#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
4.0 SOHC Thermostat housing
Reply
Thread Tools
Old 06-28-2009, 07:21 PM   #1
rmelo99
Bridgeport, CT
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've developed another leak at the thermostat housing on my 1998 4.0 SOHC.
I've found the post to upgrade to a better assembly, and I would be inclined to do so however the posts says to reuse the old upper half of the housing and that's where my problem is.
I found a "non-oem" upper half at autozone to replace my cracked factory one. That worked for a couple months and another leak. I'm on my second one and same problem. I think the aftermarket one warps or something.
I either need to located a "good" oem upper half to put on my existing lower, or do the uprgraded swap and still need an upper?
Please help. The explorer has been out of commission since end of winter!! Need to get this bad boy fixed!!
rmelo99 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-29-2009, 10:38 AM   #2
slowsn
mcminnville, tn
98 EB Explorer
Vehicle Specs
Quoted: 0 Post(s)
two days ago i noticed this exact same leak on my 99 eddie. im hoping my thermo housing isnt craked and its just the gasket. my local advance auto parts has the felpro replacelment and a stant thermostat for about $16
ill be following this thread for any advice/info
slowsn is offline   Reply With Quote
Old 06-29-2009, 11:32 AM   #3
rmelo99
Bridgeport, CT
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Not sure who made the replacement I purchased but it looks like the stock on...but is not the same.
When I put the first one in I had to cut about 1/4"or so of the hose bc of the outlet angle being off by just a bit.
The 2 I've had seem to warp and leak on the backside where there is no screw. The 3 screws are all along the front.
Old 06-30-2009, 12:51 PM   #4
rmelo99
Bridgeport, CT
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok, so I bought aftermarket thermostat housing cover number 3.
It was reinstalled yesterday, this time with some (cough) gasket sealer in a tube around the rim.
I'm letting it setup overnight(full cure time) and will fill up with antifreeze today.
I'm all for doing the upgrade to the sport-trac thermostat housing, but I need some help on the original post!
Old 06-30-2009, 07:27 PM   #5
rmelo99
Bridgeport, CT
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok, so I filled up the car with water to do a leak test. I ran it for a while and all was good.
Then water started leaking from below. I can't tell where the water is coming from but it doesn't appear to be coming from the thermostat housing. It was more than a drip, more like slow leak.
The lower radiator hose looks ok. Not new but ok.
Does that hose go to the engine or up to the lower part of the thermostat housing?
Help me find this leak where else could it be? The engine oil is ok, I think that means I'm ok with gasket right?
Old 07-02-2009, 07:26 PM   #6
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
Check the bypass hose.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 07-02-2009, 09:58 PM   #7
rmelo99
Bridgeport, CT
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok...back to square one. Good news is I found the leak, bad news is it's the upper housing cap.
These aftermarket ones from AutoZone are not 100% like the stock one. The water outlet/house connection angle is off by just a few degrees.
If I put the housing in place w/o the hose connected it sits flat all around.
Because of the angle difference there is not enough clearance for the hose. The outlet touches a "vaccum" or some other line that sits behind the thermostat housing. When the hose is connected it pushes up against that line and lifts the housing in the rear, therby causing a leak.
So I need to get another stock housing cover or a better aftermarket one.
No more autozone. I checked RockAuto and they carry 2 different ones. One by ACDelco and another by FourSeasons.
I fear this will happen again with another aftermarket one. You can't buy the stock one from Ford as many others have found.
HEEELLLLPPP!!
Old 07-06-2009, 11:24 AM   #8
rmelo99
Bridgeport, CT
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Anyone use the ACDelco part? It's $38 and the local parts place can get it for me....but I need to be sure I won't have the same problem.
Old 09-07-2010, 11:29 PM   #9
FL Sparky
Jacksonville, FL.
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
What was your final solution? I have a 2002 with the 4.0 and have a leak at the mating line.
