Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Engine clatter after oil change
Reply
Thread Tools
Old 06-08-2009, 01:51 AM   #1
singularity
Dallas, TX
'98 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hey everyone, after a routine oil change today, I started to hear a clatter from the engine.. it initially sounded like the valvetrain but it gets louder towards the crankshaft region. It's the first time I have actually noted this kind of sound - my friend's Camry made the same sort of noise before the crankshaft bearings were busted.. which is why I'm a little paranoid. It's the second time I changed the oil myself.. did everything as before, I only changed the brand from Pennzoil to Mobil Clean 5000 (same grade 5W-30).. no leaks, oil pressure normal, oil is clear in the dip-stick.. I am at a complete loss as to what the cause is. Please Help!
singularity is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-08-2009, 03:23 AM   #2
Lacky01
Eugene, Oregon
1998 Sport
Vehicle Specs
Quoted: 0 Post(s)
subscribing
mine also makes a "clatter" or a "clacking" sound, but only now and again. I'll pay attention to the circumstances surrounding the noise and try to locate the source.
teamwork people!!!
__________________
98 Ford Explorer Sport 2wd 5spd 4.0L OHV
Current plan: 4WD Swap
and a 79 turbo Cobra work in progress
Lacky01 is offline   Reply With Quote
Old 06-08-2009, 04:48 AM   #3
austinmob
Sydney
96 XLT
Vehicle Specs
Quoted: 1 Post(s)
Its not a chirp sort of sound is it.
austinmob is offline   Reply With Quote
Old 06-08-2009, 07:14 AM   #4
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
What filter are you using? Some of the filters on the market have poor or no anti-drainback valve, which can cause noise due to oil starvation on startup.
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 06-08-2009, 10:52 AM   #5
singularity
Dallas, TX
'98 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for your responses everyone!
Quote:
No. it's more of a mechanical rattle.. sounds quite like a diesel engine.
Quote:
I am using a Super Tech ST8A oil filter. Used to have a Fram PH8A previously.
Started the engine this morning.. didn't have the clatter for about 10 seconds. It is also most noticeable at idle.. I guess at open throttle the clatter is just covered up by the engine noise itself.
Old 06-08-2009, 11:11 AM   #6
patrick112390
chesterfield,va
97' mountaineer 5.0 4406
Vehicle Specs
Quoted: 0 Post(s)
get yourself a real filter! supertech is what-walmart brand?? this is one of those things when you get what you pay for. the only filter i use is mobil 1 and motorcraft. both have the valves to eliminate dry starting..
__________________
97' mountaineer 5.0 V8 4406- k&n intake, hunter brush guard, front/rear tow hooks, 35X14.50 Mud Grapplers, crager soft 8 rims, remote start, shackles, TT, AAL, 3'' pa body lift, 4'' superlift, 4406 swap, 4.88 gears and a full carrier Detroit Locker
patrick112390 is offline   Reply With Quote
Old 06-08-2009, 12:00 PM   #7
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
As said above, get a quality filter like Motorcraft. Fram are junk, and I don't think the Wal-Mart filter is anything special.
__________________
Our Crappy Website
Old 06-08-2009, 12:07 PM   #8
patrick112390
chesterfield,va
Vehicle Specs
Quoted: 0 Post(s)
although if you are in walmart buying grocerys next time-WALMART SELLS MOTORCRAFT FILTERS! and correct me if im wrong bu the last time i was in there you could walk out with one for under 5 bucks...dont skimp on your investment
__________________
Old 06-08-2009, 03:38 PM   #9
Tom G
Lusby Md
99 XLT V8
Vehicle Specs
Quoted: 1 Post(s)
Did you put oil in the filter before you installed it?
Tom G is offline   Reply With Quote
Old 06-08-2009, 04:08 PM   #10
CmdrPopNFresh
Salt Lake City, Utah
'93 Sport
Vehicle Specs
Quoted: 0 Post(s)
yeah a motorcraft filter at walmart is 3.50something. i would higly recommend taking that cheap filter you have off and sticking a quality motorcraft filter on there.
