Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
97 Ford Explorer will not come out of park.
Reply
Thread Tools
Old 06-19-2009, 09:42 PM   #1
RJSNASCAR
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Was wondering if any body knows what to do when your vehicle will not move out of park. I have a 97 explorer .. automatic 6 cyclinder 4.0L put it in park got back in to leave and it will not come put of park. Any suggestions would be appreciated. Thanks
RJSNASCAR is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-20-2009, 10:05 AM   #2
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Quoted: 300 Post(s)
It is in a driveline bind. Try to rock it back and forth to relieve the pressure. If that fails, block the front tires, jack up the rear end by the differential to lift both tires barely off the ground. Grab one tire and move it forward and back a little. Either carefully try to move the gear shifter at this point, or lower the truck, then try it.
__________________
The Black Hole
Pugly
gmanpaint is online now   Reply With Quote
Old 06-20-2009, 10:26 AM   #3
Willard
Bloomington, Indiana
04 Ranger Edge
Vehicle Specs
Quoted: 1 Post(s)
It's either that or the shift interlock isn't working. It is triggered by the Brake on/off (BOO) switch. Are your brake lights working? That will tell you if that switch is bad. If not that the solenoid that triggers the interlock could be bad.
__________________
Jesse
'94 Eddie Bauer DD/Beater
"Old Faithful" RIP
'04 Ranger Edge DD "Black Knight"
You want to see my face?
Willard is offline   Reply With Quote
Old 06-20-2009, 10:31 AM   #4
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Quoted: 300 Post(s)
Great catch! Forgot about the interlock.
__________________
The Black Hole
Pugly
Old 06-21-2009, 12:48 AM   #5
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 426 Post(s)
Welcome to this forum! I've moved your thread to the stock 95-01 section. Check the fuses. The interlock solenoid is electric. It won't activate if there is no power in the circuit.
BrooklynBay is offline   Reply With Quote
Old 09-17-2009, 04:40 PM   #6
wow97
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
Doh!
Quote:
you have a BAD BRAKE LIGHT SWITCH IT HAD TO ME AT MALL STUCK GAS STATION MY DAD BYPASS SO I GET INTO DRIVE WHEN I GOT HOME MY DAD FIX WIRING TO BRAKE LIGHT SWITCH AND I PUT NEW BRAKE LIGHT SWITCH AFTER THAT NOMORE PROBLEM MY WIFE SAID YOU BUY BRAKE LIGHT SWITCH NOW
Old 09-17-2009, 05:36 PM   #7
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
wow...
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 09-17-2009, 07:22 PM   #8
Willard
04 Ranger Edge
Vehicle Specs
Quoted: 1 Post(s)
Is that English?
__________________
Jesse
"Old Faithful" RIP
Old 09-17-2009, 10:10 PM   #9
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Quoted: 300 Post(s)
Goonie Goo Goo!
__________________
The Black Hole
Pugly
Old 09-18-2009, 07:30 AM   #10
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
If you cannot pull the shift lever towards you with the ignition on and your foot on the brakes, the problem is with the interlock. A bad brake light switch, blown fuse, or other broken circuit can cause the brake-shift interlock to not release the lever. That's the most likely culprit.
The quickest way around it in a bind is to unlock the steering column by turning the key to the UNLOCK position, but NOT to the RUN position. If the dash lights up or the radio comes on, you turned it too far. Then, depress the brakes, and shift to NEUTRAL, then start the engine. You'll have to repeat the sequence every time you want to start it until you solve the problem, but it can be done.
As mentioned, it's likely either a blown fuse for the brake on-off switch, a bad brake on-off switch, or a wiring issue.
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
