#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
2003 Sport Trac sputtering/rough idle.
Reply
Thread Tools
Old 05-05-2009, 12:24 PM   #1
Bish
Georgia
2003 Sport trac
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
First post, and I have a question. I have a 2003 Sport trac that has been rough idling and/or sputtering when stopped or first started in the AM. The check engine light came on the other night. Advantage Auto read the codes (O2 sensor) and recommended using a gasoline treatment. Not surprised that didn't work. Any suggestions?
Bish is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-05-2009, 01:43 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome bish
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 05-05-2009, 02:23 PM   #3
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Quoted: 3 Post(s)
There are many components in the O‚‚‚‚² Sensor system, could you post the actual codes that were read?
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
fixxxer is offline   Reply With Quote
Old 05-05-2009, 11:03 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread to the 2001-2005 Sport Trac section.
BrooklynBay is online now   Reply With Quote
Old 05-06-2009, 02:23 AM   #5
mikekristine218
Modesto, Ca
'03 Sport Trac XLT~98 XLT
Vehicle Specs
Quoted: 0 Post(s)
Try changing the O2 Sensors. It could also be the Cold Start Sensor if it only occurs when cold.
Hope that helps, all I can think of at this time.
mikekristine218 is offline   Reply With Quote
Old 05-07-2009, 04:17 AM   #6
02Xploda
Tucson,az
02 ST
Vehicle Specs
Quoted: 0 Post(s)
Tune up?
IAC--clean it out--free
Throttle body-- clean it out also--free
02Xploda is offline   Reply With Quote
Old 05-07-2009, 01:42 PM   #7
471Magnum
Evansville, IN
2002 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Really need to post the codes. Could be anything from bad EGR valve, or O2 sensor, or a vacuum leak. Or it could very well be dirty injectors.
Codes will point you in the right general direction.
471Magnum is offline   Reply With Quote
Old 05-07-2009, 05:34 PM   #8
Clusterpup
Miami, FL
Clusterpup's Avatar
02 Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
I bought a code reader from Advance Auto a couple of weeks ago for $50, it was on sale, regular price is $70. It just reads the codes and can erase them. It comes with a CD that lists all the codes for MANY vehicles including ours.
Clusterpup is offline   Reply With Quote
Old 05-08-2009, 09:28 AM   #9
JohnnyO
Moderator Emeritus
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
Quoted: 13 Post(s)
Clean the Idle Air Control valve.
Check the vacuum elbow on the passenger side of the engine for a crack.
Both are common problems that will cause a rough idle.
__________________
'08 Sport Trac, Gibson exhaust, Firestone Destination A/T's, Steelers swag.
"It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Old 05-12-2009, 02:31 PM   #10
Bish
Georgia
2003 Sport trac
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks for the advice. I replaced the infamous cracked elbow hose(which was torn not cracked), replaced the fuel filter, erased the code and all is well. the idle is perfect and the light has stayed off.
Old 05-12-2009, 06:25 PM   #11
Clusterpup
Miami, FL
Clusterpup's Avatar
02 Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
good to hear. my trac had the same hose busted when i bought it. replacing it made it idle better but i still have a vac leak i have to resolve and its affecting the blend door for my ac. i need all the ac i can get living in south florida, its already hot there. i will be checking that out soon as i get back in town.
Old 05-13-2009, 12:27 PM   #12
sickwilly
Middle Tennessee
2005 Exp Sport Trac
Vehicle Specs
Quoted: 3 Post(s)
My idle is kind of rough too. I have the fuel filter at home with the tool and if it ever stops raining, I will get it replaced.
I have found the elbo and looking at the top of it, I see some marks but no clear tear or hole. Where were you all finding the tears? I am guessing I should pull that sucker off to be able to see all sides of it?
sickwilly is offline   Reply With Quote
Old 05-13-2009, 04:00 PM   #13
Clusterpup
Miami, FL
Clusterpup's Avatar
02 Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
You should be able to hear the leak. Maybe you can stick your finger under the hose and see if you can feel air or maybe your finger will cover the hole and the hissing sound of a leak will stop. Also, that hose comes off pretty easy though if its old it may come apart.
Old 05-18-2009, 08:42 AM   #14
Bish
Georgia
2003 Sport trac
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
elbow hose leak
I could hear the leak when I lifted the hood. I just pressed on the hose while it was running and it was easy to see the tears on top of the hose.
Old 10-18-2009, 09:21 PM   #15
Wade Davis
Vehicle Specs
Quoted: 0 Post(s)
Infamous hose leak before:
and after:
Wade Davis is offline   Reply With Quote
Old 01-17-2010, 09:41 PM   #16
noelb2615
Quezon City, Metro Manila
2002
Vehicle Specs
Quoted: 0 Post(s)
thank you very much, very informative
noelb2615 is offline   Reply With Quote
Old 02-04-2010, 05:15 PM   #17
VolklGoat
2002 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Wow, thanks a lot, I've had the exact same issue with my 2002 and just went and looked and my hose looks exactly like that picture!
Where do you get the replacement elbow hose from?
And does anyone know a part number or exact name?
Thanks a ton!
VolklGoat is offline   Reply With Quote
Old 02-04-2010, 06:44 PM   #18
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Check WWW.DormanProducts.Com for the part.
Old 07-21-2011, 11:45 AM   #19
rwspringer01
tampa fl
2003 sport trac
Vehicle Specs
Quoted: 0 Post(s)
check engine, sputtering
Quote:
I have same vehicle, same results. I found the solution here on this site. A common problem is the pvc valve hose. if you search this site there is a post that has pics, and how to fix. I had a shop check my engine light when I had my oil changed, he gave me an estimate of $579.00 said I had 2-o2 sensors bad. threw the same codes at autozone. after finding the solution on this site the total cost was $2.79 I replaced the rubber elbow on top of the engine on passanger side. autozone seemed to be aware of the problem and gave me a small L shaped that worked great. good luck, hope this helps
rwspringer01 is offline   Reply With Quote
Old 03-24-2013, 03:36 PM   #20
scott_t_ct
Vehicle Specs
Quoted: 0 Post(s)
Wink Thank you so much!
Quote:
and after:
This was exactly my issue with my 2003 Sport Trac. Your photos proved to be spot on, and I hope they help many more users save big money!
scott_t_ct is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
