Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
1996 XLT Rear Diff - Best Fluid
Reply
Thread Tools
Old 05-06-2009, 08:58 AM   #1
SCB2525
Richboro, PA
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
What is the proper fluid? I have 2 quarts of Redline 75W-90 without limited slip additive. How do I know I have a limited slip diff? If I do, where should I get the additive?
SCB2525 is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-06-2009, 09:16 AM   #2
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
That weight should work provided you're not towing heavy stuff. Additives can be purchased from the dealer or sometimes auto parts stores - it usually costs around $5 I think.
You can tell if you have a limited slip if you have a "D" in the axle code in the sticker located on the side of the driver's door.
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 05-06-2009, 12:06 PM   #3
SCB2525
Richboro, PA
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well what does it call for? This truck doesn't tow, but if a 75w-140 would significantly cut down on vibration or protect that much better, I may go for that.
Old 05-06-2009, 12:35 PM   #4
SCB2525
Richboro, PA
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've looked around and there's conflicts as to what people say to use. Some say 75/90 is fine but others say Ford updated their recommendation to 75/140 due to wear issues. Truck has 177k and I don't know if the fluid has ever been changed. Still, its given no troubles or noises but I just want to get some of the deferred maintenance up to snuff. Trans was rebuilt about 20k ago and the transfer case fluid changed about the same time with Redline High Temp ATF. Driveshaft splines were greased shortly after it became my vehicle and its sounding like it needs it again. I think I may use Amsoil open gear grease to try and keep it lubed longer.
When I do the differential should I get the gasket off Rock Auto or just use RTV?
Old 05-06-2009, 01:39 PM   #5
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Either really - I personally just use RTV. But some people will argue that a gasket with RTV on both sides is much better.
__________________
Old 05-06-2009, 02:20 PM   #6
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
the 75/90 should be fine, as long as it's good quality oil. I'm running amsoil 75/110 in mine with no troubles, that what the dealer reccomended. And my axle probably sees a whole lot more stain than yours does.
techieman33 is offline   Reply With Quote
Old 05-06-2009, 11:07 PM   #7
SCB2525
Richboro, PA
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'd say Redline is quality. If 75/90 is what's in there now, I don't think it'd be bad to replace it in kind. Also, anyone ever utilize a magnet? I wouldn't think putting one inside would be very good, but how about throwing a hard drive magnet on the outside near the bottom? I just don't know how effective that would be.
What is the capacity on these? Should I expect to be good with 2 quarts?
I really wonder if its ever been changed. If it never has been, you think I stand to bump up my MPG?
Old 05-06-2009, 11:09 PM   #8
HahnsB2
Battle Ground WA
88 Bronco II
Vehicle Specs
Quoted: 0 Post(s)
They take about 2.5 quarts, so buy 3.
__________________
88 Bronco II EB, 4.0L, M5OD, 4.56s, Aussie Locked 8.8, Aussie Locked D35 w/e-clip eliminator, Manual 1354, 3" PA Body Lift, 34x10.5 Swamper LTBs, Warn Hubs, U-Joint Drive shaft, OBA, Custom bumpers front/rear, 2 1/2" Exhaust w/flowmaster 40 series.
95 Dakota Sport CC, 5.2, 5-Spd(Hurst), 4x4, M1, HS 1.7 RR's, Aero Turbine 3030/Side Exit, 50mm TB, 30x9.50s on 15x8 Ultra 50 Series, 3.55s.
HahnsB2 is offline   Reply With Quote
Old 05-06-2009, 11:22 PM   #9
RickMar
N. Andover Massachusetts
99 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
If you have the limited slip differential designated with the "D" under Axel as IZwack posted and you want the additive. You will want to check out the
AMSOIL product called SlipLock at this link :http://www.superoilcentral.com/Super...k_diff_add.htm
I hope this is helpful.
Rick
RickMar is offline   Reply With Quote
Old 05-06-2009, 11:34 PM   #10
SCB2525
Richboro, PA
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I checked the code this morning but it didn't match the same format as the one above. The axle code was I believe 45, which according to a rundown I found in another thread, means I don't have a LS diff.
