Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
more - electric fan questions - the fan is easy to find... what about wiring?
Reply
Thread Tools
Old 06-19-2009, 09:23 AM   #1
rama1200
Jackson, MS
2004 explorer xls
Vehicle Specs
(Original Poster)
May I should post this here???
Ok.... it looks like finding a fan and mounting it is not that difficult... what really bothers me is the wiring... now it turns out that you need to think about your ac, thermostat...
let's say I get a nice fan, mount it, etc... will this supply everything else I need?
http://summitracing.com/parts.aspx?sku=HDA-3651
Thanks
rama1200 is offline   Reply With Quote
Old 06-19-2009, 10:21 AM   #2
Gold Bob
Millican, Texas
2002 XLT
Vehicle Specs
that should cover everything. the only problem I see is where would you mount the sensor. the ones I have used in the past have the sending unit attached to the radiator fins.
you will probably have to tee off the current temp sender to mount the new sending unit. maybe some else knows of a better place.
__________________
Jeremy
2002 XLT, 4.6L, 4x4, Towing package
Gold Bob is offline   Reply With Quote
Old 06-19-2009, 12:10 PM   #3
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
When we installed an e-fan into a friends f-150 we were looking at the same kind of controller.. A couple thing to consider. How many amps is the fan your going to install going to draw? In our case, we were expecting 50+ amps (Lincoln Mark VIII fan). Thats more draw than most of the controllers we saw could handle, and at the time I wasn't comfortable going to a PWM controller (I still see conflicting information on them with high amperage fans).
We decided to spend a little more and get a Dakota Digital PAC-2000.
The extra features the PAC-2000 has that we wanted were..
Fan start delay - It won't turn the fan on until 5 seconds after the engine is running. This helps keep the draw off the battery until the motor is up and running.
Fan stop delay - We have it set so if the fan is running when the truck is turned off that it will keep the fan running for 30 seconds (you can make it shorter or longer). This helps keep the heat soak down.
The way we have it hooked up, the fan will always start if it reaches 210F water temp.
If the a/c bypass switch is flipped the fan won't turn on with the a/c but it will still turn on when the temp reaches 210.
normally, turning on the a/c will turn on the fan. We added a bypass switch since you don't need the fan when your going down the freeway for the a/c.
Here are the pics from the install. http://www.explorerforum.com/forums/...ght=taurus+fan
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
