Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger - Computers, Chips, Tuning > EEC IV
Notices
92 Ranger Keep alive memory code 512.
Reply
Thread Tools
Old 05-23-2009, 06:42 PM   #1
congaman
sault ste marie On
1992
Vehicle Specs
(Original Poster)
CAN 92 Ranger Keep alive memory code 512.
Run Diag on my Ranger and come up with a 512 code no idea what that is and this is the kicker code 10 thing??? runs rough at idle engine light comes on eventually stays on.
Changed the ign wires and dist cap rotor.
Diag shows a code 111 no problem code
Thing is there is no code memory in the comp does anyone know if there is a back up batterie ni the computer and what the code 10 means
congaman is offline   Reply With Quote
Old 05-23-2009, 07:03 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
welcome conga
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 05-23-2009, 11:31 PM   #3
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread to the EEC-IV section. According to my sticky thread on the top of this section: http://www.explorerforum.com/forums/...d.php?t=160035, it says: 512
(M)
Memory power (PCM pin 1) was interrupted - Was the battery disconnected? 512
Keep Alive Memory Test Failure.
C
The code 10 could be a separator code: SEPARATOR PULSE.
The separator pulse is a single pulse that indicates the END of hard fault codes and the BEGINNING of memory codes.
It will show up as a code 10 on most digital testers.
BrooklynBay is online now   Reply With Quote
Old 05-24-2009, 05:38 AM   #4
congaman
sault ste marie On
1992
Vehicle Specs
(Original Poster)
Code 512
Quote:
(M)
C
Battery was disconnected for 10 seconds only.
Old 05-24-2009, 05:48 AM   #5
congaman
sault ste marie On
1992
Vehicle Specs
(Original Poster)
After i got the truck back from the shop the teck told me he had pulled up no codes and suspected the box oxs anyways i went and got me one of those code readers and also got no codes till i replace a blown fuse 15 amp under the hood witch had something to do with the computer, then the codes came up.
Old 05-24-2009, 09:49 AM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
I would suggest that you clear the codes since the fuse was replaced, then see if they come back again.
Old 06-09-2009, 08:51 PM   #7
congaman
sault ste marie On
1992
Vehicle Specs
(Original Poster)
Thumbs up 512 Code
Had truck in the shop the rough idle problem i had didnt show up code.
They ended up replacing the MAF and the thing runs like a top well almost it is 98% better.
The engine lite still comes on because of code 512 KAM but i was told there may be a bad live all the time wire "YELLOW" that runs to the computer witch keeps the mem alive.
Solution is to find the KEM wire running into the computer itself and run it directly to the fuse box on the positive live side and the lite should stay off.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
