Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Massive transmission fluid leak
Reply
Thread Tools
Old 06-24-2009, 05:20 AM   #1
deamon3
Wisconsin
94 Eddie Bauer
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
So I was in my garage when I slid and almost killed myself on a pool of what looks like tranny fluid (burgondy color). So I go out to my explorer in the drive way , and there is a trail of tans fluid leading out of my driveway , it goes for over 3 miles away from my house! I must have lost one or two quarts.
The only thing I can say I did differently today then I did other days , was pull a loaded lawn mower trailer for maybe a half hour.
I should also add that my transmission fluid also disappeared a few weeks ago after I pulled a boat for a few hours. I put 3 quarts in a after that, and today I pull another trailer and it looses it all again???? What wrong with this thing?
deamon3 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-24-2009, 07:44 AM   #2
924dr4x4
philly,pa
92 xlt 4 door 4x4
Vehicle Specs
Quoted: 0 Post(s)
where is it leaking from exactly on the truck?if its in between the engine and trans where they bolt up at it could be torque converter or pump seal,or could be the trans pan gasket if coming from the bottom of the trans....does your x have the external trans cooler??if so it will be right behind the grille but infront of your condenser for the truck...check the lines for the trans cooler make sure the screws are tight that hold the lines on
__________________
john
-97 explorer limited,awd v8,stock for now
-92 4 door 4x4,fully loaded leather gut,8.8 rear,dana 35 ttb
-86 mustang gt,5.0,5spd,aftermarket cam,ported and polished intake,ported and polished heads,flowmaster 2 1/4" dual exhaust,headers,high flow mid pipe,8.8 posi rear 3.73 gears
924dr4x4 is offline   Reply With Quote
Old 06-24-2009, 09:43 AM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 425 Post(s)
Put it up on ramps to see where the fluid is leaking from.
BrooklynBay is offline   Reply With Quote
Old 06-24-2009, 12:38 PM   #4
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
If it's ONLY happening when you are towing, it's the front Seal on the transmission.
Ryan
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 06-24-2009, 12:42 PM   #5
Ford_Racing_Guy
Spencer, Wisconsin
'92 XLT & '98 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
i recently had a transmission leak on my 92 on one of the lines leaving the transmission, it was rusted through and i didn't notice it right away because it was dripping on the exhaust burning before it started hitting the ground.
__________________
1998 XLT
98 F250 XLT L/D
97 Ford Thunderbird LX
06 Yamaha R1
Ford_Racing_Guy is offline   Reply With Quote
Old 06-24-2009, 01:12 PM   #6
deamon3
Wisconsin
94 Eddie Bauer
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Mine leaks right where the engine connects to the transmission , it's all over the place underneath. Although when I bough the car it already had the transmission fixed or replaced and the seal looks new.
Old 06-25-2009, 01:12 AM   #7
deamon3
Wisconsin
94 Eddie Bauer
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
OK I put more transmission fluid in and now it's not leaking. I think It just leaks when I tow stuff , so I'll be sure not to tow anything anymore lol.
Old 06-25-2009, 01:20 AM   #8
BrianDye
I'll have another...
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 79 Post(s)
Hm, this might sound retarted, and maybe I am, but maybe when your pulling all that weight, its maybe "stretching your explorer"... as in, pulling, so the trans is moving back just a micrometer and thats enough for the fluid to say byebye...?
Check all the bolts holding it on, and check the gasket see if theyre on right, and tight lol
__________________
06 Charcoal Beige XLT
Debadged in back, removed pin stripe, tinted fogs, LED conversion, black headlights w/Morimoto Mini retro, xB LED Halos, black bentley style grille, Tan cloth interior swapped w/black carpet, black leather/power/heated seats from a Limited
BrianDye is offline   Reply With Quote
Old 06-25-2009, 03:04 AM   #9
deamon3
Wisconsin
94 Eddie Bauer
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
The thing is , when I lost the fluid , I wasn't pulling anything the explorer was by itself. But earlier that day I was pulling a unnecessarily heavy trailer (built by idiots) with a mower on it.
Your idea sounded good but I think it would only technically stretch if only the front wheels were engaged and not the back?
Another point I should make is it was very hot that day and the engine may have been hot , where I touched the prop rod for the hood (had to jump the mower) it was very hot. Loose bolts sound like a good place to start maybe. Maybe theres some kinda heat expansion thing going on.
Old 06-26-2009, 07:32 AM   #10
rayford2
Clarion, PA
'94 XLT
Vehicle Specs
Quoted: 0 Post(s)
US
Don't forget the rear seal your drive shaft spline goes through...Ray S. in PA
rayford2 is offline   Reply With Quote
Old 10-07-2009, 11:23 AM   #11
John A Rossi
Norristown, Pa.
