Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Rear Differential Vibration & Fluid Change
Reply
Thread Tools
Old 05-02-2009, 04:49 PM   #1
wArtsmith
Crystal Lake, IL
2006 Explorer Eddie Bauer
Vehicle Specs
(Original Poster)
I watched the video on how to change differential fluid, but the part that got only momentary mention was adding the new fluid. I have a 2002 AWD Mountaineer. It appears the fill plug is right above the larger drain plug. Having the spare tire in the way doesn't help.
What's the best trick for letting gravity do its thing and allow me to refill it?
Now, the bigger reason why I'm doing this:
I get *serious* vibration from the rear when making turns, especially after traveling long distances. The differential has 97K miles. A year ago Ford looked at it but may not've replaced the fluid. I'm about to change it out with Mobil 75W140LS, figuring a $50 oil change is an inexpensive troubleshooting step. Anyone ever experience this?
wArtsmith is offline   Reply With Quote
Old 05-02-2009, 10:07 PM   #2
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Vehicle Specs
Check it out. I removed the spare. Only takes 2 minutes.
http://www.youtube.com/watch?v=CAiy8CN1JdE
__________________
Explorer how to videos Brakes, Intake, Seafoam, Coolant Flush, Oil change, Differential Flush, Inertia Switch, Thermostat, Transfer Case Flush, Throttle Mod, and more!
http://www.youtube.com/user/jlsparky7
If you like/use my vids you can thank me by subscribing to my youtube page! Thanks!
jlsparky7 is offline   Reply With Quote
Reply
Tags
change, differential, fluid, vibration
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
