#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Rear end roar-is there a fix?
Reply
Thread Tools
Old 06-23-2009, 11:26 PM   #1
davedwards
Mount Olive NC
2004 Explorer LTD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
04 explorer limited V8 automatic 4x4.I'm hearing quite a bit of noise in the rear end when accelerating or cruising at speed.My wife said I was dreaming,but I took a ride in the back seat today and the roar is much more noticable there.When you let off the gas,the roaring stops.Is there a fix for this without having to sell a kidney to pay for it? Thanks
davedwards is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-24-2009, 09:46 AM   #2
Curtis
Orlando, FL
04 XLT 4x4
Vehicle Specs
Quoted: 6 Post(s)
02's and early 03's tend to have rear end roars... havnt seen too many 04's with the problem.
Are you sure its the rear end? Usually the roar happens when you let off the gas and coast instead of applying gas.
Maybe a rear wheel bearing?
__________________
Curtis
2008 Expedition EL Limited
2004 Explorer XLT 4x4 4.6
1970 Buick GS 455 Silver Mist
Curtis is offline   Reply With Quote
Old 06-25-2009, 12:11 PM   #3
Cgy04XLT
Calgary,Alberta
04 XLT
Vehicle Specs
Quoted: 0 Post(s)
You might want to start here...I am not sure if you have this issue but it solved the vibration issue when at steady speeds and when accelerating as well as the low speed rub/vibration when turning I had as well.
Check out this link.......
http://www.explorerforum.com/forums/...15&postcount=2
Hope it helps you out!
Cgy04XLT is offline   Reply With Quote
Old 06-26-2009, 12:47 AM   #4
cross6
Baton Rouge, LA
2004 Mountaineer
Vehicle Specs
Quoted: 31 Post(s)
My 04 suffered from the infamous rear end diff failure that caused this roaring. Replaced under extended warranty.
cross6 is offline   Reply With Quote
Old 06-27-2009, 12:07 PM   #5
007
Midwest
04 XLT Sport V8
Vehicle Specs
Quoted: 0 Post(s)
Quote:
If you are referring to the ring and pinion epic fail, then our '04 did that also by 35k miles. It was replaced and now is doing it again at 120k. Guess what...it's going to stay howling at 60 mph until it breaks this time.
__________________
James
007 is offline   Reply With Quote
Old 06-28-2009, 07:07 PM   #6
757 MC
Waconia, Mn.
2004 Limited 4.6l
Vehicle Specs
Quoted: 0 Post(s)
I am having this same issue with my '04. Does anyone know how much this repair costs? Has Ford come up with a perminent fix yet?
757 MC is offline   Reply With Quote
Old 06-28-2009, 10:41 PM   #7
Fox Fader
Columbus, GA
searching
Vehicle Specs
Quoted: 0 Post(s)
Mine dose it too once the fluid gets good and hot, but who cares this is something they do and with these being connected to the body, the sound is magnified.
__________________
_______________
2005 XLS 115k not even side steps (sold)
2001 Sport-Trac 131k Wife's
Fox Fader is offline   Reply With Quote
Old 06-29-2009, 03:19 AM   #8
gforceman
Virginia beach VA
2003 limited 4.6 V8
Vehicle Specs
Quoted: 0 Post(s)
basicly i feel 3 gen expos are just throw away vehicles drive just before thet fail then trade in or sell ,
i have a 03 Eddie 4.0 174k ,
problems:
1 Rubber around both front balljoints dryrotted cracked .
2 rear differential whines.
3 driveshaft makes a crack sound in reverse.
4 rear seals leak
5 replaced front wheel bearings
6 rear wheel bearings starting to let go
7 i suspect timing chain slack .
i am now looking for a replacement and i wont be a explorer this was my 2nd one
__________________
2003 Limited 4.6 All Black
gforceman is offline   Reply With Quote
Old 06-29-2009, 07:02 AM   #9
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
problems:
4 rear seals leak
What you describe are not-so-uncommon things for a vehicle with that kind of mileage....especially if never replaced before. Timing chain, ball joints, bearings....all at 174k....sounds typical to me.
The whine is common on the 3rd gen's, I'm still debating whether to have mine fixed (again?) or not....the diff clutch pack and ring/pinion was replaced when it was under warranty from the previous owner, at around 40k miles with the same sounds, now I'm at 126k and the sounds are here again....this time it would be on my dime to fix.
I wouldn't really call them throw-away vehicles, but if you do not maintain them at regular intervals....things go. Don't expect ball joints to last for 200k miles.
thepotroast is offline   Reply With Quote
Old 06-29-2009, 09:14 AM   #10
Fox Fader
Columbus, GA
searching
Vehicle Specs
Quoted: 0 Post(s)
I agree on the ball joints, the need changing before you get to 100k normally. Had to replace all four on the '97 at 88k, what a pain. The uppers on te 05 need doing now, looks like the will be a lot easier.
__________________
_______________
Old 06-29-2009, 10:51 AM   #11
Thelt
Lenoir, NC
2002 Limited
Vehicle Specs
Quoted: 1 Post(s)
Quote:
If you are sure it is not your rear wheel bearings then change the fluid in the rear end making sure to get the right friction modifiers.
If the sound changes when you turn left or right then it is probably your wheel bearings. They are known to go out on third gen explorers
__________________
2002 Explorer Limited, V6, 3.73 limited slip
265/75/16s
Blacked out trim
Thelt is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
