Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How to: Remove 4.0 Engine Explorer 1997-2001
Reply
Thread Tools
Old 05-13-2009, 02:33 PM   #1
grufman
Stockholm
Various
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Sorry, it's written in swedish, but the pictures speak for themselves.
http://www.grufmanbil.se/mektips/Dem...lorer97-01.pdf
I also did a writeup on how to remove the faulty camchains on the E-engine.
http://www.grufmanbil.se/mektips/Sto...lorer95-01.pdf
And while I was at it, I also did a tutorial on how to remove the transmission on a 95-2001 explorer
http://www.grufmanbil.se/mektips/Dem...daExplorer.pdf
Enjoy
grufman is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-13-2009, 02:41 PM   #2
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
Awesome.
__________________
Explorer how to videos Brakes, Intake, Seafoam, Coolant Flush, Oil change, Differential Flush, Inertia Switch, Thermostat, Transfer Case Flush, Throttle Mod, and more!
http://www.youtube.com/user/jlsparky7
If you like/use my vids you can thank me by subscribing to my youtube page! Thanks!
jlsparky7 is offline   Reply With Quote
Old 05-13-2009, 02:59 PM   #3
CmdrPopNFresh
Salt Lake City, Utah
'93 Sport
Vehicle Specs
Quoted: 0 Post(s)
wow thats really well done! too bad i dont know that language
CmdrPopNFresh is offline   Reply With Quote
Old 05-13-2009, 03:08 PM   #4
Kiloaman
Alamo, CA
'99 XLT
Vehicle Specs
Quoted: 0 Post(s)
Yes, excellent pictures, i like a lot. Wish it was in english.....but nothing that I couldn't translate online. Plus, the pictures are pretty self explanatory. Good work! Will be extremely useful!
Kiloaman is offline   Reply With Quote
Old 05-17-2009, 03:37 PM   #5
grufman
Stockholm
Various
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
maybe someone could make it a sticky? ;-)
Old 07-24-2009, 02:48 PM   #6
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
vroomzoomboom's Avatar
98 supercharged 347 sport
Vehicle Specs
Quoted: 370 Post(s)
for anyone that needs this info, i went and did a online translation of it to print off. they are numbered with the pictures. i left the first 2 out, cause if you can figure those out, your already way over your head!
3. Remove the splash guards on the inner screens.
4. Unscrew the 4 bolts holding the exhaust pipe at manifold. ½ "-making!
5.Remove the starter motor. You do not let the cable connection.
6.Turn off växellådsbultarna keeping the engine together. We recommend an extended
which is about 150 cm long and has svivlande 13 mm at the end.
7. Here is another picture of where växellådsbultarna sit.
From this page it may be easier to hand chasing out the bolts.
8.Here you dismantle the bolts in the bottom of the box.
9.When the engine and the box is separated, and the starter motor removed picked, you can access
turbine screws. 14 mm. Remove these. 4 pcs.
10.Use a 19 mm socket on the crankshaft to rotate the engine.
11.We recommend that you use a small air turbine engine when the screws should
dismantled. It makes the job go faster.
12.Remove the cover over the cooler.
13. Let all the glycol from the engine. There is a drain screw on the right side of the condenser.
14.Remove the bonnet.
15.Add like hood on the roof. Do not forget to protect the paint against huvlåset.
16.Remove the air hose ...
17.... and engine cover
18. Drill away theft protection to the data box.
19. Release the computer connection, 10 mm
20 Release the earth cable, 11 mm.
21 Release the data cable from the engine, do not forget the vacuum hoses on both the right and
left side of the engine.
22 Use a fan key to switch off the fan nut. It is rättgängad.
23 Release both kylrören to the automatic gearbox. 16 mm.
24 Release the plastic casing around the condenser.
25 Plastic casing and the fan losskruvade dismantled simultaneously.
26. Let cooler, 2 screws. Release also kylrören during the cooler, these are fastclipsade.
Let also the upper and lower radiator hose and let the last glycols drain.
27 Release both cooled hoses leading to the heat package.
28. Remove the condenser. How will it look.
29. Unscrew remskivan to the servo pump.
30. Remove the servo pump.
31. Remove the reservoir to the servos.
32. Remove also the small holder to servo hose.
33. Remove the nuts to the servo pump.
34. Put the servo reservoir.
35. Unscrew the steering rods to the AC compressor. 5 mm.
36. Do not forget the vacuum hose when the ac-compressor release time. Do not forget to
re-mount it when the engine comes in. Easy happened!
37. Release the fuel connection. Use spring lock tool.
1999-2000 has a hose. 1997-1998 has two hoses.
38. This is how it looks when the ac-compressor has released a time.
39. Remove the engine mount. 4 bolts.
40. Remove the bracket to the oil stick to the machine.
41. Remove the bracket to the AC pipe.
42. Remove the bracket to automatkylrören.
43. Remove the 2 data connectors and 2 lambda contacts on the right and left
side of the engine (on the back).
44. Now the engine let go.
45. When you come out a little engine you can release the bolt attached to the cable strain. Sitting on
left engine mount. 10mm, taken from below.
46.Now you can remove the mount to ac-compressor 15mm.
47. Release the power cable to the alternator, pull out the power cable and take off cable
oil pressure sensor. Now is the sentence to make it possible to get it out of the engine. Good luck.
48. The released. View from the front ...
__________________
Stroke Me, Blow Me. 347 Stroker + M112 Eaton Supercharger = Evil
roll pan build for 1st and 2nd gen explorers
door switch LED convention
vroomzoomboom is offline   Reply With Quote
Old 07-24-2009, 03:49 PM   #7
erixon
Edmonton, AB
99 Sport
Vehicle Specs
Quoted: 0 Post(s)
the växellådsbultarna must have some deep bolts if you need a meter and a half extension... oh how those växellådsbultarna's can be pesky. lol
erixon is offline   Reply With Quote
Old 07-24-2009, 03:51 PM   #8
Xplorer82
OH.
'97 XLT... '98 Eddie...
Vehicle Specs
Quoted: 1 Post(s)
thank you. no really, thanks. i needed this write up
__________________
┌П┐(-_-)┌П┐
'98 Eddie Bauer. 4x4, 4.0L SOHC. 190k miles and counting, Flowmaster 50 series, Amsoil Ea air filter, 31x10.5" Sumitomo All-Terrain & the dreaded rattle.
R.I.P : '97 XLT - it was a good 8yrs..
Xplorer82 is offline   Reply With Quote
Old 05-07-2011, 09:03 PM   #9
redanvilforge
Cardinal, ON
1997 Explorer XL
Vehicle Specs
Quoted: 0 Post(s)
CAN Great write up!
Thanks for the write up and translation! This is going to be very useful when i swap the engines from the parts truck to my good truck.
redanvilforge is offline   Reply With Quote
Old 05-08-2011, 08:23 AM   #10
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
1 SOHC V6 Engine Removal Procedure
Quote:
This may also help: 1 SOHC V6 Engine Removal Procedure
2000StreetRod is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
