Mussin
- February 24, 2008
- Lima,Ohio
- '02 Mountaineer
Going to work today the transmission in my 2002 merc mounty (v8 AWD) shifted hard a few times then the o/d light started flashing rapidly and the cluster said "check Transmission".... I only live 3 miles from work. After work I drove it home and it didn't want to shift gears until I let off the gas. Eventually the O/D light began flashing.. It seemed to drive fine while in gear but up and down shifting it seemed lost. Sometimes it worked fine sometimes I had to feather the gas to get it to shift. I only drove 35mph tops so I don't know what the OD did if anything. What do you guys think I am looking at here?? Valve Body? solenoid pack?? complete tranny? What tranny do I have? My wife has a 2002 mounty as well but it is a V6, does it have the same transmission? I can work on cars so if it is just replacing the VB or solenoid pack I can do that.
THANKS
Jeremy
THANKS
Jeremy