FL Sparky is offline   Reply With Quote
Old 10-13-2010, 04:34 PM   #10
ucluglee
Greenville, SC
'00 XLT
Vehicle Specs
Quoted: 0 Post(s)
My 2000 with 188k miles is now showing signs of this exact same thermostat housing issue. I had it pressure checked this morning and was told the leak was coming from "around the temperature sensors". I then Googled and found this site. Looks like I may be in for a housing replacement. I will investigate further in the next few days.
ucluglee is offline   Reply With Quote
Old 10-13-2010, 08:33 PM   #11
ucluglee
Greenville, SC
'00 XLT
Vehicle Specs
Quoted: 0 Post(s)
Ok, I looked closed this evening when I got home and there is a bit of antifreeze buildup on and around the thermostat housing. I was unable to get a real close look at it as the intake manifold was in the way, but from researching this and other message boards, it's a pretty safe guess the housing could be cracked and leaking. O'Reilly Auto can get me a Dorman replacement for $149. My question is, can this be replaced without removing the intake manifold?
http://www.oreillyauto.com/site/c/de...0420&ppt=C0331
Old 10-18-2010, 09:23 AM   #12
ucluglee
Greenville, SC
'00 XLT
Vehicle Specs
Quoted: 0 Post(s)
Let me ask another question. My brother-in-law works for CarMax and he can get me a replacement housing at a great price. My question is, my current housing has 2 sensors attached to it, and they appear to be the "o ring" type. My new housing has threaded connections. Does anyone know (1) what the part numbers for the sensors are, and (2) what are the sensors? I know one is the temp sending unit but what is the other one?
__________________
Previous
1984 Bronco II 2.8 V6 312k miles
1992 Ranger 3.0 V6 394k miles
Currently
2000 Explorer XLT 4DR 2WD
4.0 V6 SOHC 217k miles
Old 10-18-2010, 10:05 AM   #13
sabasigh
STL Metro East, IL
sabasigh's Avatar
'05 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
I believe the unit closest to the tensioner is the ECT and the unit to the left of it (as you are looking at them) is the Temp Sending unit.
http://www.explorerforum.com/forums/...9&postcount=10
http://www.explorerforum.com/forums/...d.php?t=165007
sabasigh is offline   Reply With Quote
Old 10-18-2010, 11:18 AM   #14
ucluglee
Greenville, SC
'00 XLT
Vehicle Specs
Quoted: 0 Post(s)
Ah, I see. Thank you very much.
__________________
Previous
Currently
Old 10-18-2010, 11:41 AM   #15
joecrna
Las Flores, CA
98 XLT 4X4 sohc
Vehicle Specs
Quoted: 28 Post(s)
Just replaced mine last week. Crack on underside. Had to pull the intake to swap. Now the horrible news. Used the Ford redesined one (made in Mexico, not Germany). Had to use new sensors, Thermostat and bypass hose. $350 in parts alone.
__________________
Joe
98 XLT 4X4 sohc
TT, Custom Deaver leafs, 31x10.5 BFG's
Custom skid plates, recovery shackles
Defender rack, Warn transformer mount
and winch
joecrna is offline   Reply With Quote
Old 10-18-2010, 11:57 AM   #16
sabasigh
STL Metro East, IL
sabasigh's Avatar
'05 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
I just got my parts in from midtennfordparts.com and the DY1004 sensor came without an o-ring. Is that right?
Can I get one at the parts store?
Not to hi-jack this thread...sorry.
Old 10-18-2010, 01:22 PM   #17
ucluglee
Greenville, SC
'00 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Thanks joecrna. That's typical for the way my luck runs. I'm hoping you only had to remove the upper intake and not the whole thing. I'll probably be able to get the parts through my bro-in-law for about $200. Now I just have to find the time to get it done.
__________________
Previous
Currently
Old 12-05-2010, 08:56 PM   #18
ucluglee
Greenville, SC
'00 XLT
Vehicle Specs
Quoted: 0 Post(s)
Done.
http://explorerforum.com/forums/show...mostat+housing
__________________
Previous
Currently
Old 02-07-2011, 12:57 AM   #19
alonso
matmoros,tamp.
98xlt
Vehicle Specs
Quoted: 0 Post(s)
alonso is offline   Reply With Quote
Old 02-07-2011, 01:03 AM   #20
alonso
matmoros,tamp.
98xlt
Vehicle Specs
Quoted: 0 Post(s)
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
