Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Offroad Tech Forums > Offroad Explorer - Ranger Projects
Notices
Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc.
33" tires with stock axles
Reply
Thread Tools
Old 06-14-2009, 04:10 PM   #1
Xanadu
Ottawa, Ontario
'97 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I'm thinking of running 33"s with the 2" suspension lift and 3" body lift. Will this give me trouble on the trails, as I've only got 3.73 gears?
Should I stick with 31"s until I get new gears?
Any opinions would be helpful
Thanks
Xanadu is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-14-2009, 04:19 PM   #2
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
Which motor do you have?
techieman33 is offline   Reply With Quote
Old 06-14-2009, 06:16 PM   #3
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
Quoted: 16 Post(s)
33s and 3.73 wont cause you troble on the trail. You can use low range. It will cause you trouble on the street. It puts more stress on you drivetrain, kills your gas mileage and just plain take the fun out of driving a lifted X. Lots of people run 33s and a 3.73 axle ratio, I did for about a year. I regeared to a 4.56 ratio and the fun was back.
unclemeat is offline   Reply With Quote
Old 06-14-2009, 06:42 PM   #4
Xanadu
Ottawa, Ontario
'97 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I've got the 4.0 SOHC
Old 06-14-2009, 06:43 PM   #5
Xanadu
Ottawa, Ontario
'97 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I want to get 4.56 gears, but the money isn't there right now. I'm not too worried about the street, cuz I got a sentra, that I drive to work lol
Old 06-14-2009, 06:51 PM   #6
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
You'll be fine with the 3.73, 4.10's would be better though. 4.56 is probably a little overkill unless the explorer is pretty much offroad only, or you plan to go up to 35's.
Old 06-14-2009, 06:58 PM   #7
99ex22
Wilsonville, Oregon
2000 5.0L 4x4 Eddie Bauer
Vehicle Specs
Quoted: 2 Post(s)
yep you will be fine. A air intake and exaughst would help out a little!!
__________________
2000 Eddie Bauer 5.0L Mac, Cat Back, BW 4406, SOA, Sloped body lift , TT, 33x12.5 BFG A/T's
http://www.explorerforum.com/forums/...d.php?t=302807
Lift your explorer!-
http://www.explorerforum.com/forums/...d.php?t=238214
99ex22 is offline   Reply With Quote
Old 06-14-2009, 07:15 PM   #8
Xanadu
Ottawa, Ontario
'97 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I got a K&N intake and a shop near me that's gonna be doing the exhaust in a month or so
Thanks,
Cheers
Old 06-15-2009, 05:20 AM   #9
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
Quoted: 16 Post(s)
Quote:
I have to disagree. IMO,if you go offroad much, or just like good throttle response. My Ranger has 31s 4.0 SHOC, 5-speed and 4.10 axle ratio. It is a luxuary to be able to put down enough torque spin the tires. My 91 X has 4.56 axle ratio with 33s (MT). the 4.56 ratio is just a hair lower (numerically higher) that stock 3.73 and 30-inch tire. With a mud tire, the additional rotational mass on the tire offsets the gearing. One last thing is the fun level. Mashing the gas and something actually happining is the best reason to go with 4.56.
Of coarse, if you spend most of you time on the pavement logging miles, then a 4.10 ratio will give you better gas milage.
Old 06-15-2009, 01:15 PM   #10
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
The 4.10's are also a lot cheaper since you can buy used axles with 4.10's already in them and swap them in yourself.
Old 06-15-2009, 04:08 PM   #11
crazyflights
St. Joseph, MO
97 1 ton Jeep
Vehicle Specs
Quoted: 17 Post(s)
If your gonna use it for offroading and not a daily driver, dont waste your time with 4.10s, run what you have for now but save and get 4.56's u will be glad u did.
crazyflights is offline   Reply With Quote
Old 06-15-2009, 05:43 PM   #12
Dannyboy
Other Make & Models Mod
4348′48″N 9113′59″W
Dannyboy's Avatar
91 4 do'
Vehicle Specs
Quoted: 6 Post(s)
x2...3.73 to 4.10 isn't worth it.
remember, 2nd gen explorers started putting in 4.10 gears with stock 29" tires and their engines produce 50 more hp.
if you're going to do eventually, then buck up and do it now, or wait and risk replacing a transmission.
