I am gonna go back and get the $7 oil LIGHT sender for my gauge......
__________________
2000 Explorer Eddie Bauer, 5.0, modified shackles, TT, CAI.......RIP
2007 Mountaineer Premier AWD, 4.6L
Delta Dog is offline   Reply With Quote
Old 02-08-2010, 12:47 PM   #4
TheJackal
Mandeville, LA
1999 Explorer XL 2WD
Vehicle Specs
Quoted: 1 Post(s)
that's because as tripplec was saying, the gauge really functions as a light.
It points to the middle of the gauge when pressure rises above a certain point; otherwise, it goes down to zero. It doesn't actually measure anything.
TheJackal is offline   Reply With Quote
Old 02-08-2010, 01:23 PM   #5
Blazepet7
Queens, NYC
99' XLT 5.0
Vehicle Specs
Quoted: 0 Post(s)
The oil pressure sensor is a problem with the 2nd gen trucks mine started to stay pinned at no pressure about a year ago check this out
http://www.explorerforum.com/forums/...d.php?t=210435 do a search for oil pressure sensor there are about 200 different treads on the oil pressure sensor not just for havin no pressure but searching guages etc.. hope it helps
__________________
99' 5.0 V8 XLT-FORD Red, Hella 500 Fogs,Pioneer AVIC D1 Navi, Sony DVD Player,TT/Shackles, AAL, Custom Rack lights, Rancho 5000's, LED Puddles, Custom Front Tow Hooks Many More Mods to Come
Blazepet7 is offline   Reply With Quote
Old 02-08-2010, 01:25 PM   #6
Delta Dog
Gulf Coast
Vehicle Specs
Quoted: 1 Post(s)
Yeah.....when i was at Advanced Auto a few minutes ago they said the oil sending unit for the gauge and light were the same part #. The NAPA guy must have been confused.
$7.99 for the part is cheap but getting to that sucker is hard. I had to have my daughter unhook the connector since I couldn't get my hand in there!! I am sure she will jump for joy when I tell here she has to stick her hand in there 3 more times.
__________________
Old 05-15-2014, 03:21 PM   #7
McNultysGirl
2002 Ford Explorer XLT V8
Vehicle Specs
Quoted: 0 Post(s)
*bump*
My 2002 started just dipping to no pressure and the "check gauges" light comes on. I've checked the oil and it's fine, nothing seems to be overheating. And shutting off the engine seems to reset it.
McNultysGirl is offline   Reply With Quote
Old 05-16-2014, 09:09 AM   #8
1992fordgreen
Inside the Rehabilitation Center
95 SC400 92 SC400 96 Ex
Vehicle Specs
Quoted: 76 Post(s)
Its your oil pressure sender. Fairly easy to replace.
__________________
1996 Ford Explorer EB SOLD 1992 Lexus SC400, 1995 Lexus SC400 SOLD, 1993 Lexus SC400, 1999 Mazda Miata, 1999 Lexus GS300, 2000 Mazda Miata SE, 2001 Toyota Sequoia, 2003 Chevrolet Suburban, 1971 Olds Cutlass SOLD 1992 Ford Explorer XLT SOLD
Quote:
Originally Posted by mattcatledge View Post
Got my 97 for $250; the previous owner thought the tranny was gone but it is actually the transfer case. They were not happy when I put it in 4 low and drove away.
1992fordgreen is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
