| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
97 Eddie Bauer 4wd
How to replace the exterior door handle.
Can someone explain how I can replace the driver's side exterior door handle on my 97 ford explorer myself? I have already ordered the new door handle, but just need to know how to do it w/o seriously damaging my vehicle. Thanks.
#2 |
Southern Cali Explorer
Newport Beach California & Bay Area California
2001 Sport (sold)
welcome
__________________ 2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12 |
#3 |
Woodhaven, Mi
1996 5.0 XLT AWD
Welcome to the forum!
I think you have to remove the inner door panel. Should be fairly easy form there. __________________ Explorer how to videos Brakes, Intake, Seafoam, Coolant Flush, Oil change, Differential Flush, Inertia Switch, Thermostat, Transfer Case Flush, Throttle Mod, and more! http://www.youtube.com/user/jlsparky7 If you like/use my vids you can thank me by subscribing to my youtube page! Thanks! |
#4 |
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 5L sport
there are two rivets that you will have to drill out. on the inside of the door, there is a threaded clip that holds the linkage in, you will have to open it (it opens like a door, it may be a little stubborn, but it will open). then put your new handle on, and then the linkage back in, and snap the clip back in place. you will need one of the bigger pop rivet guns because the rivets are 1/4 ones. also, when you go to rivet the handle back on, tape some cardboard under the handle. that way if the rivet gun drops after it snaps off the rivet, it will not scratch the door. hope this helps you.
__________________ NOS is nice, but i'd rather be BLOWN ![]() evils elite registry roll pan build for 1st and 2nd gen explorers door switch LED convention |
#5 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! I've moved your thread to the stock 95-01 section.
#6 | |
Pa.
1997 Mercury Mountaineer
Quote:
http://www.explorerforum.com/forums/...ht=door+handle __________________ ~Jamie~ |
#7 |
balt, md
91 xlt, 92 xlt, 95 xlt
I have a 2000 explorer. The original outside drivers door handle lasted about 100k and I had to replace it. I'm sure I did the repair correctly in terms of drilling the rivets out and getting the linkage lined up properly. However, I've had to since replace the handle twice within 20k miles. I've been using a new aftermarket replacement (Dorman) handle from one of the well know wholesalers. Here's my question... does anyone know if the dealer supplied handle is of better quality than the aftermarket handle? thanks
__________________ '88 F150 4x4 '91 Explorer XLT 4x4 '92 Explorer XLT 4x4 '95 Explorer XLT 4x4 If it don't = 16 (4x4), it ain't worth driving... |
| Thread Tools | |
