Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
Roadbully Spacer Lift Install Tips.
Reply
Thread Tools
Old 06-02-2009, 09:22 PM   #1
hors_19
Lacey, WA
'04 XLT NBX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok so to install the front,
First step is to put a jack under the lower control arm and disconnect the sway bar you can take the jack out after this step.
Second step is to disconnect the upper control arm, now to do this take the nut off once you have the nut off hit the actual hub casting that the ball joint goes into with a hammer one good time and it should pop right out.
Third step is to take the lower bolt out of the strut. Then Take the 3 nuts on the top off and you will be able to drop it down then pull it out.
Now to reinstall them just do it the opisite But remember that with the jack on the lower control arm you are going to compress the strut and then you are going to have to pull the upper control arm to the Hub casting.
OK so to install the rear ones,
First step is to put a jack under the lower control arm then take off the disconnect the sway bar you can take the jack out after this step.
Second step, there is a bolt that holds the lower control arm to the hub, take that out.
Third step is to take out the lower bolt on the strut.
Now here is the part that is a pain in the a$$, there are 3 nuts up top again but one is hidden kind of. There is a bump stop looking thing, what you are going to have to do is put a 13 mm 1/4 drive socket on the nut then put a ratchet on it. Now to put the ratchet on it you are going to need a bar to put under the body and on top of the strut and lift to get the ratchet on. once you get that one off you can continue with the rest.
Then you can push down on the lower control arm and take out the strut.
If you have the 1.5" spacers now you are going to either need a grinder or a hacksaw (which is what i used) to shorten the bolts on the strut to put the spacer on.
Then just reverse the steps and there you go lifted EX. Now remember if you don't have a lot of mechanical experience don't be worried it isn't hard just time consuming. It took me from about 1:00 to about 7:00 to complete so if you want to take it some where figure about 6-7 hours of labor you are going to pay.
Well I hope this helps out every body. If anybody has any questions don't be afraid to ask.
__________________
1988 J**p Cherokee Pioneer
2in spacer lift front, 2in blocks rear cut out fenders and 31 1050 15 mud terrain tires Half doors in the works.
2009 J**P Liberty: reason for swap(Lifetime Power train warranty)
SOLD: 2004 EX XLT NBX
RB Lift 2" Front and 1.5" Rear, Tail Light Guards and 265/70/17's
hors_19 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-03-2009, 01:46 PM   #2
FourXFred
Boston, MA
02 EB
Vehicle Specs
Quoted: 0 Post(s)
Install is the same for the 3 inch spacers as well, but you definitely need a coil spring compressor to get the front struts back in. Also, for the rears i used a 13mm gear wrench instead of a socket. It fit in there pretty well and after i let the bolts soak in PB Blaster for about a half hour they came off easy.
__________________
4.6, RB 3 inch spacers, 265/75 BFG AT's, Brown wire mod, K&N cold air intake. 2ND rear end, 100th wheel bearing.
FourXFred is offline   Reply With Quote
Old 06-19-2009, 10:35 AM   #3
Layinhp
CANADA BEST PLACE ON EARTH
2002 XLT v8
Vehicle Specs
Quoted: 0 Post(s)
no spring compressor needed plus it just gets in the way
time consuming yes even worse when everythings rusted = not good
watch the 3 bolts on top of the strut they will snap off pretty easily if rusted
Layinhp is offline   Reply With Quote
Old 06-22-2009, 06:57 PM   #4
FourXFred
Boston, MA
02 EB
Vehicle Specs
Quoted: 0 Post(s)
right, not for the 1.5 inch. but it is definitely needed for the 3 inch spacers.
__________________
Old 06-22-2009, 09:11 PM   #5
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
Quote:
As far as I know, Ben isn't making the 3" spacers anymore for the 3rd gens, only up to 2.5
I have an order in for some right now, and he said that 2.5 is as big as he builds.
Mine are a 2.25 front and 1.75 rear...so we'll see if a spring compressor is needed, I am going to rent one just in case. I plan to take pictures throughout the install to hopefully add to the discussion of installing the RB spacers on a 3rd gen.
thepotroast is offline   Reply With Quote
Old 06-22-2009, 09:48 PM   #6
xplorerguru
2005 explorer
Vehicle Specs
Quoted: 0 Post(s)
roadbully includes very detailed instructions now, and youll see you wont need any commpressors....
xplorerguru is offline   Reply With Quote
Old 06-22-2009, 10:27 PM   #7
rocket2ya
PHX
02 mountaineer v8
Vehicle Specs
Quoted: 0 Post(s)
i put 3in on mine and i didnt need any spring compressors.......
__________________
2002 Mountaineer V8
Spectre CAI. Magnaflow Exhaust. Custom Grille. Blacked out Tails. 10,000k HID's. Avital remote start-alarm. Debadged. 2 infinity 1262w's. Orion 800.1 amp. JVC HU. 6 1/2" Polk Mobile Monitors all around. Police siren.
06 Cadillac CTS-V LS2, lowered on eibach pro kit, blacked out wheels, Magnaflow exhaust, 13.4@105 1/4 mile
rocket2ya is offline   Reply With Quote
Old 06-23-2009, 05:09 AM   #8
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
Quote:
Good, because they just get in the way! I never liked working with them anyway
Old 06-27-2009, 07:03 AM   #9
Layinhp
2002 XLT v8
Vehicle Specs
Quoted: 0 Post(s)
also put 3" in mine and no compressor needed on removal or install of spacers
put the spacer in and use floor jack whalla no compressor needed
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
