Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
power window motor removal?
Reply
Thread Tools
Old 06-20-2009, 04:17 PM   #1
red.EDDIE.4x4
Tulsa, Oklahoma
'93 Eddie Bauer 4x4
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
hey guys, my power windows on my 93 Eddie Bauer are not working quite right. when i push the button to go up or down all i hear is a clicking noise and sometimes the window goes up or down and sometimes it doesnt. i know the motor is turning because i can feel it. most of the time i end up hitting the button and pulling it up. i figured it must be a gear on the motor that is either stripped out or missing teeth. but when i went to take it out i only can take out one bolt. the rest of whats holding the motor in are rivets.
so is there a way for me to take it out? or am i gonna have to take it into a shop? any suggestions?
red.EDDIE.4x4 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-20-2009, 04:24 PM   #2
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
http://www.explorerforum.com/forums/...t=window+motor
techieman33 is offline   Reply With Quote
Old 06-20-2009, 06:18 PM   #3
red.EDDIE.4x4
Tulsa, Oklahoma
'93 Eddie Bauer 4x4
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
thanks! that helped alot on the rear windows.
but what about the front windows? same type of thing? because all i see are rivets...
Old 06-20-2009, 06:21 PM   #4
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
yeah it's basically the same for the fronts, you have to drill the rivets out, and then put new rivets in, or bolt them in.
Old 06-20-2009, 06:35 PM   #5
Titan09
Southeast Georgia
'93 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
No...you do not,
I repeat...DO NOT!!!!!!!! need to drill out the rivets if all you are doing is replacing the motor. I just completed this project on my '93 Sport.
You have to drill out one of the dimples in the door (it's covered up by the lower left part of the speaker mount, so you'll be able to see it when you take out the speaker) with a 1/2" drill bit to expose the third screw. Take out the screws, and the motor drops out. The two other screws are behind holes that are just to the left of the speaker. Re-installation is the same thing in reverse.
It's a delicate operation...It's a lot tougher getting the motor re-installed, but it will align itself once you tighten down all the screws. The rivets have nothing to do with mounting the motor, and you'll make the project a lot harder than it has to be if you just need to replace the motor.
Titan09 is offline   Reply With Quote
Old 06-20-2009, 08:39 PM   #6
red.EDDIE.4x4
Tulsa, Oklahoma
'93 Eddie Bauer 4x4
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
thanks guys! titan was right about the little dimple. all went well. only drawback was that the little bushings were 9 bucks a set
Old 06-20-2009, 08:59 PM   #7
Titan09
Southeast Georgia
'93 Sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
Well, at least you didn't have to spend $50 for a new motor, like I did...heh
Old 06-21-2009, 03:00 AM   #8
dansnyder22
Ogden, Utah
1993 XLT, 5 speed
Vehicle Specs
Quoted: 0 Post(s)
Quote:
ohhh nine bucks, let me cry for you
__________________
1993 XLT 5 speed currently Stock lift and 31 BFG A/T
1992 Eeddie bower in the process of becoming a Crawler
Upside down and on fire - A situation to be avoided
dansnyder22 is offline   Reply With Quote
Old 06-21-2009, 08:59 AM   #9
red.EDDIE.4x4
Tulsa, Oklahoma
'93 Eddie Bauer 4x4
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
i was expecting them to be more like 5 or so.
Old 07-07-2010, 08:59 PM   #10
mfreedog
maysville,Ky
1999 xlt
Vehicle Specs
Quoted: 0 Post(s)
I had trouble with my drivers side motor and I took the motor out plugged it in and it started working. I greased the rails and it took off fine and so far so good.
mfreedog is offline   Reply With Quote
Old 07-07-2010, 09:06 PM   #11
92exp4x4
Covington, Kentucky
92 XL 2-door and others
Vehicle Specs
Quoted: 1 Post(s)
Did you buy the HELP brand part? I have always ordered a gear kit from ford for a full size truck (87-91). Its about $25 per kit, but it comes with a tube of grease and a new center gear. The white plastic one is the only difference.
Whats the HELP part number if you have it?
__________________
My stable:
2 doors - '91 Eddie Bauer; '92 XL 5 spd; '92 Sport 2WD 5 spd
4 doors - '93 XLT; '94 XLT, 6" lift, 33's; '94 Eddie Bauer 5 spd; '94 Limited
Others - '22 Model T, '62 Fairlane 500, '93 F-Superduty 460 5 spd, '93 Aerostar 4.0 LWB, '95 Aerostar, '01 Mazda B2300 5 spd (wifey's) '15 F750 service truck (company owned)
92exp4x4 is offline   Reply With Quote
Old 10-12-2011, 12:11 PM   #12
o' dannyboy
big apple
'93 xlt
Vehicle Specs
Quoted: 0 Post(s)
My window froze in the down position. The switch activated a clicking sound in the door but the window would not budge. The switch seemed to work but the motor seemed shot.
If you think it's the motor DO NOT REMOVE THE REGULATOR!!! You don't need to in order to replace the motor. The motor comes out independent of the regulator. No rivet drilling, no replacement bolts or any of that!!! If it's not the regulator - leave it alone except to lubricate it!!
Drilling the 1/2" hole is no big deal but do not go too far, be gentle, the bolt is right there. (Ford™, PLEASE HELP US UNDERSTAND WHY THE DIMPLE AND NOT A HOLE???)
Remove the speaker and all the mysteries of the inner door are revealed. You can see the motor and get your hand in there to remove it.
For me, prior to installing the new motor, I removed the old motor, plugged in the new motor to test it and discovered it worked fine. And then, for the hell of it, I plugged in the old motor while it was out to test it. IT WORKED FINE, TOO!!!
I generously lubricated the regulator tracks with lithium grease and sprayed some Tri-Flow™ into pivot points, reinstalled the OLD motor and ran it for a good quarter hour; up and down, down and up - works like a charm!!! Better than before! Maybe a loose connection or a rusty joint or track??? Who knows?
Took the new motor back to AutoZone®!
Net cost: $0.
o' dannyboy is offline   Reply With Quote
Old 09-08-2015, 09:44 PM   #13
RevForever
Denver, Colorado
1993 Ford Explorer 4wd
Vehicle Specs
Quoted: 0 Post(s)
Thanks about drilling the dimple!
Titan09 thanks a ton for discovering the dimple; can't imagine how you figured that out! Worked like a charm on my 1995 Explorer Sport. Once removed, my motor tested fine and I tested the switch tested fine too, so I took the other advice and lubed the heck out of the rails and joints. I'll enjoy it while it works but it's mysterious!
Last edited by RevForever; 09-08-2015 at 09:46 PM. Reason: Forgot vehicle model and year
RevForever is offline   Reply With Quote
Reply
Tags
first gen, power windows, window motor
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
