#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Evap emission Control Sys Pressure Sensor
Reply
Thread Tools
Old 06-19-2009, 05:53 PM   #1
bigglok03
Born in Queens,NY raised in Lithonia,Ga
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Talking Evap emission Control Sys Pressure Sensor
I took my 98 Explorer Sport to get an emissions test and I failed. The code it came back with was P0453(Evap Emission Control Sys Press Sensor High Input). How would I go about fixing this? Is it as simple as replacing the sensor?
bigglok03 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-19-2009, 06:09 PM   #2
Dilbert5
austin
97
Vehicle Specs
Quoted: 0 Post(s)
before yo replace the sensor, you need to check voltages. Do you have a DVM? if so. The sensor has three wires.
GY/R grd
BR/W ref voltage
R/PK sensor output goes to pin 62 or 82 of pcm (my shematic is hard to read, not 100% sure). Verify the correct wire color code.
You should be able to read the 5 volt ref, then see what the sensor output is reading. According to my schematic, it should be 2.37 v (with gas cap off). If you read something close to this. The next step is to verify the voltage at the PCM.
My schematic is a little hard to read, hence I am not positive which pin, but you should be able to follow the color code.
Dilbert5 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
