Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How to replace an oil pump in a 1999 2wd 5.0
Reply
Thread Tools
Old 06-10-2009, 11:55 AM   #1
jtj1903
Clinton, MD
1999 Limited 5.0L V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My oil pump keeps making knocking sounds when I turn my car on and off. Also, my oil level gauge flickers up and down whenever i'm not accelerating. I think its priming slow and going bad on me so i wanna replace it. Anyone know to change one in a 1999 2wd 5.0. pics would be great if possible
jtj1903 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-11-2009, 01:00 AM   #2
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
The motor's gotta come out.
The crank counterweights make it impossible to pull the pan off without lifting the motor.
While you are under there, can you measure your driveshaft (and/or take pics of it) from U-joint to U-joint, Center to Center.
Thanks,
Ryan
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 06-11-2009, 01:55 AM   #3
Turdle
Move along people
Humboldt, KS
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 700 Post(s)
Thanks,
Ryan
Ryan, I just did mine without pulling the engine
http://www.explorerforum.com/forums/...ght=purple+pan
I did have a lot to remove due to the suspension lift, however a 2wd should be easy.
the pan will not completely come out, until you remove the oil pickup and pump and drop it in the pan.
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 06-11-2009, 02:00 AM   #4
Turdle
Move along people
Humboldt, KS
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 700 Post(s)
from above thread--engine in truck
You can see, from this point the oil pickup nut, and 2 oil pump bolts can be removed. once the tube is in the pan, the pan will come out--
If you just need to change the pump, well, looky here--
I am glad I was able to prove it could be done. But It was a bummer to do it.
__________________
Jon
2000 Mountaineer
Old 06-11-2009, 09:57 AM   #5
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
amazing!! I am next.... red trucks going into the garage monday, thanks to Jon I plan to have it back out by Friday! Do NOT want to mess with those bellhousing or exhaust bolts again if I dont have too! front end = pffft no problem!!
currently the rzr is in the garage front and center... oh man I thought I was addicted to offroad before....
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 06-11-2009, 10:11 AM   #6
Turdle
Move along people
Humboldt, KS
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 700 Post(s)
The driver side cat pipe may cause some grief. But hey--cut it with a sawzall and have the exhaust shop run a bead if you have to--
__________________
Jon
2000 Mountaineer
Old 06-11-2009, 10:41 AM   #7
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
exhaust shop? LOL I am the shop!
Kidding!!! Little things like this do allow me to work on my welding skills, and then take it in when I admit defeat
__________________
Old 06-11-2009, 05:57 PM   #8
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
...I forgot I was in 2nd Gen....
With a 5.0L in my 1st Gen, I have a true Engine Crossmember, so I will have to lift the motor a bit to do the same thing.
Ryan
__________________
Old 06-11-2009, 10:36 PM   #9
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Quoted: 35 Post(s)
Is the 99 V8 front suspension the same as the V6 front end on the 2wd?
If it is, unless the frame is completely different the pans bolts and the front cover bolts just need to be removed and the pan should drop out of the truck..
I dropped my v6 pan to clean the pan of a ton of sludge and replace the oil pump and after removing 24 bolts, the starter, and the power steering cooler and the pan dropped out into my hands...
Good luck on replacing the pump and pickup...And I hope it fixes your problem.. Mine did!!!
__________________
When in doubt, use a bigger hammer!
2014 Jeep Compass Limited [Company Vehicle]
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