If I have to get a third quart, I'm on the fence as to whether I might as well go all 75/140. My problem is I got this fluid online several months ago and I'm not sure what I'd do with it. My nearest Redline dealer is like 20 miles away. I wonder if they'd swap the 2 75/90s for 75/140s as long as I got a third 75/140 and a few quarts of ATF for when I plan to change the fluid in the M5OD in my dad's '91 F-150. Otherwise I might be willing to sell these two quarts of 75/90 if anyone's interested.
Old 05-07-2009, 12:39 AM   #11
nitro71
Spokane WA
Vehicle Specs
Quoted: 0 Post(s)
D or L is limited slip.
http://www.explorerforum.com/ntrprize/Axle.htm
If you off road it put whatever is cheap in as you'll probably want to replace it occasionally anyways. My blazer had water getting in the diffs once in a while.
nitro71 is offline   Reply With Quote
Old 05-07-2009, 06:07 AM   #12
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
If your 2wd that 2 quarts would be enough to fill up the front diff.
Old 05-07-2009, 02:38 PM   #13
RickMar
Vehicle Specs
Quoted: 0 Post(s)
Axle Ratio and Transmission Codes — Ranger, Explorer
1996 Explorer
CODE -Type -RATIO
41 Conventional 3.27
45 Conventional 3.55
D4 Limited Slip 3.73
46 Conventional 3.73
D1 Limited Slip 3.27
42 Conventional 4.10
D2 Limited Slip 4.10
All above have 3200 Pound Capacity
Rear Axle 3
Ford Conventional and Traction-Lok® 8.8 Inch
Approximate Capacities 5.5 Pt. (2.75 Quarts)
3 Fill to 1/4 inch to 9/16 inch below bottom of fill hole
I hope this helps.
Rick
Old 05-07-2009, 02:39 PM   #14
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
1996 Explorer
CODE -Type -RATIO
^-- those numbers only apply to Explorers, not Rangers. Just look here for the entire list: http://www.explorerforum.com/ntrprize/Axle.htm
__________________
Old 05-07-2009, 11:03 PM   #15
SCB2525
Richboro, PA
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Lots of good info, thanks guys.
Does anyone know what is OE in a 3:55 conventional diff? 75/90 or 75/140?
Also, anyone know if an aftermarket cover is available with a drain plug? Relatively cheap that is? I'd probably change it a lot more often if it was that easy.
Old 05-07-2009, 11:52 PM   #16
RickMar
Vehicle Specs
Quoted: 0 Post(s)
Rear Axle Conventional (5.5 - 5.8 pts.) 80W90 Axle Lubricant
Ford Part #XY-90-QL
Ford Specification ESP-M2C154-A
Ford Part Name -Premium Rear Axle Lubricant
I hope this helps.
Rick
Old 05-08-2009, 01:02 AM   #17
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
Redline is good stuff and that weight will be fine. Check my signature for a differential flush how to video. With a 100% synthetic gear oil you DO NOT need the additive unless there is vibrations after the fluid change.
The best gear lube in my opinion is Amsoil.
__________________
Explorer how to videos Brakes, Intake, Seafoam, Coolant Flush, Oil change, Differential Flush, Inertia Switch, Thermostat, Transfer Case Flush, Throttle Mod, and more!
http://www.youtube.com/user/jlsparky7
If you like/use my vids you can thank me by subscribing to my youtube page! Thanks!
jlsparky7 is offline   Reply With Quote
Old 05-08-2009, 01:14 AM   #18
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
This isnt aimed to you jlsparky7, but I just wanted to add my personal experience with Amsoil gear oil:
Last fall, I drained the shuttle van's rear axle's gear oil and refilled with Amsoil. After that, the van has had this hum at like 55 mph. When the Explorer is done and ready to be towed, I will flush the Amsoil out and see if Redline does any better. If that doesnt work, back to good ol' Mobil-1 (although expensive).
__________________
Old 05-08-2009, 09:28 PM   #19
SCB2525
Richboro, PA
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well I'm going to have to mix the Redline with a topper of Mobil-1 it seems, as the only Redline distributor in the area is only open M-F and I was busy all day. I need to get this done this weekend, so its going to be 2qts Redline and the rest M-1.
Anyone think that wouldn't be OK?
Old 05-08-2009, 09:28 PM   #20
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
I'm sure it'll be okay.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
