Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
97 explorer sport need fuel filter replacement
Reply
Thread Tools
Old 07-03-2009, 09:43 AM   #1
FordExploder94
new england
FordExploder94's Avatar
1997 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Angry 97 explorer sport need fuel filter replacement
hey guys i just got a fuel filter for my explorer because it has been running like crap lately, some times when i start it up it will barley stay idle and some times it starts right up. some times when im driving it will start to bog down and i will loose rpms even if i am accelerating in a low gear. My guess is a fuel delivery problem. When i went to auto zone they scanned it and said it was running lean and i had an EVAP leak or something. but that's probably because i have no muffler. My father said to start at the fuel filter since it is a relatively cheap fix. My question to you is, are there any special tools i need to remove the old filter and replace the new one. My new fuel filter came with a little plastic thing almost looks like a tool or something. My father said that's probably what it is because he knows more than me.Can you guys give me some inside on this? thanks a lot.
FordExploder94 is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-03-2009, 10:09 AM   #2
FordExploder94
new england
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
here is a pic of the new fuel filter its a WIX
Here is a pic of the existing fuel filter
and heres a pic of BIlly Mays R.I.P.
Last edited by FordExploder94; 07-03-2009 at 10:12 AM. Reason: forgot to upload pics!
Old 07-03-2009, 10:59 AM   #3
dean1997sport
Los Angeles
97 Sport OHV
Vehicle Specs
Quoted: 1 Post(s)
You can go to auto zone and buy the fitting removal tool for like $6.99 they look like little plastic disks. I used the plastic ones, but there is also a metal one. If you do a search for fuel filter you can find out exactly what is involved. Its pretty easy I changed mine in like 10 minutes. Have you done a tune up?
dean1997sport is offline   Reply With Quote
Old 07-03-2009, 12:21 PM   #4
FordExploder94
new england
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
alright well i changed my fuel filter and it its still bogging out and running like crap. my dad said to dump a bottle of dry gas in my tank and see if that helps. if not im just going to have to pay all the money and bring it to a shop
Old 10-18-2009, 02:12 PM   #5
buddy573
San Francisco
1995
Vehicle Specs
Quoted: 0 Post(s)
How much was the fuel filter you put in your car?
Hey
I have a 1995 Ford Explorer and I believe the fuel filter needs to be replaced. Will call around to see how much mechanics want to charge but I thought I would ask around. Any info would be helpful.
buddy573 is offline   Reply With Quote
Old 12-21-2009, 08:17 PM   #6
Jtorsey91
Campton, NH
'98 Explorer XLT 4.0 SOHC
Vehicle Specs
Quoted: 0 Post(s)
its relatively simple to do. i did mine at the shop in my school. i guess its always easier with a lift. but for doing it and using the tool for the first time it took probably 40 min, and cost $8 for the filter and my teacher had the tool.
__________________
_________________________________________
1998 Ford Explorer XLT 4.0 SOHC
Jtorsey91 is offline   Reply With Quote
Old 12-21-2009, 08:21 PM   #7
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
Quoted: 77 Post(s)
Quote:
Next you need to check the fuel pressure of the pump with a guage (harbour freight or borrow one) then I would have the injectors checked. Lots of other possibilities as well. If you have no CEL light, then you have to check things out one at a time and eliminate what works.
Goood luck!
http://www.2carpros.com/dia/test_fuel_pressure.htm
__________________
2000 Ford Explorer SOHC 4X4 310,000KM
2000 VW Beetle 1.8
1991 BMW 735iL
bluestream1 is offline   Reply With Quote
Old 12-22-2009, 08:24 PM   #8
martybaker
Coats,NC
2001 XLS
Vehicle Specs
Quoted: 0 Post(s)
I recently did a tune-up of the 2001 Explorer I just got. It has 156,000 miles on it. Everything on it was original...the plugs (the gap was about .096), wires, coil, fuel filter....everything! I changed the plugs, wires, coil, and took the manifold off and cleaned out all the gunk, but I never could get the fuel filter off. I tried for 2 days, first with the plastic tool, and then with the metal tool. Even sprayed the fitting with lube and let them sit overnight. It runs really good with all the new stuff. If I could get that thing changed, I think it would run even better..lol
martybaker is offline   Reply With Quote
Old 12-23-2009, 05:22 PM   #9
bluestream1
Waterloo Ontario
Vehicle Specs
Quoted: 77 Post(s)
That filter is a real Bitch, but you will get it off. It take a special motion of pushing in with the tool and pulling out with your hands on the line. Once you have done one, it's easy.
I hope you get this and it makes sense; just got back from office christmas party, and not thinking real clear.
__________________
2000 VW Beetle 1.8
1991 BMW 735iL
Old 01-22-2011, 10:28 PM   #10
Bert D
Boise, ID
1997 XLT
Vehicle Specs
Quoted: 0 Post(s)
Change fuel filter
Quote:
Bert D is offline   Reply With Quote
Old 01-22-2011, 10:30 PM   #11
Bert D
Boise, ID
1997 XLT
Vehicle Specs
Quoted: 0 Post(s)
This will be my last visit . Every time I have visited it has been no help. I get redirected to another site. Sorry it happened that way. And the information that I did read on here was either incomplete or misdirected.
Old 01-23-2011, 11:02 PM   #12
rego
Mn
98xlt,2000xlt both ohv 6
Vehicle Specs
Quoted: 6 Post(s)
Quote:
You can hire someone to fix yours. It's OK. There's nothing wrong with that.
rego is offline   Reply With Quote
Old 02-05-2011, 05:09 PM   #13
Brian T Nickless
Courtenay, B.C.
99 Sport
Vehicle Specs
Quoted: 0 Post(s)
CAN Directions
Bert D : Sorry you feel like that. I find tons of useful info, always very well explained and often with photos. You won't find a better resource anywhere else.
Explorer94 : Have you used a heavy duty fuel system cleaner yet ? I'm a big fan of Seafoam motor treatment. 1/2 in the gas tank, 1/2 in the oil. Then
( once it's warmed up ), run it pretty hard. It'll clean the entire fuel system out. Good luck ! Brian
Brian T Nickless is offline   Reply With Quote
Reply
Tags
explorer, filter, fuel, poop, sport
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
