- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
I decided its time to work on the extended arms.. its a small enough project and the kind I can do without taking the X down for a long time...
I got these from an EF member a while ago (came with a 5.5" lift and other parts)..
They currently have Heim joints which I don't think would last very long in our dusty climate.. Also, they were female heim joints instead of the normal male ones which means its harder to find good joints...
I already cut the ends off, and removed the extra support material that was in the tube..
I'm looking to use a set of Ballastic Joints (http://www.ballisticfabrication.com/Forged-Chromoly-263quot-Ballistic-Joint_p_1636.html).
This means I'll need to make new hangers for the joints since the ones for the heim will be too narrow..
I do have two somewhat stupid questions...
Bolt on or Weld on the joint mount to the frame?
Will it really matter if I get get left or right handed threads for the Joints/tube adapters? For my use I can't think of a reason to have either, other than lefty loosy, righty tighty
~Mark
~Mark