CmdrPopNFresh is offline   Reply With Quote
Old 06-09-2009, 12:16 PM   #11
singularity
Dallas, TX
'98 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hey everyone, thanks for all your input and I took your advice.. I changed the oil filter to a Motorcraft FL-1A but the clatter is still there at idle. Oil levels and pressure are normal. Talked to a few ppl I know.. they said it sounded like the push-rods or the valves themselves.. gonna take it for a run for a few miles this evening to see if it goes away.
Old 06-10-2009, 12:05 PM   #12
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Odd how things manage to go bad at the weirdest times- make you think things are related, when they may not be related at all... Let us know what you find out!
I used to use SuperTech filters, when they first came out, they were much larger, and had a lot more media in them. They actually tested toward the top of the list on oil testing sites- but recently they just seem to be getting smaller, and I've gone back to Motorcraft filters.
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 06-26-2009, 02:28 AM   #13
derek98explorer
Pitt Meadows B.C.
1998 xl
Vehicle Specs
Quoted: 0 Post(s)
hey there i am new to the site. It seems to me that alot of us with the ohv engine have the same problem. Mine too has the clatter noise and it came after an oil change. The rig runs awsome does not miss a beat. I have been to three ford dealerships and none of there so called ford speciallists could tell me what it is or if they even experienced it with another customer. So why the same symptoms and surcomstances for all of us. These threads here about engine clatter,marble sounds,knocking after an oil change all seem to stop. Has anyone ever actually found out what causes it. This noise of a diesel engine is driving me crazy.
derek98explorer is offline   Reply With Quote
Old 06-26-2009, 04:08 AM   #14
Lacky01
Eugene, Oregon
1998 Sport
Vehicle Specs
Quoted: 0 Post(s)
welcome Derek!!!
I've heard rumor of the OHV's making noise from a build-up of carbon? possibly?
a quick Seafoam treatment should clear it up if that be the case...
If my valvetrain is dying then theres only one direction I'm headed:
Turbo diesel!!!!
__________________
Old 06-26-2009, 05:54 PM   #15
derek98explorer
Pitt Meadows B.C.
1998 xl
Vehicle Specs
Quoted: 0 Post(s)
Where could I get seafoam? I live in canada british columbia and no parts stores have heard of seafoam I guess I could hop over the boarder to shucks and see if I could get it there in belingham.
Old 06-26-2009, 06:01 PM   #16
derek98explorer
Pitt Meadows B.C.
1998 xl
Vehicle Specs
Quoted: 0 Post(s)
Also as to motorcraft being a quality filter. I cut one in half and it looks almost identical to a run of the mill fram. I didn't think that a quality filter would cost $3.50 at walmart.
Old 06-26-2009, 07:10 PM   #17
71cutty455
St. Louis, MO
1998 XLT 5.0 V8 AWD
Vehicle Specs
Quoted: 3 Post(s)
I just paid $3.67 for my Motorcraft filter at Walmart 4 days ago. And thank God they dropped the price of Mobil 1 to $22 for a 5 qt jug!!!
__________________
1998 Ford Explorer XLT 5.0 AWD on 22"s
http://www.cardomain.com/ride/2868365
71cutty455 is offline   Reply With Quote
Old 06-26-2009, 08:43 PM   #18
Danson
London, Ontario
2000 Limited
Vehicle Specs
Quoted: 0 Post(s)
timing chain and guides??
Danson is offline   Reply With Quote
Old 06-26-2009, 08:43 PM   #19
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
I just picked up a jug on Mobil1 5W30 also...it said 26.00 on the shelf, but rang up at 22.00.
I was happy!
Ryan
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 06-26-2009, 08:44 PM   #20
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
WalMart also carries SeaFoam....Bellingham or even Tulalip will have it..
Ryan
__________________
Reply
Tags
clatter, crankshaft, engine, oil change, valvetrain
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