Dannyboy is offline   Reply With Quote
Old 06-15-2009, 05:47 PM   #13
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
Quoted: 1 Post(s)
So, how bad will mileage be with 4.56s and 33's? If this puts the truck, practically back at stock.. it should get "decent" mileage.. 4.56's seem to be a good happy medium between street and off-road. Am I wrong? I don't see me getting all that torque I started out with back with 4.10s and 33's... I go on a lot of trips, and I ride plenty of trails.
A buddy of mine has an F150 with 33's (and the 5.0L), but he has 3.50's.... oh man.. and he goes on trips a Lot..
__________________
Lifted 98 302
Quote:
Originally Posted by joel903 View Post
These freaken explorers! Everything breaks
Ford: Fixed Or Repaired Daily. But still going, kicking and screaming all the way. =D Yeaaah.
storlied is offline   Reply With Quote
Old 06-15-2009, 05:49 PM   #14
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
I totally agree that 3.73 to 4.10 isn't good for much. This is a 2nd gen being talked about though with the sohc, and a lot of guys seem to be happy with the 4.10 and 33" combo. 4.56 would be better if it was mostly off road but for a DD it seems like 4.10 is the better choice.
Old 06-15-2009, 06:33 PM   #15
Dannyboy
4348′48″N 9113′59″W
Dannyboy's Avatar
91 4 do'
Vehicle Specs
Quoted: 6 Post(s)
33's would be right at stock with a gear ratio at 4.25, those aren't available so you have the choice to go up or down. Also, a 33" tire is around 50lbs (52lbs for a BFG AT) where a 235/75/15 BFG AT is 37lbs. That's nearly 50% heavier at each wheel.
If you're going to pay the money, take the bigger step.
NOW with that said, and I know Techieman experienced this, if you have 3.73s you can probably snag a set at a junkyard from a truck with 4.10 gears, sell your 3.73 setup rear axle and the total cost is probably like $300 vs. $1000 for a gear swap. At that point I support the 4.10 swap.
Old 06-15-2009, 06:47 PM   #16
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
Quoted: 1 Post(s)
When I do the gear upgrade, I'm going to be pulling my front driveshaft and having them do the rear only until I can afford the front... how much is each?... I remember getting quoted $1,200 or so a long time ago.. but that was 4.10's..
__________________
Lifted 98 302
Old 06-15-2009, 07:00 PM   #17
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
Quote:
It's going to depend on the brand of gears, locker or not, and what the shop charges you for labor. But there shouldn't be much if any difference in price for whatever ratio you choose.
Old 06-15-2009, 07:02 PM   #18
alohamonte
Glendale, AZ
1998 Explorer 4.0 4x4
Vehicle Specs
Quoted: 36 Post(s)
I have the 3.73 on a baby 31"s and even a slight incline on the highway requires 3rd gear to get up. Rolling on 33" I'd probably keep the OD switched off anytime I'm going less than 70mph.
I lost at least 2-3 mpg too from 235s vs 31s.
__________________
1998 Xplorer 4.0 OHV 4x4, 3.73 L/S, 31x10.5 Good Year Silent Armor A/T, All Synthetic Fluids, Sony Audio System, Yakima Roof Rack w/ 3rd Crossbar, Bilstein Shocks, Silverstar Ultras, Clifford Alarm & Keyless Entry, Throttle Cable Mod, Moog Front End
alohamonte is offline   Reply With Quote
Old 09-06-2009, 07:08 PM   #19
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
Quoted: 1 Post(s)
Quick question, when going from 3.73 to 4.56 does the carrier have to be changed? I want to retain my limited slip without having to fork out even more money.... do I have to?..
__________________
Lifted 98 302
Old 09-06-2009, 07:11 PM   #20
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
No you will not need to change your carrier. Planning on going up to 35's?
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
