| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Ham Radio - CB - Trail Communications I have found that fourwheeling and ham radio go hand in hand. Post any questions or comments about the great hobby of amateur radio here. Of course CB'ers are welcome also. Ray, AE6H and Joe, N1LVN both moderate this forum. |
Thread Tools |
#1 |
Cooler than Ben!
Fort Riley, KS
'00 XLS
Roof mount CB antenna?
Has anyone installed one? Have photos? I'm wondering how exactly its supposed to seal so it doesn't leak, and how thick the mount is so I'll know if I'm going to have headliner issues. I'll be using a Wilson 1000 antenna, but I'm interested in any and all roof mount installs.
Edit: Not talking about magnetic mounts, of course. __________________ '96 4x4 4.0 OHV Auto Eddie Bauer -1354 Manual -TT and Shackles -2" BL -33x12.5 BFG A/T tires on 15x8s (RIP) ![]() '95 2wd 4.0 OHV Auto XLT -Stock Daily Driver '00 4x4 4.0 OHV Auto XLS See specs on left |
| Sponsored Links (Less Ads) |
#2 |
Columbia, MO
1994 XL
I have this antenna mounted permanently in the center of the roof: http://www.walcottcb.com/flex4-wilso...28_352_412_420. I really like it because of it's flexibility. It folds right over when needed!
Not the best pic, but this one shows it: http://smg.photobucket.com/albums/v4...t=IMG_0809.jpg. I used this mount: http://www.walcottcb.com/firestik-k4...l?cPath=28_353 with this spring: http://www.walcottcb.com/firestik-ss...ath=28_354_445. You might want the "low profile" mount, though. A tiny bit of coax pokes through my headliner, but I don't care. With the two washer-like mounting plates, just use a little clear silicone around the hole. No leaks here! It all works well. Good luck with your setup. __________________ 1994 Explorer XL: 4-door 4x4 manual everything! 1986 Mustang SVO 2.3 turbo/T-5 (for sale) Dana 60/Sterling 10.25" axle swap status: building axles and doubler SAS: SVO42's 1-ton SAS Doubler: BW1354/Dana 20 Doubler |
#3 |
Cooler than Ben!
Fort Riley, KS
'00 XLS
I'm trying to figure out how this is supposed to mount through the roof..
![]() (from here) It seems like this is more like a roof mount, and I would just need a washer with a rubber seal and a nut to fasten this through the roof: ![]() (from here) Any suggestions? __________________ '96 4x4 4.0 OHV Auto Eddie Bauer -1354 Manual -TT and Shackles -2" BL -33x12.5 BFG A/T tires on 15x8s (RIP) ![]() '95 2wd 4.0 OHV Auto XLT -Stock Daily Driver '00 4x4 4.0 OHV Auto XLS See specs on left |
#4 |
The Youngin'
Willow Spring, NC
'96 XLT
I'm pretty sure you don't actually go through the roof. You secure the antenna with a magnet of some sort in the center of the roof and run the co-ax down through a door jam to your CB.
#5 |
Scubajoe - Radio Mod
Garner, NC
'97 AWD V8 XLT
Yeah, those pictures don't help a lot.
__________________ Joe, N1LVN '97 XLT AWD V8 STOCK Amsoil Synthetics throughout. Amsoil Ea air filter. Bilsteins. Scanguage. Search ExplorerForum |
#6 |
Cooler than Ben!
Fort Riley, KS
'00 XLS
The more I think about it the more I think I'll go with the one in the second picture. When I have some time I'll give Wilson a call to find out for sure though.
#7 |
Elite Ranger
Cumming, GA
'93 Ranger XLT
I have a K40 roof mount antenna in my Rangers (and my Dad's, and my ex's Ex).
Punch (don't drill) a 3/4" hole in the roof, seal the edges of the hole with paint to avoid rust, assemble the antenna mount (it should have a rubber piece to make a seal onto the roof surface to prevent leaks - if not, add one) - that's it. One more thing - I add a backing plate to the underside of the roof. 1/8" or so aluminum works well. In the Rangers, a 12x12 piece - in the Ex, a 12xWidth-of-track-in-roof piece worked fine. Here's a picture - not a great shot of the antenna, but you get the idea. |
#8 |
Cooler than Ben!
Fort Riley, KS
'00 XLS
Why would punching a hole be better than drilling?
#9 |
Elite Ranger
Cumming, GA
'93 Ranger XLT
Yes - the roof is thin sheet metal. It would be very difficult to drill a nice, large, round hole from a hand-held drill.
Not impossible, but difficult. Thin metal stretches and bends easily. I imagine you could use a hole saw, but I would suggest having someone hold a block of wood to the backside of the roof to act as a backing plate. Remember, as you lean on the drill, the metal will want to flex/deform. |
#10 | |
Wannabe Elite Explorer
near Oak Ridge, TN
Quote:
You *could* make a depth stop for the bit, and make certain it was sharp, but then, sometimes the bit wants to act like a tap and you get a hole that looks more like the inside of a speedclip than a hole. I use a 30 dollar bit expecially designed to cut the correct hole, but failing that, you could prolly find a cheap hole bit that you could use once. I have never 'punched' a hole in a vehicle for an antenna, but I have punched many into metal boxes and as thru holes. I will say, however, they are right about the sheet metal being very thin. Antennas with a lot of wind load, or prone to bang on things, usually aren't a good choice for a NMO mount. the more flex, the less contact you wind up getting with the ground plane, and you also wind up flexing tiny cracks in where the sealant adheres, causing an intermittant leak. (shrugs) -Shawn |
#11 |
Cooler than Ben!
Fort Riley, KS
'00 XLS
So I should put some kind of backing between the antenna mount and the roof to help support it..
Where would I get this special bit for cutting holes in a roof? __________________ '96 4x4 4.0 OHV Auto Eddie Bauer -1354 Manual -TT and Shackles -2" BL -33x12.5 BFG A/T tires on 15x8s (RIP) ![]() '95 2wd 4.0 OHV Auto XLT -Stock Daily Driver '00 4x4 4.0 OHV Auto XLS See specs on left |
#12 |
Elite Ranger
Cumming, GA
'93 Ranger XLT
I used a 1/8" thick aluminum backing plate.
The bit you are referring to is called a hole saw. They can usually be found in hardware stores and home centers. |
#13 |
Gotta Love It...
Salisbury, MD
1998 Merc Mountaineer
I use an ANTENEX 3/4 hole saw just for antennas. I also use a 3/8 NMO mount for the thinner sheet of an Ex roof. I learned the mistake (twice) in using a 3/4 on a thin sheet roof. The 3/8 mount is excellent. www.tessco.com has everything you need for mobile antennas, and if they don't, I do..
Spin __________________ 1998 Mercury Mounty OBD1 303E Engine, BBK 70mm TB 3" Cat Back Flowmaster Stock Lift(for now) Amateur Radio Emergency Communications Vehicle MEMA RACES/ARES SKYWARN Spotter/Chaser
| Thread Tools | |
