| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Lexington, VA
1999 XLT 4.0
Girlfriend was driving to work, something went boom (not a big boom... her description) and the oil gauge went nuts. No oil leaked out as far as I can see. Car also had the timing chain defect, sounded like a motherf'ing powerstroke diesel. Did my chain snap? If so, am I fornicated? Could it be something else?
If I were to replace the engine, what year(s) should I target for explorers and rangers. I have the "E" engine, as its a 4x4. I'm also a broke ass mothafudger. |
#2 |
missouri
00E.B.,93 xlt 92 xlt
guess it has a 4.0 sohc? if the tensioners went out and it sound like that you are in bad shape but if its a 4.0 ohv maybe not as bad...
__________________ 00 E.B. 4x4 sohc RIP 97 xlt control trac 94 explorer sport 93 xlt explorer 4x4 92 xlt explorer (parts truck) 92 xlt explorer project |
#3 |
Lexington, VA
1999 XLT 4.0
It's defintely the SOHC.
#4 |
Lexington, VA
1999 XLT 4.0
The question remains: What engines should I target? Also, is my engine f*****? I don't remember the difference between interference/non-interference and whether this engine is one, but if the chain snapped, do I have bent valves or other irreperable damage? Is my best course of action to try to get a new engine? If so, what engine should I go for? I'm a broke law student, so that's the primary factor, though I am wary of getting another 90s SOHC engine with the same defect. Was it '01 when they were fixed on exploders? What about Rangers? I've searched and got differing info.
Finally... does anyone know anyone in Southern Virginia (Lexington/Roanoke area) that can fix this for cheap (I know... no chance of this question being answered, but its worth a shot.) |
#5 |
Aylesbury, ENGLAND
'00 North Face
Any SOHC engine from a 4x4 Explorer, Ranger or Mountaineer will fit, but you'll need to use all of your ancillaries, incliding motor mounts. From 2001 the engines had the upgraded tensioners and guides.
Duncan |
#6 | |
Modesto, Ca
'03 Sport Trac XLT~98 XLT
Quote:
Sorry to inform you of the bad news and good luck in finding a new engine. |
#7 |
Roxana, Illinois
2000
Many have stated the fact that the pistons punched the valves. I can assure you if that's true you are looking at a new chain (obviously) new cam shaft, new valves and springs. Call your local mech shop (not a stealership) and find out the cost to rebuild the heads. Of course you can ask them at the same time about them installing the new head (new gasket's) and new timing chain. The timing chain needs to be done precisely. If done wrong and the engine is turned over you can have the same issue again.
You could buy a new engine but when it comes to buying used, to quote Forrest Gump "You never know what your gonna get"! I would price shop, even talk with friends of friends, friends of family. Anyone you can think of. Sorry about your bad luck. |
#8 |
Lexington, VA
1999 XLT 4.0
So... after the car has sat for 6 months while I was out of state, I'm back to trying to get it running. I found a possible replacement engine that runs perfect. However, it's a 97, so I'm guessing it probably at least needs the oil check valve installed/tensioneers replaced. Since the engine is out, now's the best time to do it. What parts do I need for preventive maintenance (i.e., I don't want it to start rattling a few months down the road, but I don't have the money to buy the full $400 chain kit, tools, and pay the mechanic to swap everything)? Do you need special tools to install the ford TSB kit I heard about before (the one with tensioneer, check valve, and intake gaskets?)
#9 |
Roxana, Illinois
2000
You would need to budget it all out. New engine (being new to you) vs fixing the old. I would personally go with the new one. Make sure to flush fluids and check everything out and possibly get a friends help. Then keep the old engine and rebuild it as finances permit. At least that way if this ever happens again or you get a new ex you can have 2!
| Thread Tools | |
