Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
A4LD Cooler Line Routing
Reply
Thread Tools
Old 04-09-2009, 02:09 PM   #1
1993Saturn
Redmond, OR
'94 XLT
Vehicle Specs
(Original Poster)
I replaced my A4LD and I don't know if my cooler lines are in the correct locations. I had to cut them off of the old trans because they wouldn't budge when trying to remove them from the old trans. They got a little bent up, so I can't be sure what is what at the cut point.
Which is the out and return on the trans case. Does the out go to the bottom of the trans cooler then the top line goes to the secondary cooler bottom, then back?
__________________
'94 XLT auto--Green, of course
Member of the Crank Window Club
You can make any car run half a million (My '93 Saturn has 510,000 miles)
Change the oil and listen to what it tells you.
1993Saturn is offline   Reply With Quote
Old 04-11-2009, 10:48 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
The lower one is the pressure line, and the upper one is the return line. Check the links in # 52 in my list of useful threads for more information.
BrooklynBay is offline   Reply With Quote
Old 04-12-2009, 03:03 AM   #3
1993Saturn
Redmond, OR
'94 XLT
Vehicle Specs
(Original Poster)
OK! Glad to know. I have been really trying to find the info, but can't seem to get there. Just to be clear, cause terminologies have different interpretations, The Top (upper) is the fitting furthest away from the front of the bell housing and the Bottom (lower) is the fitting closest to the front of the bell housing?
Thank You!
__________________
Old 04-12-2009, 04:32 AM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Page 33 in this link has a diagram for you: http://www.scribd.com/doc/9571098/A4...-Service-Group
Old 04-12-2009, 12:40 PM   #5
1993Saturn
Redmond, OR
'94 XLT
Vehicle Specs
(Original Poster)
OOPS! my previous post ended up before yours. It is supposed to be AFTER!
__________________
Old 04-12-2009, 01:11 PM   #6
Tbars4
Offroad Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
...and BrooklynBay will be the one to answer your question in the other thread...
http://www.explorerforum.com/forums/...d.php?t=241914
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 04-12-2009, 08:31 PM   #7
BrooklynBay
Brooklyn, NY
Vehicle Specs
I've posted a response to that thread.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
