Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2004 Explorer - Caliper Pin Question
Reply
Thread Tools
Old 07-04-2009, 11:47 AM   #1
Born2Run
Vehicle Specs
(Original Poster)
Replacing the pads and rotors on my sister's 2004 Explorer XLT 4WD.
When I pulled the caliper pins to grease, I noticed there are two different style pins. Pin A and Pin B - See pic below.
On the drivers side caliper, Pin A was on the bottom (leading) and Pin B was on the top (trailing) side of the caliper.
On the passengers side caliper, Pin A was on the top (trailing) and Pin B was on the bottom (leading) side of the caliper.
This seemed strange ... I would have expected the same style of pin to be located in the same position (leading/trailing) in the caliper.
I know the pads have been replaced previously ... possible the pins were switched when reassembled.
Does anyone know which pin goes where in the caliper?
My Haynes manual does not clarify and I don't have a shop manual.
Thanks for your help.
Rich
Born2Run is offline   Reply With Quote
Old 07-04-2009, 03:02 PM   #2
Fox Fader
Columbus, GA
searching
Vehicle Specs
Rich,
I'd say if there was no ill effects as it was, put it back like it was.
T
__________________
_______________
2005 XLS 115k not even side steps (sold)
2001 Sport-Trac 131k Wife's
Fox Fader is offline   Reply With Quote
Old 07-04-2009, 07:54 PM   #3
Born2Run
Vehicle Specs
(Original Poster)
Thanks T.
That's probably what I will do ...
... but I would like to know for sure the correct locations for the pins.
Anyone else have any info on this?
Thanks.
Rich
Old 07-05-2009, 09:04 AM   #4
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
I found this too. Keeping track of what came out of where i swapped them to see if it made a difference. Yes, when one was in the wrong way it was lose compared to the other, which was tighter. When put in the correct way there was no slop in either of them, both felt snug the same amount.
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 15k
2010 Sport Trac Limited, V8 4WD, 55k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 07-05-2009, 11:25 PM   #5
muzzymaniac
Kent, NY
04 Explorer XLT 4.0L
Vehicle Specs
Subarus have these too. I found its easiest to buy a pin kit and replace the sleeve. They always seem to bunch up on me when ai reuse them. Put them back the way you found them.
muzzymaniac is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
