Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Ham Radio - CB - Trail Communications
Notices
Ham Radio - CB - Trail Communications I have found that fourwheeling and ham radio go hand in hand. Post any questions or comments about the great hobby of amateur radio here. Of course CB'ers are welcome also. Ray, AE6H and Joe, N1LVN both moderate this forum.
Reply
Thread Tools
Old 05-27-2009, 04:44 PM   #1
Brett F.
Upstate SC
'93 4x4
Vehicle Specs
Was given a Cobra 29NW Classic and wont work
Hi all. I was given a Cobra 29 Classicand cannot seem to get it to work at all. Trying to figure out if it is dead or not.
So that being said;
I have also been given a mag mount antenna. Where the coax ran between the weather stripping and the door it is worn to the core wire. I tried to separate the mesh wiring away from the core and put electrical tape on it to keep them separate. I took my volt meter and set it for continuity and put it across the center of the antenna connector and the outside and I am guessing since I did not get a tone that the mesh is touching the core at that one spot so it should be ok. However, I didn't get a tone from the center of the connector to the tip of the antenna either so I am a little lost.
Anyway, I cannot get any noise from the unit even just playing with the squeltch.
When I key the mike I get the sound like a bump of the mike getting keyed but that's it.
What should the SWR be with no antenna? I put it in calibration mode and the SWR knob does nothing.
Thanks!
__________________
Lovin' life here in the good ol' South.
My stock '93 4x4 XLT is currently being driven by my 17 yr old daughter.
My current daily driver is a 1996 XLT 4WD.
Brett F. is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-27-2009, 05:12 PM   #2
rizzjc
Scubajoe - Radio Mod
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
First, check the Cobra website for the manual, if you don't have it.
On the antenna, what type is it? Fiberglass? Metal whip? If metal, is it powdercoated? That would prevent continuity. Is the whip removable? If there's some sort of loading coil in there, then I'm not sure what affect that would have on the test you are trying to perform. Maybe someone else does.
__________________
Joe, N1LVN
'97 XLT AWD V8 STOCK
Amsoil Synthetics throughout. Amsoil Ea air filter. Bilsteins. Scanguage.
Search ExplorerForum
rizzjc is offline   Reply With Quote
Old 05-28-2009, 06:19 AM   #3
Brett F.
Upstate SC
'93 4x4
Vehicle Specs
Well last night I checked out the worn place in the coax and there was a break I didn't see before in the center copper wire.
So I cut the coax and then stripped both and just twisted them together without letting them touch and it worked so... I am picking up a new mag mount this morning.
Hope this works.
__________________
Old 05-28-2009, 10:45 AM   #4
rizzjc
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
Sounds good. Good luck!
__________________
Joe, N1LVN
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