94 Eddie Bower
Vehicle Specs
Quoted: 0 Post(s)
TRANSMISSION LEAK "HELP"
Sorry to jump in but I`m not sure where to post.
Yesterday after a full tune up I started up my 94 EX which has not been running for 4 years. It ran for about 45 seconds then put in reverse to go for a short test drive. when the accelerator was easily pushed to back up, the truck seemed to somehow be stuck and not move. This occured only for a moment then started to reverse. Immediately the trans fluid started to pour out in front of the transmission. Repair shops speculate that the front trans seal had dried up from sitting so long and tore. It really poured out in a steady stream. Minimum cost - $800 quoted to replace front trans seal. This was a very gently driven truck with 115,000 miles and the trans fluid had been changed at 70,000 miles. There was no issues with it when parked, Just that the owner got too old to drive and gave it to me. What are the possible simple places that the fluid could be coming from that I can check, before I take it in for service and get a big bill. Does this diagnosis sound like the likely cause?
( I DON`T TRUST TRANSMISSION SHOPS). All responses greatly appreciated.
JOHN.
John A Rossi is offline   Reply With Quote
Old 10-07-2009, 12:43 PM   #12
Masterd
Upland, CA
1993 Explorer Sport
Vehicle Specs
Quoted: 3 Post(s)
Deciding what you should repair depends on the condition of the tranny. If it just thef front pump seal, and the rest of the tranny is Ok, then go ahead and do it. But with 115k on it, and with how weak these trannys are from the factory, I'd be a bit weary.
Is the fluid a nice pink color, or is it more of a brown/black? Thats a good starter indication.
Masterd is offline   Reply With Quote
Old 10-07-2009, 12:49 PM   #13
deamon3
Wisconsin
94 Eddie Bauer
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Just buy some transmission sealer stuff. Thats how I ultimately fixed mine. Cheap and simple.
Old 10-07-2009, 01:08 PM   #14
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 425 Post(s)
The front seal usually blows out while it's hot, and driving on the highway at a highway speed, and not when you first start it up. I believe that one of the cooler hoses might be bad.
Old 10-07-2009, 02:12 PM   #15
John A Rossi
Norristown, Pa.
94 Eddie Bower
Vehicle Specs
Quoted: 0 Post(s)
Fresh and pink!!!
Old 08-28-2011, 07:55 PM   #16
jsnance
leland, nc
1993 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
US Shawn explorer tranny leak
ok...i have a 1993 explorer with the 4 litre and the A4LE transmission with only 86k original miles.....have no transmission leak until i tax the transmission ...ie using 4 wheel drive on hills in wam weather....when the engine gets warmer than usual the fluid will srew out until its empty...i can refill it and drive it normally for hours with no leaks whatsoever....the transmission was just flushed and refilled, the thermostat replaced, and the cooling system flushed and refilled, and i also blew out the transmission cooler to make sure it wasnt plugged...transmission gives me no problem until i stress it a little....i have also ensure the trans is not overfilled...any help here would be great
jsnance is offline   Reply With Quote
Old 08-28-2011, 07:57 PM   #17
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 425 Post(s)
Welcome to this forum! The front seal blow out problem is a common issue. Did you check the coolant level in the radiator?
Old 08-29-2011, 12:57 AM   #18
69Explorer69
Hagerstown MD
94 XLT 4x4 4dr
Vehicle Specs
Quoted: 0 Post(s)
sounds like something my a4ld did to me..i pulled a yard mower not even for 10 miles back to my house.the nest day i am driving down the highway and it wouldnt shift into any gears.So i pull over to find what looking like 1-2 quarts of trans fluid all over the bottom of my trans it looked to be coming from were the trans bolts to the engine..i had to walk to get some trans fluid by the time i got bad i guess it cooled off enough for the seal to fall back in place.i guess the heat softend the seal up and was allowing it to leak.Filled it up was good to go..
i was about 25-30 miles from my house so i turn around just to be safe and head back home i swear i was not even 1/4 mile from my house and there goes all my fluid again i was so fing pissed i wanted to burn the damn explorer up.I push it home and see that its leaking from the same spot...i knew it had to be the seal..so i started to take it apart with alot of help with people from this site and boy did they save the day.i didnt have a clue how to drop a trans. I guess all i am trying to say is SCREW that high dollar bill that a trans shop wants to do it..go buy your self a nice tool set and do it your self...thats just my .02 thanks
__________________
Save A Firetruck Ride a FireMan
69Explorer69 is offline   Reply With Quote
Old 08-29-2011, 02:05 PM   #19
jsnance
leland, nc
1993 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Yes coolan level regular....however....when ever this happens seems the coolant in the reserve tank is boiling although the temp gauge indicates no overheat...just replaced the thermostat and flushed radiator...perplexing that the trans dosent leak constantly.....
Old 08-29-2011, 07:40 PM   #20
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 425 Post(s)
Check the fan clutch.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
