TennTechMan
- April 12, 2007
- Maryville, TN
- '94 Sport
I'm needing some help from anyone that has or is considering a 422 cam. The 422 cam requires the 988-12 Comp Cams dual valve springs. I have this cam and springs installed on a set of 95TM heads with stock valve retainers and no extra machining on the heads. The springs are not located correctly at the retainer end or at the head, so the springs are free to move around. On my engine, this caused the springs to essentially remove the valve stem seals after 1.5 years and about 14,000 miles. I swapped out the seals, put the motor back in, and now no smoking.
Here's the part where I'm looking for help and opinions. The most common method I've heard for locating the bottom of the spring is having a machine shop modify the heads. I've designed a set of shims that go under the springs to locate the springs correctly. See below for comparison images. I've already gotten a price back from one of my suppliers, and I know I can do a set of 12 of these shims for $75 shipped to anywhere in the USA. As I get prices from other suppliers, the price will only go down from there.
Is this something that any of you would be interested in at the above mentioned price? Those that already have the 422 cam and springs, is this something you would have considered? If I get some interest, I'll go ahead and order several sets. I do plan to pull my motor again, and put these parts in it.
At the top end of the springs, the stock retainers don't propperly locate the springs. Since Crane no longer makes the correct retainers (someone correct me if I'm wrong, this was true at the time I originally built my engine), I've also designed some retainers that will work. I haven't gotten any prices back on these yet though. I also think that I've possibly found some retainers that Edelbrock is already making that will work. Depending on the prices I get back from my suppliers on these retainers, I will purchase a set of the Edelbrocks to measure and see if they work correctly. I know the spring seats are correct, I just need to confirm that the spring set height is correct.
Once I get some prices from suppliers, I'll decide whether it's worth it to try the Edelbrocks or not. If one of my suppliers gets close to the cost of the Edelbrocks, I'll plan on having those made. If the custom ones are much more, I'll buy a set of Edelbrocks to measure.
Any interest in the custom valve spring retainers?
I appreciate any and all input.
Dual springs with no head machining and stock retainers.
Dual springs with shims on the head and the retainers I designed.
